A2141 DFU error message now USB C asking 20.49V and configurator says "Recovery"
  • abajor
    • 178
    I have a A2141 which fails DFU with error code shown in image.
    Now instead of DFU it says "Recovery"
    A little back ground on this laptop. I was thinking of writing a topic on corporate laziness and irresponsibility.
    We acquired a handful of laptops which a very large company wanted to have shredded due to sensitive information.
    Since apple has NSA grade drive formatting I think this is inexcusably lazy that the IT department doesn't just target mode format the drives and release the MDM, and donate the laptops.
    Personally I think a large company paying to have working relatively modern laptops shredded should be fined for squandering resources and being an ecologic and economic parasite.
    I would love love love to out the company that's doing this, but I don't want to jeopardize the person who was tasked to shredding these laptops livelihood.
    That said the T2 rom chips are being flashed to clear the MDM. (Wondering about best practices when doing this)
    This has worked on every one of these laptops except this one, the rollback chip was damaged and I replaced it. I've also replaced the ROM.
    Does anybody know anything I should look for since it apparently failed the DFU restore and is now in recovery.
  • myth77
    a1466 to a2141 apple configurator
    by myth77
    I am having issue with macbook pro a2141, 2019. It start with question mark, the only option is internet recovery but it will not go to disk utility mode..just stops on like 1/3 progress bar with apple logo.
    When i insert usb disk it will not recognize it, but on usb ports it is giving picture on external screen. It is heating a lot.
    I did all resets and only thing left is try to revive it (firmware reinstall) with apple configurator from another mac. I have only macbook air 1466 from 2013. I install apple configurator on macbook air but when i connect usb-c (mac 2019) to usb-a...
    08-28-2022, 12:26 PM
  • macabook
    A2141 issues after display replacement
    by macabook
    I have replaced a broken display on A2141 with a good one, taken from similar model, now the image and backlight works fine. But the camera, the true tone and keyboard backlight is not working. I made some research on internet but I am still not sure how to fix it, according to logiwiki the A2141 display is compatible with all similar model but we need to use a1707 flex cable, so my questions are:
    1-does the cable will make every thing work fine ?
    2-Do we need to swap display IC chips from the old display to make everything work correctly,( I saw it on multiple video...
    12-26-2024, 02:20 PM
  • Arshad alam4659
    MACBOOK PRO A2141 SSD SHORT
    by Arshad alam4659
    I HAVE A MACBOOK PRO A2141 820-01700 THIS BOARD IS PP2V5_NAND_SSD1 SHORT TO GROUND THEN I CHECK ONE SIDE U8600 IS SHORT THIS SIDE IS ONLY ONE CHIP U8600 OTHER SIDE
    PP2V5_NAND_SSD1 IS OK AND U9100 U9200 U9300 U9400 IS ALSO OK Will removing the U8600 fix the board or will I have to install a new one
    Link to boardview --> https://www.badcaps.net/forum/troubl...91#post1449091
    10-01-2024, 08:26 AM
  • Joyoungjae
    a2141 820-01700 charge only with one port
    by Joyoungjae
    Hello friends, it's been a while.
    Model A2141 came to me for repair.
    I confirmed that there was a short in the ppdcin line and that the capacitor was blown.
    All the short line capacitors seemed to be in bad condition, so I replaced all c7043, c7024, c7026, c7027, c7029, and c7042.
    The short is caught and the power is turned on.
    However, when the power is turned on with the battery installed, only one charging port works and the other three display 20V but 0 amps.
    If you plug in the charger when the battery is not installed...
    07-31-2024, 05:27 AM
  • Arshad alam4659
    Macbook pro A2141 graphics short
    by Arshad alam4659
    Macbook pro a2141 PP1V8_S0_GPU is short to ground , how can i disable gpu, someone tell me
    09-23-2025, 06:59 AM
