Ram Modules with undderfill - tricks for desoldering
+ More Options
Posts
  • ongobongo
    • May 2023
    • 57
    I'm working on another Lenovo E14 gen 2 AMD here which has a ton of errors with the factory soldered DDR4 ram chips. I do have a donor board here from which I'd like to use the modules and swap them. Unfortunately, the modules are glued down with underfill, which i have never worked with before.
    I tried with a lot of heat on the donor board but the modules won't come loose.
    Are there any hint or tricks when it comes to dealing with underfilled chips/ic that could help here
    Ongo
    by sam_sam_sam
    03-31-2024, 02:12 PM
  • gabrielA7
    Zotac GTX 1080 8GB / No video / Error reported on all memory modules!
    by gabrielA7
    Hi guys!!
    I have this video card on my bench, it turns on and the screen goes black!
    I used MATS but it showed an error in all memory modules, when writing!
    I once got a 1060 with the same symptom, all modules were defective, I rebaled the GPU and it stayed the same.
    Remember that I have all the debts ok, 1.35 Vram and such!
    Could the problem really be in the GPU?
    Could it be the BIOS?
    Thank you in advance!​
    06-05-2025, 09:04 AM
  • hans_meier
    HP EliteBook 840 G6 how to dump without desoldering
    by hans_meier
    I have an "HP EliteBook 840 G6" and would like to know how to dump the BIOS flash chip without desoldering. Putting 3.3V on VCC of the BIOS chip with a programmer does not work (seems to enable the PCH). I have read some general notes about connecting the CPU reset to ground or to bypass oscillators. There does not seem to be a reset line for Intel i5-8365U. Just RSMRST, but it's only accessible on the other side of the mainboard. Is there an easy way to dump the flash without desoldering and without removing the mainboard? Does anyone have experience with this? Maybe...
    01-04-2025, 04:11 PM
  • Dreigas
    ISL95880HRTZ desoldering temperature
    by Dreigas
    I bought from China ISL95880HRTZ (3+1+1 Voltage Regulator with Expanded ICCMAX Register Range Supporting IMVP8 CFL/CNL CPUs) chip, which I think is not the original one, but anyway, I tried to resoldering it with a 380C hot air station. Seems soldering is pretty good, but the laptop doesn't work (it worked before, but still had some problems with power delivery).
    Is there any big chance, that they sent me two fake ISL95880HRTZ chips or did I just use too big temperature for desoldering? I will try with another chip, but I can't find any info about the maximum desoldering...
    09-13-2024, 10:59 PM
  • armini
    18VDC PSU completely dead - ZD-915 desoldering station
    by armini
    Hi everyone!
    Three years ago I got a ZD-915 desoldering station which failed just after a few months of light use. During a short desoldering session, the station simply shut down, and since then it has been completely dead and unresponsive. The failure was silent, without any pops.
    Due to a lack of time, I set it aside and didn't look at it.
    Yesterday, I took it apart and did some basic measurements. The 18v terminal shows 0v. In addition, there is no visible damage to the board itself.
    According to replies in 18VDC PSU has dropped to...
    04-25-2023, 07:49 AM
