A2338 Trackpad and keyboard not work after somtime.
+ More Options
Posts
  • vijayppatel017
    Vijay Patel
    • Dec 2023
    A2338, after sometimes trackpad and keyboard not work, and USB keyboard and mouse work all time,
    changed UT360, UT301. Diode value dropped in PP1V85_S2_IPD from 443 to 200. then i will replace that both IC and again value increase. same repeat. any idea, what to do,​
  • hoang sonw
    macbookviet
    • Feb 2021
    • 7
    • Viet Nam
    Borrow voltage from pin (1) CT311 connected to pin (2) RT311
    • iMuhtaseb
      A2681 Keyboard, trackpad and sleep?!
      by iMuhtaseb
      Wow it's been a while since I posted!
      This is a weird case, it has a history of liquid spill a year ago but customer did not want to replace neither trackpad or keyboard.. fast forward for today:
      A2681 turns on but not trackpad or keyboard feedback (or external keyboard and mouse) and then after a minute or so the Mac sleeps..
      It's a NOT a sleep sensor or trackpad or keyboard or daughterboard or anything else (I replaced all those); it's the logic board..
      Tested another locked logic board on customer's top case and it posted with keyboard and...
      05-22-2025, 09:59 AM
    • ronaldopdias
      A3113 corrosion to LAS = No keyboard, yet screen and trackpad work fine
      by ronaldopdias
      Hi All.
      I have a A3113 MacBook Air 13" (M3) that had minor liquid damage. The screen remains on if the lid is closed, the keyboard doesn't work, but trackpad and Touch ID does.​
      The LAS was corroded, but I have tested it on an A2681 (M2) and it functions fine. Anyway, I ordered a new one and replaced it and calibrated it with Apple.
      I have checked the main voltages going to the daughterboard and they are present. Diode mode reading on the LAS line which goes direct to the SoC is also correct, no short.
      So then I replaced the daughterboard, and...
      06-16-2025, 03:12 AM
    • slimmy182
      A2289 MacBook keyboard and trackpad does not work anymore
      by slimmy182
      hello, my A2289 MacBook keyboard and trackpad does not work anymore. keyboard backlight is working, Touch Bar is working but I can’t use it. if I connect external keyboard and external mouse all work perfectly, but internal keyboard and trackpad does not work. The Apple Hardware Test completes with the error PPF003 indicating that the fan is not working properly. (PPF004). does it worth try to change keyboard and trackpad? or Maybe I need logic board repair? I take apart trackpad and no signs of corrosion
      04-17-2021, 03:55 AM
    • guzq
      MBA13 M3 2024 A3113 EMC8611 820-03285 No Trackpad No Keyboard (water damaged)
      by guzq
      Hi Guys,
      This Mac come with dead issues (severe water damage), now it’s turning ON except Trackpad and Keyboard not working.
      Already check and write down DM for JT400 and JT201 don’t find any abnormal value (I don’t have unit for compare).
      Already try,
      • Replacing Trackpad Flex Cable
      • Replacing New Trackpad
      • Replacing Little Board (Daughter Board)
      • Try using New Keyboard
      Still no change at all, Trackpad and Keyboard not working.
      So I check “Power Load Switches” and this is all the numbers,
      UC830 > 1 = 3.297V ; 3 =1.757V ; 4 = 3.798V...
      07-08-2025, 05:19 AM
    • hollox123
      ASUS ROG Strix G713QR - Keyboard, backlight and side LEDs don't work
      by hollox123
      Hello, I have an "ASUS ROG Strix G713QR" laptop, and for approx. 3 months I have the following problems:
      1. Laptop keyboard doesn't work
      2. The backlight on the laptop keyboard doesn't work
      3. The x2 side LEDs (red) on the laptop don't work
      The power button works, the touchpad works, and all the USB, HDMI, Ethernet, etc. ports work.
      I already tried to reinstall all the drivers and reinstall Windows. So I don't know what to try anymore that is software-related.
      But I am strongly aiming that it is somehow a BIOS-related problem,...
      05-11-2025, 08:05 AM
