ASUS X542UR Touchpad problem
    My laptop's touchpad is not working. I have tried software, touchpad and touchpad fpc. I think the motherboard is faulty, can you share motherboard schematics or how can I fix the problem?
    Model
    X542UR-GQ272T
    Part No
    90NB0FE2-M03490
    Part Desc
    AS X542U 7500U/1DG5/12G/TU
    Part Specification
    X542UR-1BGQ/8SL/V/WAC/A08
    Have a good day,
    Schematic requests go here -> https://www.badcaps.net/forum/troubl...-requests-only
      Originally posted by SMDFlea View Post
      I asked both for the schematic and to see if we could find a solution to my problem.
        Which is the trackpad connector? Is it J3103 in the shared pic?
        Test it by placing the meter in diode mode. No power on the logic board. Connect the trackpad.
        Red meter probe (yes red) to ground.
        Black meter probe to point to test.
        Test each pin on the trackpad connector. Post each diode mode measurement.
          I checked each pin of J3103 and they all work
              which ones I will measure, can you write their names?
                Post #4
                  Post #4
                  I checked all the J3103 pins, they're all working.
                    and my motherboard touchpad connector name is not J3102, my touchpad connector its J3103.
                      ok my problem is solved, I was connecting to the wrong connector
