Lenovo Legion Y520-15IKBM - No power besides the main rail
  • Fronczek
    • Jan 2024
    • 33
    • Poland
    Hello people,
    I've got this laptop not working for repairs, and as you can see something was done to it as you can see in the coils PL58XX (which I for some reason cannot find in the schematics...) The first FET (PQ201) was not an original part and a questionable one at that and the second one (PQ202) was shorted. Both are N-channel. Ordered replacements for them and replaced them after arrival. Now I have encountered another problem: there is no power at the second FET. By following the thread linked I got to the injection part. Applied 0.8V at 1.5A, but couldn't feel anything getting hot, so upped it to 1V at 2.5A and to my relief the PCH nor the CPU is getting hot. What is though, is the area near the first FET. I don't have a thermal camera, so further troubleshooting is an issue. I suspected that one of the caps gone bad, just in case did measurements that I put in the photos, but it's conflicting with what seems most likely the first FET getting hot, but I feel heat in the general area of it. Help will be much appreciated! I'm attaching a schematic for this board, and a few photos.
    Measurements:
    Main rail (VIN) is 20.6V
    PF101 has continuity, so it's not the fuse
    None of these 5 caps have the same voltage on both terminals
    PQ201:
    S-D - 20.2V, 2.8MΩ
    S-G - 0V, OL
    D-G - 20V, OL
    PQ202:
    S-D - 0V, 3.5MΩ
    S-G - 0V, 3.8MΩ
    D-G - 0V, 5.2MΩ
    ACDET is 2.8V
    ACOK is 0V
    LINK to schematic -> https://www.badcaps.net/forum/troubl...45#post1352445
    Technical discussions covering any type of laptop, notebook, netbook, tablet, or smartphone. Any and all brands and models welcome. When starting a new thread, please put the make AND model of your device in the thread title. Also be VERY descriptive of your issue, that way you'll get the best answer possible!
  • mon2
    • Dec 2019
    • 14793
    Locate the battery charger IC -> review the VCC (power rail) of the charger IC. Is it being powered? Confirm the voltage to ground of the REGN pin on the charger IC. It should be ~6 volts.
    If the charger IC is not being powered, then the gate pins of the DCin mosfets will not be available to enable this power path.
    • Fronczek
      • Jan 2024
      • 33
      • Poland
      Yep, REGN is at 6V and the VCC's being fed 20.3V
      • mon2
        • Dec 2019
        • 14793
        Measure the voltage of the ACDRV pin on the charger ic. It should be ~25v if all is well. If not, remove the ~4K ohm resistor in series with this line and test the acdrv pin again.
        • Fronczek
          • Jan 2024
          • 33
          • Poland
          ACDRV is gone even without the resistor in question, also why 25V?
          • mon2
            • Dec 2019
            • 14793
            N-channel mosfets require gate pin voltage to be higher than the source / drain voltage being passed to enable.
            gate voltage = adapter input voltage + REGN voltage = 19 volts + 6 volts = 25 volts.
            Best to carefully (!!) measure the voltage to ground of each pin on the charger ic with the power adapter attached. Post each measurement.
            • Fronczek
              • Jan 2024
              • 33
              • Poland
              Weirdest thing just happened - plugged in the laptop and seen sparks from a capacitor (PC216). It blew up, so I replaced it for a smaller one but with a higher voltage rating and ACDRV is back???????????????
              #1 (ACN) - 19.95V
              #2 (ACP) - 19.95V
              #4 (ACDRV) - 26.45V
              #5 (ACOK) - 3.3V
              #6 (ACDET) - 2.8V
              #11 (SDA) - 3.3V
              #12 (SCL) - 3.3V
              #15 (BATPRES#) - 3.3V
              #16 (TB_STAT#) - 1.35V
              #17 (BATSRC) - 220mV
              #18 (BATDRV) - 250mV
              #19-20 (SRN, SRP) - 220mV
              #21 (ILIM) - 1.35V
              #24 (REGN) - 6V
              #25 (BTST) - 5.7V
              #26, 27 (HIDRV, PHASE) - 220mV
              #28 (VCC) - 20.3V
              The rest have 0V
              Let me add that the battery is not plugged in as of testing.
              • Fronczek
                • Jan 2024
                • 33
                • Poland
                Sorry my post is in sort of an "Unapproved" limbo
                  SMDFlea commented
                  Editing a comment
                  Sorry,it was due to the forums spam filter
              • Fronczek
                • Jan 2024
                • 33
                • Poland
                Weirdest thing just happened - plugged in the laptop and saw sparks from a capacitor (PC216). It blew up, so I replaced it for a smaller one but with a higher voltage rating and ACDRV is back??
                • mon2
                  • Dec 2019
                  • 14793
                  The voltage list looks good. Check the voltage to ground at each inductor (usually are grey in color). Each inductor is linked to a power rail. Measure each to check if that rail is working or not. Or test the board again.
