Asus TP412F - No Power
  • mrgumshot
    • Sep 2015
    • 13
    • Netherlands
ID:	3268557 Hi All,
    i’ve got a Asus laptop on my bench here with a shorted IC. I think its a Power regulator but i cannot find ANY info on this IC. I thought i’d try my luck here.
    Had a coil which was shorted to ground. Injected 1V and watched this ic get hot under thermal cam. Removed the IC and the short was gone. Now its .3 voltage drop which is good.
    So basically i need help identifying this IC.
    it looks like it says V+ BUB but i’m not sure. I cant find any info on google and theres no silk screen or schematic as far as i can see.
  • mon2
    • Dec 2019
    • 14003
    Post pics of the PCB (without this part); the bottom side of this removed part.
    • mrgumshot
      • Sep 2015
      • 13
      • Netherlands
      You mean like this?
      • mon2
        • Dec 2019
        • 14003
        What is nearby this regulator? What is the function of this power rail?
        Pour some IPA onto the top surface to enhance and magnify the topside smd markings. Take another pic with the IPA.
        • GLISIT
          by GLISIT
          01-16-2025, 02:29 PM
        • abajor
          Asus G634j Rog Strix SCAR Power rail shorted nothing hot on thermal camera.
          by abajor
          I haven't been able to find a schematic or board view for one of these out in the wild. I had one come in with a no charge/no boot issue.
          It Uses two pairs of Source to Source Mosfets after the power jack to prevent back flow from battery or PSU after the power jack.
          The drain on the board feed side of the Mosfets measures a near dead short to ground. I attempted a voltage injection there it draws about 1.4A at 1V absolutely nothing heats up on the thermal camera.
          It draws 1.86A injecting directly to ground.
          Is this just the way it is when these ultra...
          03-19-2025, 03:23 AM
        • OOF DIO
          ASUS FX505DV no power shorted at PWM controller Pin 3 VREG3 TPS51225C, need pinpointing of the short.
          by OOF DIO
          (If anyone has a functional boardview file of FX505DV/DU that would be helpful)
          (Had 3 problems, now just 1)
          I have no experience or knowledge and usage of tools to repair devices besides the entire past 12-10 days of researching, watching YouTube repair videos and troubleshooting this laptop motherboard. ChatGPT was used as a guide to ask questions.
          I used boardviews of mostly FX505GD-M, and some FX505DU, FX505DD. Used schematics of FX505DU.
          I had originally intended to replace the BQ24780s first (due to previous battery removal while benchmarking) but I...
          04-19-2025, 05:03 PM
        • PantherDave
          by PantherDave
          Hi all!
          05-29-2024, 02:01 PM
