Hp pavilion 14 - No display
  • Nagyesz
    • May 2024
    • 124
    • Hungary
    So this is why the computer won't turn on? Are you sure this is the source of the problem? Can I measure it somehow?
    • mon2
      • Dec 2019
      • 14190
      Certainly do wait for feedback from other techs but to me, this IC is defective. It is deformity that is not present on a normal IC and often indicates that a transient went through this device -> caused internal damage to the semiconductor die and the same pressure caused the packaging to bubble up. Also, moisture combined with rapid heat can also cause such micro cracks / bubbles which in the PCB production world is named as 'popcorning'. This is a key reason that parts are gently baked before mounting through SMD ovens and that is to draw out or bake out the moisture.
      Can also be caused by reflowing with a hot air tool with too high of a temp and heating of the component at a too high rate. The moisture expands on the inside and as no escape.
      What is Popcorn Effect in PCBA Process (pcbonline.com)
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4326
        • Italy - Milan
        Hi..
        That can't be a popcorn effect as there is no BGA die on a substrate, the popcorn name refers i guess to the tin balls that pops out the side glue between substrate and bga die..
        to the O.P., scratch it away and see if a hole remains or is only a rosin drop.. bye
        • Nagyesz
          • May 2024
          • 124
          • Hungary
          Thank you for the responses so far. I scraped it, and I don't see a hole anywhere.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Post#17 indicates ,you've missing enables(PM_SLP_S3/PM_SLP_S5). These enables will come from PCH. Check the SIO for short as mon2 has suggested(both these enables will go to SIO also).
            • Nagyesz
              • May 2024
              • 124
              • Hungary
              #26
              Thank you for the response. Unfortunately, I am not very skilled, especially when it comes to SIO chips. Where should I look for the short circuit? On which components or which pins on SIO?
              • Nagyesz
                • May 2024
                • 124
                • Hungary
                #27
                Edit: I injected 1.2V into the PL8300 inductor, and nothing really heated up.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4326
                  • Italy - Milan
                  #28
                  Has it got a double chip cpu with integrated graphics? I suspect bad bga, try hard freezing it,.maybe in the freezer in a bag and then test it when frozen..
                  • Nagyesz
                    • May 2024
                    • 124
                    • Hungary
                    #29
                    Thank you for the idea, to be honest, I'm not sure how well this might work, I will wait for someone response because the 1.2V RAM line is still missing, and I have no idea what to do next. ( It has integrated graphics, yea )
                    • Nagyesz
                      • May 2024
                      • 124
                      • Hungary
                      #30
                      Here's a little status update: I got a 135W charger, but unfortunately, the 1.2V for the RAM is still missing.
                      What else should I try experimenting with? Where should I inject the voltage? The 1.2V is missing at RAM IC controller.
                      Would replacing the SIO chip solve the problem?
                      • Sephir0th
                        • Oct 2020
                        • 1282
                        Check PL8400 voltage and resistance to GND please
                        FairRepair on YouTube
                        • Nagyesz
                          • May 2024
                          • 124
                          • Hungary
                          #32
                          PL8400
                          2.8 ohm to gnd
                          1.8V power on state
                          • Sephir0th
                            • Oct 2020
                            • 1282
                            You realized that 2.8 Ohms is a partial short-circuit on the 1.8V rail?
                            • Nagyesz
                              • May 2024
                              • 124
                              • Hungary
                              #34
                              I thought that low resistance was acceptable on low voltage lines.
                              What does it mean if the 1.8V line is shorted? What should be done?"
                              • Sephir0th
                                • Oct 2020
                                • 1282
                                The Classic 1.8VALW is supposed to read in KiloOhms.
                                Voltage injection is the next logical step.
                                • Nagyesz
                                  • May 2024
                                  • 124
                                  • Hungary
                                  #36
                                  Will injecting 1V and say 2-5A into the 1.8V line be sufficient?
                                  Thanks for the tip, by the way.
                                  • Sephir0th
                                    • Oct 2020
                                    • 1282
                                    1 Volt is a good starting voltage. The taken current will tell us whether we have to raise the voltage or not.
                                    Good luck
                                    • Nagyesz
                                      • May 2024
                                      • 124
                                      • Hungary
                                      #38
                                      PL8400
                                      On 1V taking 0.4A
                                      Should I raise the voltage?
                                      • Sephir0th
                                        • Oct 2020
                                        • 1282
                                        If you have a thermal camera there might already something to spot.
                                        And don't forget to remove the heatsink and to clean the CPU/PCH BGA package, since the PCH is a suspect too.
                                        If you can't feel anything you're allowed to raise the voltage to 1.8 Volts max(!).
                                        • Nagyesz
                                          • May 2024
                                          • 124
                                          • Hungary
                                          #40
                                          I checked at 1V and nothing was heating up at all, not even at 1.8V. However, after a few minutes, there was a slight warmth coming from the processor, but nothing serious. What should I do now?
                                          On 1.8V taking 0.69-0.73A