                  • Fronczek
                    • Jan 2024
                    • 33
                    • Poland
                    The laptop is indeed booting, although it seems to be stuck in boot/bios, it doesn't output to HDMI (the matrix is missing at the moment). The charger plugged LED seems to be missing as well
                    • mon2
                      • Dec 2019
                      • 14793
                      Do you have video on the lcd display?
                      • Fronczek
                        • Jan 2024
                        • 33
                        • Poland
                        Got the laptop for repairs without one, and I don't have a 30 pin lcd at the moment. I could order one right now.
                        • mon2
                          • Dec 2019
                          • 14793
                          It is ok to test with HDMI. No video with HDMI? Does the keyboard caps key led toggle?
                          • Fronczek
                            • Jan 2024
                            • 33
                            • Poland
                            Yep, no video at all. The fans are working at the max rpm (I think) and the components are getting hot, and yes the caps led toggles.
                            • ktmmotocross
                              Boardkiller
                              • Feb 2014
                              • 3634
                              • slovakia
                              Guys i have same problem . Always with this bloody 780S. anybody know what is main trouble with them?
                              i have looks like all things that needs to be have/voltages/, but after half a second ic put power down. i see spiked ACDRV, ACOK, but only for a halfsecond. mosfets are ok, i changed ic, ADAPTER_ID is 1Kohm to GND so with 135W adapter is ok
                              when i jump first mosfet laptop works
                              • mon2
                                • Dec 2019
                                • 14793
                                Ideally, share the measurements of the voltage to ground of each pin on the 780S.
                                At the very least share,
                                VCC ; is the charger IC being powered?
                                REGN ; must be ~6 volts
                                ACIN ; current sense voltage of the main power rail
                                ACIP
                                ACDET ; is the power adapter threshold being met to enable the DCin mosfets?
                                If the current sense resistor path is not complete or out of spec, the DCin mosfets will be turned off.
                                • ktmmotocross
                                  Boardkiller
                                  • Feb 2014
                                  • 3634
                                  • slovakia
                                  ACIP
                                  VCC ; 20V
                                  CMSRC - 0V
                                  REGN 6V
                                  BS - 5.7V
                                  IADP - 0V
                                  ACDET - 2.8V​
                                  VDD - 6V
                                  ACDRV - 0V
                                  All missing voltages is normal for a half second and than goes down
                                  • mon2
                                    • Dec 2019
                                    • 14793
                                    Remove all power. Meter in resistance mode.
                                    1) measure the resistance between pins 1 & 2 but do so directly at the charger IC.
                                    2) measure the resistance to ground of pin # 2 of this charger IC.
                                    Post both measurements.
                                    • mcplslg123
                                      • Jun 2015
                                      • 7262
                                      • india
                                      ACDRV will only rise when CMSRC is present and ACOK is pulled high. Seems like overcurrent shutdown by charging IC.
                                      • mkdj
                                        Acer TravelMate P214 - N19Q7 main power rail shorted to ground
                                        by mkdj
                                        Dear all,
                                        I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
                                        I have checked resistance across each of the 4 MOSFETS. I have the following readings:
                                        Both N-Channel Mosfets: nothing odd
                                        P-Channel MOSFET number 1:
                                        source - drain : 117 kOhm
                                        source - gate: 96 Ohm
                                        gate - drain: 117 kOhm
                                        P-Channel MOSFET...
                                        08-20-2025, 06:08 AM
                                        Lenovo Legion Legion 5 17ACH6H Notebook Specification for Upgrade or Repair
                                        This specification for the Lenovo Legion Legion 5 17ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Legion 5 17ACH6H boardview and Legion 5 17ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-07-2024, 05:00 AM
                                        Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook Specification for Upgrade or Repair
                                        This specification for the Lenovo Legion Laptop Gamer Notebook Legion 5 15ACH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Laptop Gamer Notebook Legion 5 15ACH6H boardview and Laptop Gamer Notebook Legion 5 15ACH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                        Lenovo Legion Legion 5 15ITH6H Notebook Specification for Upgrade or Repair
                                        This specification for the Lenovo Legion Legion 5 15ITH6H Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Legion 5 15ITH6H boardview and Legion 5 15ITH6H schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-07-2024, 04:10 AM
                                      • HERETIK10
                                        MSI GT70 2PE Voltage dropping on the main power rail
                                        by HERETIK10
                                        I have a strange problem (for me) on an MSI GT70 2PE laptop.
                                        When it's under heavy load, power goes steadily to the battery (for 2 or 3 seconds) then return to the charger. If I remove the battery it turns off.
                                        The higher the load, the lower the voltage on the main rail. We go from 19.5V, PC connected to the charger but turned off (normal consumption of 0.06A)
                                        On, when it draws 2A the voltage is 19.2V, then eventually collapses to 18.5V (and turns off) around 5A.
                                        I removed the first 2 mosfets (PQ13 & 14) from the main rail, without noticeable change....
                                        11-24-2023, 06:06 AM
