samsung np550 charging problem
  • trmrtts
    • Jan 2014
    • 38
    • turkey
    hi all
    i have samsung np550: ac adapter with not working but with battery working.charging ic bq735
    vcc :19v
    acdet:3.1v
    acok:0v
    regn:6v
    i changed charging ic,I/O controller and mosfets
    whats my problem?
    boardview:
    schematic:
  • mon2
    • Dec 2019
    • 14106
    Can you post the above in the schematic side of the forum? The above links are raising virus flags.
    Is this your board?
    • trmrtts
      • Jan 2014
      • 38
      • turkey
      Yes this board Mine
      • mon2
        • Dec 2019
        • 14106
        Remove all power. Meter in resistance mode. Measure the resistance to ground of the ACP and then the ACN pins. If the resistance is too low, this charger IC will turn OFF the DCin mosfets and halt the power path that powers the board and stops the battery charging.
        After the above, place one meter probe on the ACP pin (direct on the charger IC), the other meter pin on the ACN pin (direct on the charger IC). Use the lowest meter scale for this measurement. Need to know the full current sense resistance path.
        • trmrtts
          • Jan 2014
          • 38
          • turkey
          acp:6 mohm
          acn:5mohm
          : 2.4 ohm
        • mon2
          • Dec 2019
          • 14106
          Carefully measure the voltage to ground of each pin of each mosfet at Q3 and Q4. One of these at least is probably defective.
          With no power, meter in resistance mode, measure the resistance across the mosfet pins:
          source & drain
          source & gate
          gate & drain
          post each measurement.
            09-07-2024, 05:50 AM
          • Scoff
            HP Probook 470 G4 - Power and Charging Problem
            by Scoff
            Looking for some help with this one if anybody can assist please? I have an HP Probook 470 G4 Laptop which recently started to intermittently failing to turn on, with intermittent white LED light(charging LED) by the charging port when it should have been charging and showing an orange LED instead. Definitely some sort of gradual failure. Now the laptop fails to power on at all, no charging LED, no Power Button LED either - seemingly dead.
            Stripped down to the bare motherboard. The original HP battery, when disconnected from the motherboard, is reading 0.00v - possibly some sort of protection...
            07-03-2023, 09:28 AM
          • ahmarzo
            Hp laptop charging problem
            by ahmarzo
            Have hp laptop motherboard part no opp 17 diner skl/kbl 15289-2 with charging problem.the laptop shows plug in charging but percentage doen not increases.the schematic or boardview is not available.
            Charging ic is bq737 with voltages on pin no
            1&2 -19v
            34&5 -0v
            6 -2.56 v
            7- 0v
            8&9 -3.15v
            10 -0v
            11 -0.18v
            12 & 13 -13v
            14&15 -0v
            16 -6v
            17;18&19 -13v
            20 - 19v
            Voltages on battery connector are
            1&2. -13v
            3&4 -3.14 v
            5&6 -0v
            8&9 are ground...
            03-20-2025, 05:13 AM
          • roman728
            Lenovo E15 / NM-C421 Charging Problem
            by roman728
            Hello guys,
            I have a problem with charging circuit in this laptop. Unit came with no power at all (USB-C meter was cycling turning off and on). I discovered that when I unplug battery laptop works on charger only. So after few measurements I found shorted 1st dual mosfet AONY36324. Unfortunately i was not able to order exact this one, so i ordered AONY36352 which i believe is the similar one. Now the problem is, when i connect battery and charger USB-C meter is not cycling anymore, it starts charging (reading 20V@2,7A) but after few seconds it is going down to 20V@0,20A and laptop...
            02-20-2024, 03:40 AM
          • howardc64
            Samsung UN55JU650DF network/streaming problem
            by howardc64
            Fixed a 9 year old UN55JU650 by replacing backlight. Original backlight LED was still working after 27k! hours but terrible picture of course. Few LEDs were out, 5-6 lens fell off (bright white spots) and another few popped off with slightest force. Surviving LEDs were all slightly blue so picture has a blue tint.
            This TV runs older Tizen OS (updated to latest version, see pic) and have problems with network (wifi or ethernet) connection. The Tizen UI frequently switch to coax input source while changing content sources. . If no good signal (coax not connected, no prior antenna/cable...
            07-09-2025, 12:44 PM
