BQ24735 Problem (HP 255 G8)
  • ianbak
    • Apr 2023
    • 58
    I have an HP 255 G8 that runs for as long as its battery holds charge but won't accept AC power.
    I have partially diagnosed the problem and the issue seems to be that there is no ACDRV output from the BQ24735 to turn on the two input MOSFETs. The 24735 has a VCC of 19.57 V, the ACDET input is at 2.93 V and the REGN 6V LDO is outputting 5.98 V, so everything looks good - but ACDRV is stuck at 28 mV.
    I've already replaced the 24735 and both input MOSFETs and nothing has changed.
    I'd appreciate some suiggestions as to what to try next.
  • mon2
    • 14668
    Link the schematics.
    Share the measurements of the charger IC. Is the charger IC the original that was on the board from the vendor or an equivalent?
    A number of conditions must be met for the ACDRV to enable. Also investigate a possible reverse voltage crowbar circuit that often triggers from the barrel / coax power adapter connector.
    • ianbak
      • Apr 2023
      • 58
      I have attached a schematic for the board. The replacement charger IC is a genuine BQ24735, as originally used by HP. There is a reverse voltage protection circuit shown on the circuit diagram, but on my board the components are not present.
      LINK to schematic -> https://www.badcaps.net/forum/troubl...ardview-please
      • mon2
        • 14668
        Carefully flux and remove PRB9. Do not lose this ~4k resistor. Power up again and check the voltage to ground on the PRB9 PCB pad (charger side) that drives the ACDRV pin.
        What is the measurement now ?
        • ianbak
          • Apr 2023
          • 58
          Here is a full set of voltages for the BQ chip:
          Pin 1 - ACN - 347 mV
          Pin 2 - ACP - 913 mV
          Pin 3 - CMSRC - 34 mv
          Pin 4 - ACDRV - 24.3 mV
          Pin 5 - ACOK - 0 V
          Pin 6 - ACDET - 2.93 V
          Pin 7 - IOUT - 0.7 V
          Pin 8 - SDA - 2.1 mV
          Pin 9 - SCL - 1.9 mV
          Pin 10 - ILIM - 0 V
          Pin 11 - BATDRV - 2.07 V
          Pin 12 - SRN - 1.07 V
          Pin 13 - SRP - 1.07 V
          Pin 14 - GND - 0 V
          Pin 15 - LODRV - 0 V
          Pin 16 - REGN - 5.98 V
          Pin 17 - BTST - 3.86 V
          Pin 18 - HIDRV - 1.08 V
          Pin 19 - PHASE - 1.07 V
          Pin 20 - VCC - 19.57 V
          • mon2
            • 14668
            Which mosfets were used for the DCin replacements?
            With no power, meter in resistance mode, measure the resistance across the mosfets as follows:
            source (1-2-3) & drain (5-6-7-8)
            source (1-2-3) & gate (4)
            gate (4) & drain (5-6-7-8)
            Share the measurements.
            • ianbak
              • Apr 2023
              • 58
              The MOSFETs were replaced like for like from a donor board.
              PQB11 Source/Drain - 3.2 MOhm, Source/Gate - 3.7 MOhm, Gate/Drain - 6.3 MOhm
              PQB12 Source/Drain - 4.3 MOhm, Source/Gate - 3.7 MOhm, Gate/Drain - 6.0 MOhm
              • mon2
                • 14668
                Were the measurements in post # 5 taken directly at the charger IC pins?
                Flux and reflow the IC. The conditions look correct for the ACDRV to enable. The DCin mosfets are not shorted.
                Update : Replace the cap that is on REGN pin with another. Must be 2.2uf or higher.
                reference:
                BQ24780S: ACDRV question - Power management forum - Power management - TI E2E support forums
                • ianbak
                  • Apr 2023
                  • 58
                  With PRB9 removed (it took me a while to identify it!) ACDRV is still at 26 mV, he same as before
                  • ianbak
                    • Apr 2023
                    • 58
                    Yes, directly on the charger IC pads.
                    I tried reflowing the 24735, and it's all still as before with ~27 mV on ACDRV. I tried swapping the capacitor too - the one on the donor board measured 1.2 uF before I put it in, which is consistent with the 1.0 uF specified in the schematic.
                    • mon2
                      • 14668
                      Do you have a battery connected to the board?
                      Review the battery charge mosfets to see if they are leaking.
                      Share the measurements of the high side and low side battery charge mosfets.
                      As a quick test, flux and remove the high side battery charge and also the battery pass-thru mosfets to disconnect each from the main power rail that is being monitored by the ACP / ACN current loop circuit. Want to remove all influences on this rail.
