A2337 - Keyboard swap to a different layout
  • soeren
    • Apr 2024
    • 16
    I swapped the keyboard from UK to DE and in my A2337 MacBook Air M1. It works without any problem.
    But I realized, if I reinstall MacOS and when it comes to the First Time Wizard, it still detects an UK keyboard automatically. Then I need to switch it manually to German and then it works.
    Does anyone knows, where is this information stored? Can I change it?
    Thanks!
  • soeren
    • Apr 2024
    • 16
    Anyone?
    • PITERPENY
      • Jul 2023
      • 477
      • Ukraine
      There is such a legend that if you restore via the Internet and then delete the language and leave only the German layout and then reinstall the system from an external drive (make the external drive in your own language), then it will be registered in a new region, maybe just rumors! but in general, each device is assigned to a specific state by serial number!
      • soeren
        • Apr 2024
        • 16
        I tried it, but it didn't work. My laptop was fresh installed via the Internet so I used an USB drive to reinstall the OS. But the keyboard is still UK. Or what are the correct steps? I have created an USB stick from my German MacOS, another laptop, is this correct?
        • kevingill
          • Jun 2013
          • 152
          • England
          Probably stored in the ROM somewhere. Wouldn't worry about it TBH
          • PITERPENY
            • Jul 2023
            • 477
            • Ukraine
            registration to the country is by serial number! if you go into the installed system and delete the native language there and leave only the required one, the system works in the required one even when reinstalling, but with a full reset to factory settings, the language attached to the serial number will return! if you really want it forever, most likely you need a donor socrum with the serial number of the required country!
            • playit
              ps/2 port keyboard dead ? p5ql pro / ethernet cable light
              by playit
              my system is p5ql pro asus mobo , logitech keyboard ps2 keyboard (more than 10 years) .
              my place use to get some power drip for a second ,at that time , pc shuts and restarts itself , it dint cause any problem till now , once or twice i noticed , i am not sure if it was exactly at power drip time or normal time - both keyboard and ethernet lan stopped working , the keyboard would lose power i mean led lights-num lock caps lock would not stay on , no light at etherbet cable too..then i would restart the pc - then its all good .
              few years back ps2 mouse stopped working, but ps2...
              12-23-2024, 06:05 AM
            • kara
              Asus GX501v keyboard not working - keyboard firmware - solved!
              by kara
              Hello, i had a problem with this laptop keyboard. not working even after replacing with new original palmrest.
              Solution after hours of researching is using a small software found on asus forum !
              https://rog-forum.asus.com/t5/rog-ga.../701169/page/6
              Thank you Bogdan Ciulei
              Finally some good news :
              I have managed to fix the problem.
              First,
              I am not responsible for any damage you might do to your hardware !
              YOU DO THIS AT YOUR OWN RISK ! I ONLY PROVIDE POINTERS , DO
              12-09-2025, 02:27 AM
              Fujitsu LIFEBOOK T726 Hybrid (2-in-1) T Specification for Upgrade or Repair
              This specification for the Fujitsu LIFEBOOK T726 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T726 boardview and T726 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Fujitsu...
              09-06-2024, 05:40 AM
