la f401p not charging battery
  • RichBon
    • Apr 2019
    • 54
    • Ghana
    i have these la - f401p motherboard that i am working on. the problem is that it does not charge the battery up it only shows its charging but does not go up. attached is the picture of how it looks. can anyone help me.
  • mon2
    • Dec 2019
    • 14342
    1) Confirm that the power adapter @ 90W matches the actual power adapter's markings. Confirm this adapter is suitable to run this logic board.
    2) It is possible that the battery may be old or defective. If possible, test with another known good battery or test this battery inside of another working logic board.
    3) Remove all power. Meter in lowest resistance mode. Short your meter probes and note the resistance of the shorted probes.
    Locate the charger IC @ PU901. With no power to the board / no battery connected; measure the resistance between pins 1 & 2 on this charger IC.
    We are confirming the full current resistance path for the battery leg of the circuit. Post the measurements.
    • RichBon
      • Apr 2019
      • 54
      • Ghana
      sir should the red prob be on ground to check or red on pin 1 and black on pin 2
      • RichBon
        • Apr 2019
        • 54
        • Ghana
        measuring the resistances between the pin 1 and 2 002.2oms
        but to ground is 0L for both side
        • mon2
          • Dec 2019
          • 14342
          These are good measurements. The total path of the battery charge resistors = 1 ohm + current sense resistor (milli-ohms) + 1 ohm = ~2 ohms.
          Configure your meter into DC volts mode -> connect the battery and also the power adapter.
          Carefully, measure the voltage to ground of the following signals:
          PBAT_CHARGER_SMBDAT
          PBAT_CHARGER_SMBCLK
          We are checking if either of the above lines is shunted to ground from a defective TVS ESD diode.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            PQ4/PQ9-voltage on pin 1/4/8?
            PU2,pin3 voltage?
            • RichBon
              • Apr 2019
              • 54
              • Ghana
              PQ4 is 19 for both 1and 8 pin4 is 1.7v
              and pq9 is 19 and gate is 9.v
              • RichBon
                • Apr 2019
                • 54
                • Ghana
                PBAT_CHARGER_SMBDAT
                PBAT_CHARGER_SMBCLK
                all gives me 3.3 volts
                • RichBon
                  • Apr 2019
                  • 54
                  • Ghana
                  pu2 pin 3 is 3.3v
                  • mon2
                    • Dec 2019
                    • 14342
                    PU2 voltage is ok. This component is a high voltage (input) LDO regulator (capable of accepting the power adapter voltage directly for input) and with a fixed 3v3 output rail. All good here.
                    • RichBon
                      • Apr 2019
                      • 54
                      • Ghana
                      Please is there anything else that is not making it charge
                      • mon2
                        • Dec 2019
                        • 14342
                        Remove all power -> meter in lowest resistance mode. Measure the resistance from the battery connector PBATT1 pins 1-2-3 to the mosfet pins on PQ906. This is to confirm that the EMI filter beads @ PL1 and PL2 are not open circuit.
                        With the power adapter and battery connected, meter in DC volts mode (20v or higher scale if manual type of meter) - carefully measure the voltage to ground on each leg of mosfet PQ906.
                        Post each measurement.
                        • RichBon
                          • Apr 2019
                          • 54
                          • Ghana
                          hi thank all you for the support you gave me. I was able to fix the problem. the solution was PQ 906. that was fault. after changing it, it works well
                          • mon2
                            • Dec 2019
                            • 14342
                            Awesome! Thanks for the update.
                            • Bowline
                              by Bowline
                              06-11-2025, 10:13 AM
                            • Julian Bailey
                              HP ProBook 445 G8 Battery not charging
                              by Julian Bailey
                              Hi all
                              We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
                              The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
                              I have gone around the board with a MM and cant find anything
                              Windows shows the battery fine,...
                              10-11-2024, 10:34 AM
                            • piernov
                              Laptop battery charging circuit
                              by piernov
                              1. Some theory
                              1.1. Introduction
                              Almost every laptop has a charging circuit of some sort, that does a few things:
                              • Manages switching between AC adapter and battery power
                              • Manages battery charging and generates power rail to charge battery
                              There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
                              • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
                              • Narrow VDC (NVDC)
                              Texas instrument has a nice overview of these technologies with some more details at https:...
                              11-15-2020, 01:31 PM
                            • kodox
                              ThinkBook 15 G3 ACL Not Charging Battery - LA-K602P Board
                              by kodox
                              since i couldn't find schematic or boardview for this model (LA-K062P), i use closest board model found here https://www.badcaps.net/forum/troubl...-and-boardview
                              the schematic share same marking for each component, using same PD-Controller, same BQ25710, the only different is the battery cell used. LA-K061P uses 3S battery while LA-K062P use 4S battery per schematic.
                              what i've done:
                              - flashing...
                              12-29-2024, 02:49 AM
                            • Shinju
                              Razor Blade Steath 13" RZ09-01963 plugged in Not Charging (new battery)
                              by Shinju
                              Hey All!
                              Long time forum member here with a problematic laptop issue!
                              I got a RZ09-0196 with a bloated battery (still worked and charged fine) I pulled the old cell pack out and installed a new cell pack in its place.
                              The laptop would not power on with the new battery installed without the power supply being plugged in.
                              When booting into Win10 (all up to date BTW) I saw the battery icon with 49% plugged in not charging.
                              TL;Dr version, old battery worked, charged but was bloated, installed a new non OEM replacement, laptop/windows...
                              10-20-2021, 04:58 PM
