Sony MBX-273 No Power(3.3V, 5V Missing)
  • Hasith
    • Dec 2015
    • 35
    • Sri Lanka
    I have this Sony MBX-273 on my hand. 19V present but no Voltage on 3.3, 5V Coils.
    It has a SN608098 Chip. When I check its pins It shows;
    19V on pin 6(VIN)
    5.3V on pin 4(EN_LDO)
    3.4V on pin 5(VREF3)
    1.3V on pin 1(VREF2)
    But only 0.46V on pin 7(LDO)
    Is this means Chip is gone?
  • mon2
    • 14666
    Remove all power. Meter in resistance mode. Measure the resistance to ground of this LDO rail.
    Post the measurement.
    • Hasith
      • Dec 2015
      • 35
      • Sri Lanka
      Thanks for the reply. Its shows 355 in diode mode
      • mon2
        • 14666
        Not a short. Test with a replacement of this part.
        • Hasith
          • Dec 2015
          • 35
          • Sri Lanka
          It should be that chip, right? Thanks
          • mon2
            • 14666
            Yes. The ldo regulator is internal to this device. The enable signal is present and output side is not shorted. Suspecting the part is defective since there is no valid output voltage.
            • Hasith
              • Dec 2015
              • 35
              • Sri Lanka
              Understood. Thank you so much for the clarification
              • mohamed mm
                sony vaio mbx-247, missing S5_ON signal
                by mohamed mm
                Hi everyone, I hope you are having a good day.
                I have a laptop sony Vaio, DA0HK1MB6E0, MBX-247. REV: E
                The laptop suddenly shut down as the owner told me, so I did the normal check there is no short but the laptop it's not powering up and there is no light when I connect the adapter because there is no battery.
                so I checked.
                pu9:
                Vin: 19v
                Ldo: 4.89v
                Ref:1.99v
                Vcc: 4.89v
                Vdd: 4.89v
                output
                3.3v pcu.
                EN2: 4.89v
                but No
                01-19-2023, 05:17 AM
              • lilo2400
                Sony PS5 EDM-020 MIssing voltages near HDMI encoder
                by lilo2400
                Hey guys..I have an EDM-020 and I'm missing these standby voltages marked with blue...I have already replaced the HDMI encoder IC but is still the same I have all the rest of 3v and 5v ...where does this voltage comes from does, anybody knows.
                Thanks in advance
                09-02-2025, 03:58 AM
              • Shushyamush
                Sony PS4 Missing component
                by Shushyamush
                Hello Ive just reballed a PS4 that had the BLOD but it still has the same symptoms.
                I noticed a component missing from the board, not sure how that happened, it there on all the pictures I look at of the motherboard,
                can anyone advise me what the value of the missing SMD is please?
                03-27-2024, 06:15 AM
              • Ritchie_Uk
                Sony PS4 component Missing, near the HDMI Port
                by Ritchie_Uk
                Hi there
                A Sony PS4 came in for "No Video" and it seems there is a component Missing, near the HDMI Port.
                The Component circled in Red
                1. Was this just a Component Missing from Manufacture please?
                2. It is a straight forward Port Replacement, or do I need to be aware of anything else?
                3. Any Schematics or Board Views available?
                Any Advice is greatly appreciated.
                Stay Safe !!...
                05-22-2023, 06:12 PM
              • Carlos#2003%
                Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                by Carlos#2003%
                Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                02-15-2024, 07:52 PM
