Lenovo Yoga 13 Panasonic, no video, fan OK, missing voltage rail (?)
  • jaroslav.psenicka
    • Jul 2020
    • 34
    • Czechia
    I have a Lenovo Yoga 13 Panasonic here, when powered
    • both fans spins (the sconds starts with a bit of a delay), no image neither on HDMI nor the display
    • most voltage rails seem OK (see image below, red labels)
    • resistnace to ground mostly seem OK as well (blue labels)
    the only suspicious is the 0.0V rail (2nd from left, top row)
    • the resistance to ground is rather low (1.9ohm)
    • when injecting the voltage (1V), it consumes around 200mA, seems OK to me (?)
    also tried new BIOS, no change
    I can't find a schematics for the board - can some of you gurus look at the voltages? are they OK from your POV?
    thank you very much,
    -jp
    Click image for larger version  Name:	336552ed-354c-4643-bfcd-05dcc9ec2575.png Views:	0 Size:	1.72 MB ID:	3263636
  • mon2
    • Dec 2019
    • 14731
    See attached. Start with the DCin power connector. The voltage here should match the power adapter voltage. Then review the 2 * DCin mosfets (Q16 & Q17) next. Need to check the voltage to ground of each of these mosfets in the power path.
    Post each measurement.
    Click image for larger version  Name:	power_path2.png Views:	3 Size:	781.8 KB ID:	3263738
    • jaroslav.psenicka
      • Jul 2020
      • 34
      • Czechia
      Thank you very much @mon2,
      here are the measurements:
      I'm testing the board outside of the laptop, with no battery connected, this may explain the low voltage on the BAT line (?)
      the resistance to ground on BAT is almost 500 ohm, looks OK to me
      the VIN is 20.1V, sounds good to me either
      -jp
      • mon2
        • Dec 2019
        • 14731
        These are good measurements to me. Need to check if I have a board view file to check on the referenced 0 volts on the board.
        What is the history of the board?
        • jaroslav.psenicka
          • Jul 2020
          • 34
          • Czechia
          that would be awesome @mon2,
          if I can identify the rail, I may find the mosfet and the corresponding controller, one of these may be bad IMO
          I wonder what rail is missing... could be something like B+?
          the board is not labeled (no silkscreen), the coil of missing rail is R47 (0.47uH?)
          this is actually an ebay find, not a clear history, not many signs of misuse of water damage
          -jp
          • electron_jj
            Panasonic TH-L42D25A checking the PSU output voltage
            by electron_jj
            Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
            I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
            08-29-2021, 08:13 AM
          • Maxpower3
            Brand name and Model Type for Lenovo error 2202 product name is invalid
            by Maxpower3
            Info for error 2202 LenovoThinkPad models and type
            Extract from ThinkPad Maintenance Utilities Configuration File
            plnsrv.ini Version 1.01
            Some information that may be useful
            There must also be missing models, add them to the list if you know of any.
            Code:
            brand name
            20B1=ThinkPad Edge E445
            20B2=ThinkPad Edge E545
            20BC=ThinkPad Edge E145
            20BM=ThinkPad X140e
            20BL=ThinkPad X140e
            20A3=ThinkPad X230s
            20AH=ThinkPad X230s
            20AK=ThinkPad X240s
            20AJ=ThinkPad X240s
            02-21-2024, 10:27 AM
          • crot69
            asus x453sa missing all voltage except 19v and charging pin
            by crot69
            Hi, my friend have this laptop
            Before all voltage missing, im already repair this laptop 3x (i have 3 of this laptop and all of them dead, can't be repaired because dead CPU and other component due unknow chips, why always asus laptop have this issue).
            1st repair it short at 3vsus (dead low side mosfe and short caps)
            2nd repair short at CPU Vcore mosfet (low side)
            3rd repair 12v missing (only 1.2v but it can run bios and hdd not detected because 3vs missing).
            and then after 3x enter BIOS it blank then dead (all mosfet buzzing, 12v still missing)
            11-23-2022, 09:51 PM
          • BC_TechForum_drb
            Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
            by BC_TechForum_drb
            Sub: Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
            Ref: 1/ MacPro6,1 Late 2013/A1481 MD878LL/A (3.5 GHz 6 Core Xeon E5-1650v2)
            Gfx-B: APN: 661-7548 PPN: 820-3533-A AMD FirePro D500-B 3GB Vmem
            2/ Figure 1 Gfx-D500-B Front Facing
            3/ Figure 2 +5v supply (zoom-in)
            Intro:
            While troubleshooting a Mac Pro(6,1) referenced above I discovered the +5v secondary supply did not stand up on the D500-B graphics card as a result of a missing enable signal. The +3.3v secondary rail was the only rail that did standup. I tried to perform...
            12-07-2023, 09:55 PM
          • Instafixx
            Macbook A2179 820-01958
            by Instafixx
            Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
            The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
            I checked the Power Sequences below and found this -
            Once a valid external power source (Charger or battery) is connected, the following rails will come online.
            PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
            PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
            05-20-2023, 05:19 AM
