DAH98NMB8C0 REV C HF need help
  • jhanra
    • Aug 2020
    • 51
    • phillipines
    good day experts!
    i have huawei matebook d14
    the laptop works normaly when using it and charging
    the problem is when i shutdown the laptop and not using it, the part in the picture with red circle
    becomes so hot you cant even touch it, and it drains the battery quickly
    i cant find schematics for this laptop
    can someone tell me what is this part so i can replace it
  • jhanra
    • Aug 2020
    • 51
    • phillipines
    this is the part
    2920u (sot23-5 marking)
    when laptop on and charging (normal)
    pin 1 vin = 16v battery voltage
    pin 2 GND
    pin 3 = 0.7v
    pin 4 = 0.9v
    pin 5 out = 3.3v
    when laptop off
    pin 2 GND
    pin 3 = 0v
    pin 4 = 1.2v
    pin 5 = 2.6v
    when laptop is off and charger plugged in (normal)
    pin 2 GND
    pin 3 = 0.7v
    pin 4 = 0.9v
    pin 5 out = 3.3v​
    this part is so hot when laptop is off and charger unplugged
    i hope someone can help
    THANKS
    • jhanra
      • Aug 2020
      • 51
      • phillipines
      can i replace it with this?
      • mon2
        • Dec 2019
        • 14680
        Do not replace this part till more is known about the original.
        The last character of this part looks like a ‘7’ ? Pour alcohol onto the top surface to gain clarity of the markings. Can you confirm?
        • jhanra
          • Aug 2020
          • 51
          • phillipines
          its not my pic, CTTO, i only edit the video i got from the net, the part marking in mine is 2920u,
          forgot to take the picture in mine cause the owner took it and will return it to me when i have the parts
          • mon2
            • Dec 2019
            • 14680
            Remove all power. Meter in resistance mode (not diode mode). Measure the resistance to ground of each pin of this SOT23-5 package. The part may be getting hot due to an excessive loading of the output pin. Post each measurement.
            • jhanra
              • Aug 2020
              • 51
              • phillipines
              ok i will try that, and post result
              thanks for the reply
              • mon2
                • Dec 2019
                • 14680
                I think it is part # G2920T11U by GMT but still working on a few leads. More later once at the office. Aliexpress has these.
                • jhanra
                  • Aug 2020
                  • 51
                  • phillipines
                  resistance
                  test probe shorted 0.9ohm
                  test to gnd
                  pin 1 = 197.8 ohms
                  pin 2 = gnd
                  pin 3 = 99.0 ohms
                  pin 4 = 8.57 kohms
                  pin 5 = 13.19kohms
                  the test is no battery connected
                  • jhanra
                    • Aug 2020
                    • 51
                    • phillipines
                    thank you very much, but i cant find this in my location, theres no aliexpress here in the philippine
                    is there any equivalent to this chip?
                    • mon2
                      • Dec 2019
                      • 14680
                      Ok - found it. See attached.
                      From other board pics of a similar model:
                      This is a HIGH VOLTAGE (for input) low current fixed LDO @ 3v3 output. Should be common to replace with others if the pinout can match.
                      Click image for larger version  Name:	pinout.png Views:	0 Size:	126.5 KB ID:	3246049
                      Datasheet:
                      • jhanra
                        • Aug 2020
                        • 51
                        • phillipines
                        Datasheet:
                        is the ohms reading the same?
                        by the way thanks for you effort to help me
                        • mon2
                          • Dec 2019
                          • 14680
                          I do not have this board but a similar one is in my database. The LP*** LDO is rated @ 50 mA but this one from GMT is rated @ 150 mA. You could try it if it is available to you but need to review the pinout functions.
                          My last post lost the datasheet - it is attached here.
                          G2920.GMT-1493-220214-0.6.pdf
                          • jhanra
                            • Aug 2020
                            • 51
                            • phillipines
                            thank you for your help, i think my last option is to buy a faulty board here
                            cause there's no way i can get that part here.
                            i will post the result as soon as i replace that part
                            • mon2
                              • Dec 2019
                              • 14680
                              Do you have access to Mouser or Digikey?
                              AliExpress can deliver the parts to your region?
                              We can locate a suitable replacement if needed. In the end. This is a fixed 3v3 ldo with an enable pin. The input must be tolerant to a high voltage like the battery or adapter voltage.
                              • wooddy
                                • Jan 2015
                                • thailand
                                I'm having this problem as well. I don't think the G2920 is bad because pin 8 in the BIOS is shorted to ground. Have you found the problem yet?
                                • mon2
                                  • Dec 2019
                                  • 14680
                                  With no power, what is the resistance to ground of pin #8 on the bios?
                                  Do you have an adjustable power supply for voltage injection? Do not use higher than 1 volt.
                                  • xe_d_sono
                                    • Aug 2013
                                    • 25
                                    • Portugal
                                    I have one too, this is dead CPU (HUB).
                                    • jaf b
                                      • Jan 2024
                                      • 3
                                      • Philippines
                                      Very informative.. Thanks
                                      • abdo3200
                                        • Mar 2016
                                        • 25
                                        • cairo
                                        Anyone help me
                                          Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                                          09-06-2024, 09:30 PM
                                          Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 08:47 AM
                                        • RdeveLabs
                                          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                          by RdeveLabs
                                          To all the members here...
                                          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                          05-05-2025, 04:59 AM
                                          Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                                          This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:11 AM
