Problem Asus Main Board TP412UA REV.3.0
  • Rofix
    • Jul 2023
    • 73
    • Italia
    Hello everyone, I kindly wanted to ask you for advice, on this PC as soon as I connect the power cable without doing anything the part where the CPU, GPU is heated up, with the bench power supply it absorbs 600 mA, without battery, kindly since I'm here various coils almost short what can we start doing? thanks for any advice
  • reformatt
    • Feb 2020
    • 1416
    I have worked on one of these ages back, no boardview or schematic available. I did write up this at the time:
    AVTK 684 --> AVT* NB687gq-v (RAM)
    ALTJ 228 --> ALT* NB679gd-z (+5V)
    L8= --> RT6256B (+3.3V)
    K6= --> RT6228A (PCH I think, prob 1V)
    RT3602AC (CPU driver)
    BQ24780S charger IC
    ITE 8987E BXA (128kb flash memory)​
    What IC is next to the coil that has 0 ohms to ground?
    • Dani_2024
      by Dani_2024
      10-28-2024, 05:06 PM
    • ygorsan
      by ygorsan
      🧩 Problem Summary:
      • I
      07-28-2025, 08:34 AM
    • jb_Bak
      by jb_Bak
      CN6401
      Pin 01 NC
      Pin 02 NC
      Pin 03 "BL_ON": 0V
      Pin 04 "N/C"
      Pin 05 "STBY 3.3V": 3.5V
      Pin 06 "GND": N/C
      Pin 07 "AC_OFF"...
      09-27-2021, 04:52 PM
    • JDC
      by JDC
      ONN 100012588
      Long answer:
      07-15-2022, 07:39 AM
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
