MacBook A2179 820-01958-A
  • PITERPENY
    • Jul 2023
    • 461
    • Ukraine
    Hello. When you press the caps lock, the green LED does not work. At the same time, caps lock in the system works and switches letters from small to large. what do you advise?
  • Darren Hibbert
    MacBook A2179 Audio board+Power button boardview & schematic needed
    by Darren Hibbert
    Hi.
    Long shot but does anyone have a schematic & boardview for the audio board+power button on a Macbook A2179?
    There is a shorted cap on mine and I need to know if I can safely remove it or whether I need to replace it and with what capacitor.
    Many thanks. ...
    08-21-2025, 02:38 PM
  • cheebster
    Macbook Air 2020 A2179 Internet Recovery and Battery Issues
    by cheebster
    Hello, i have a batch of 10 Macbook Pros A2179 bought from a Costco return wholesaler.
    The 10 of them show the exact same behavior;
    They auto power on, to internet recovery spinning globe, fans to 100%.
    Power consumption on USB-C port is 0.43a, shuts down as soon as unplugged. Battery doesn't charge at all. However, it boots to 20V on the Ampmeter.
    Based on their iBridge versions (4.x and 5.x) these were shelfed for a long time.
    All of them power on the same way; 100% fans, shut down as soon as they are unplugged. Removing...
    10-09-2024, 06:23 AM
  • CAPTGENE
    A2179 Macbook Air turns ON and works normally with a battery but it is not charging
    by CAPTGENE
    I have similar a similar issue. My A2179 Macbook Air turns ON and works normally with a battery but it is not charging. With the USC-C alone it takes 20V but only 100mA, PPBUS is 12.3Volts, and wont turn ON.
    I replaced U7000 twice with the same result. not charging!
    Whats should I check or replace?
    02-20-2025, 02:58 AM
  • envym
    by envym
    Hi everyone!
    06-27-2025, 08:54 AM
  • sdogs
    Macbook Air 2020 A2179 820-01958 battery problem?
    by sdogs
    I have a MacBook Air A2179 in my hands that had power problems (5V to the USB-C port intermittently).
    After a first inspection I could see that the D3302 protection IC was burnt out, so I replaced it but the problem was not solved, it seems like intermittent 5v input.
    I then replaced the two u3200s (CD3217B12ACE) and now I have stable 20 volts and the macbook has turned back on.
    Unfortunately I have a further problem, it works very slowly and the fan runs at maximum and if I disconnect the charger it turns off, it's as if the battery was disconnected.
    02-08-2024, 08:00 AM