                      Then test again.
                      • ianbak
                        • Apr 2023
                        • 58
                        Sorry for the delay in replying - busy day yesterday.
                        There was no battery attached when those measurements were made. With the battery attached and power connected I get the following:
                        Pin 1 - ACN - 10.6 V
                        Pin 2 - ACP - 11.3 V
                        Pin 3 - CMSRC - 24 mv
                        Pin 4 - ACDRV - 18.3 mV
                        Pin 5 - ACOK - 3.3 V
                        Pin 6 - ACDET - 2.9 V
                        Pin 7 - IOUT - 0.8 V
                        Pin 8 - SDA - 0.1 V
                        Pin 9 - SCL - 3.2 V
                        Pin 10 - ILIM - 0.6 V
                        Pin 11 - BATDRV - 17.6 V
                        Pin 12 - SRN - 11.3 V
                        Pin 13 - SRP - 11.3 V
                        Pin 14 - GND - 0 V
                        Pin 16 - REGN - 6.0 V
                        Pin 17 - BTST - 11.0 V
                        Pin 18 - HIDRV - 11.3 V
                        Pin 19 - PHASE - 11.3 V
                        Pin 20 - VCC - 19.5 V​
                        Again, these look pretty OK to me.
                        PQB13 isn't shorted - I was getting at least 50 MOhm every way when I measured it.
                        I tried removing PQB1, which is a double package that I think combines the two battery charge MOSFETs you are referring to, and it made no difference.
                        • mon2
                          • 14668
                          Can you confirm these measurements? These do not look correct for a normal board.
                          • ianbak
                            • Apr 2023
                            • 58
                            I've just re-measured it, with and without the battery present, and the numbers are all still as before.
                            • mon2
                              • 14668
                              Remove all power. Meter in (lowest) resistance mode. Measure the resistance between pins 1 (ACP) & 2 (ACN) of the charger IC @ PUB1. Short your meter probes to review the lowest measurement capable by your meter.
                              Next, measure the resistance to ground of pin # 2 (ACN) of PUB1.
                              The voltage drop across this current sense resistor @ PRB1 is too large. Post each measurement.
                              • ianbak
                                • Apr 2023
                                • 58
                                We might finally be onto something here! ACN to ACP is open circuit, which explains how there can be a 0.7V drop between them when they should be bridged by the current sense resistor! The current sense resistor itself has continuity (measured across terminals 1 and 4) and both ACN and ACP are MOhms to ground.
                                I'll continue to investigate this tomorrow.
                                • ianbak
                                  • Apr 2023
                                  • 58
                                  That was the problem - a broken trace between ACN and the current sense resistor. I located the break, bridged it, and now have a working laptop.
                                  Thanks for your help - I think I'd have given up before finding the fault without it!
                                  • mon2
                                    • 14668
                                    Np. Glad to have helped. It was a good case to learn from for future readers.
                                    • artenidas
                                      Thinkbook 14 G2 ITL problem with open MOSFETs.
                                      by artenidas
                                      I'm working on a USB-C powered laptop (Thinkbook 14 G2 ITL) motherboard K051P with the TPS65994 (U24) and USB-C controller (UT1, likely JHL8040R).
                                      Here's the current status:
                                      U24 has both 3.3V and 5V present
                                      The EEPROM for U24 has 3.3V on pin 8
                                      UT1 also seems fine (has 3.3V supply)
                                      No shorts found anywhere on the board
                                      EEPROM was flashed and soldered correctly, the .bin file is exactly 32KB, so it looks valid
                                      🔧 The problem is:
                                      The second MOSFET (PQS12) is not passing 20V...
                                      08-04-2025, 06:44 AM
                                    • theone111
                                      by theone111
                                      3. Problem: TV shuts down
                                      07-22-2024, 10:36 AM
                                    • Zeonalbasta
                                      Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
                                      by Zeonalbasta
                                      i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
                                      The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
                                      09-13-2024, 01:17 PM
                                    • Gibon378
                                      Problem with stopping audio and video for no reason
                                      by Gibon378
                                      PC Specs:
                                      • CPU: Ryzen 5 1600
                                      • GPU: GTX 1080 Palit JetStream
                                      • MOBO: ASRock ab350 PRO4
                                      • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                      • PSU: XFX 650W (don't remember what model)
                                      • OS SSD: ADATA SP920
                                      • OS: Windows 10 21H2
                                      Problem description:
                                      Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                      11-19-2022, 09:41 AM
                                    • perzyk23
                                      Lenovo T580 - LCD Panel problem - error 0288
                                      by perzyk23
                                      Good morning,
                                      I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                                      10-25-2024, 12:42 AM
