A2442 820-02098 5v 0a
  • sewsulle
    • Feb 2023
    • 16
    Good afternoon,
    I'd appreciate help diagnosing my A2442 that's only taking 5v and 0a
    This was my personal laptop and I had closed it at the end of a class and opened it in the next class when it just didn't wake up from sleep (The battery was charged). I connected a charger later that night and it booted right up but touch ID stopped working. The next day it did the same thing but never turned back on when I plugged in a charger.
    I though the touch ID issue was weird but I'm not sure if that info helps.
    When this happened months ago I tried to diagnose the issue and suspected U5200 but there is no visible damage.
    I'm not sure where to start with this one and any help would be appreciated. I only have experience working on intel boards. This is my first M1.
    Thanks in advance
  • mon2
    • Dec 2019
    • 14673
    What is the voltage to ground of:
    PPBUS_AON @ F5200 / F5201 ?
    Check both sides of these fuses.
    • sewsulle
      • Feb 2023
      • 16
      I have 0.97v on both sides of each fuse
      • mon2
        • Dec 2019
        • 14673
        Remove all power. Meter in resistance mode (not diode). Measure the resistance to ground of PPBUS_AON ​at either of these fuses. What is the measurement?
        • sewsulle
          • Feb 2023
          • 16
          PPBUS_AON resistance to ground is 109.4 ohms
          • mon2
            • Dec 2019
            • 14673
            This is a low resistance value for PPBUS_AON.
            Flux and remove both of these fuses @ F5200 and F5201. Then measure the resistance to ground again to note which side of the fuse(s) is shorting?
            Is it the producer (ISL9240) side or the consumer / downstream side. After the fuses have been removed, power up again and measure the voltage to ground at the PCB pad where either of the fuses were soldered. Measure at the upstream or ISL9240 side of the PCB pad.
            What is the voltage to ground now (without the downstream loading since the fuses have been removed)?
            Update:
            Do confirm the voltage from the power adapter is reaching the ISL9240 - check the voltage to ground of PPDCIN_AON.
            • sewsulle
              • Feb 2023
              • 16
              I have 12.4v on the producer ISL9240 side. As I understand, that means U5200 is not the problem.
              The consumer side is shorting
              Edit:
              PPDCIN_AON: 5.3v
              • mon2
                • Dec 2019
                • 14673
                Measure the resistance from this downstream fuse pad to test each and every inductor (usually are grey in color). If you measure a low resistance,post a list of which inductor. Checking a high side mosfet shorting.
                • sewsulle
                  • Feb 2023
                  • 16
                  Good Morning,
                  Resistance from downstream fuse pad:
                  L5230: 156.6 k ohms
                  L5840: 108.1 ohms
                  L5820 108.1 ohms
                  L5800 108.1 ohms
                  LF800: 1.46 k ohms
                  LN480: 1.34 k ohms
                  LP800: 6.5 k ohms
                  I also noticed that UR660 looks slightly damaged. I'm not sure if this could be the problem.
                  • mon2
                    • Dec 2019
                    • 14673
                    Post a pic of UR660. It may be a factor or may have been damaged from a leaky high side mosfet.
                    L5840: 108.1 ohms
                    L5820 108.1 ohms
                    L5800 108.1 ohms
                    These are of concern. Remove all power. Meter in resistance mode. Measure the resistance to ground of any of these inductors. What is the measurement in ohms?
                    • sewsulle
                      • Feb 2023
                      • 16
                      Unfortunately I won't be home or have access to the board until Wednesday.
                      I really appreciate your help and will post a pic and measurements ASAP.
                      • sewsulle
                        • Feb 2023
                        • 16
                        Thank you for your patience.
                        Resistance to ground on L5800, L5820, and L5840 is 2.8 ohms
                        I've attached a pic of UR660. There are indents/chips in the surface and a nearby capacitor, CR663 is missing.
                        • motormayhem
                          Lenovo T460 Only Charges on One Charger
                          by motormayhem
                          Laptop Question
                          I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                          A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                          05-12-2023, 01:46 PM
                          NVDC charger configuration...
                          11-05-2024, 03:28 PM
                        • flat-earther
                          how to prevent a connected charger from draining battery when not charging?
                          by flat-earther
                          I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                          So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                          but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                          So the battery is backfeeding the charger and being drained.
                          How can I prevent...
                          08-07-2025, 01:04 PM
                        • flat-earther
                          ASUS X54H laptop thinks it's always charging even with charger unplugged
                          by flat-earther
                          The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                          Windows also shows ''Plugged in'' when charger is not connected.
                          This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                          Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                          If I let battery run out and say it has 3% Windows will...
                          06-24-2025, 09:32 AM
                        • Johndill
                          Dell Inspiron 7567 LA-D993P odd charger issue
                          by Johndill
                          Hi, I have a Dell Inspiron 7567 LA-D993P that I've just got running.
                          There was corrosion around PU1503 which shorted PC1518 & blew PL1504. (Reference pictures attached)
                          I've replaced PC1518 & PL1504 & the laptop is now running however I now have another issue.
                          Here are the tested scenarios:
                          1. With the laptop running on battery, I plug in the 150W charger & the charger shuts off (no LED, protection mode) but the laptop remains running on battery.
                          2. With the laptop off, plug in charger (LED says on) & the front charging...
                          11-16-2022, 10:55 PM
