820-01041 NO BACKLIGHT NEED HELP MISSING 60v
  • alfredposadas09
    • Aug 2020
    • 343
    • Philippines
    820-01041 i manage to repair the leak capacitor in C846x now the diode reading is ok i think u8400 is not working
    F8400=12.56v
    R8400= 12.56v​
    PPVOUT_S0_LCDBKLT= 1.1diode reading= 0v
    PP5V_G3S_BKLT_A=5v
    PP5V_G3S_BKLT_D=5v
    EDP_BKLT_EN=0v <<suspicious
    ISNS_LCDBKLT_P= 3.3v
    ISNS_LCDBKLT_N=3.3v
    I2C_BKLT_SCL=i didnt check it yet
    I2C_BKLT_SDA=i didnt check it yet
  • mon2
    • Dec 2019
    • 14006
    Diode reading implies a short circuit on this rail. Switch to resistance mode on your meter. Check the resistance to ground of this same PPVOUT_S0_LCDBKLT rail. Post the measurement.
    • alfredposadas09
      • Aug 2020
      • 343
      • Philippines
      DIODE READING =0.1v before when i remove the leak caps it goes 1.1v based on flexbv5 software the reading is 1.1v diode i guess (red probe on ground and black probe on that rail)
      • alfredposadas09
        • Aug 2020
        • 343
        • Philippines
        does macbook lcd needs 12v to the lcd to communicate to the pch?
        • alfredposadas09
          • Aug 2020
          • 343
          • Philippines
          i sucessfully remove the leaked caps here in PPVOUT_S0_LCDBKLT but still no 12v
          • alfredposadas09
            • Aug 2020
            • 343
            • Philippines
            PPVIN_S0SW_LCDBKLT_FET=12v
            LCDBKLT_EN_L=12v
            voltage divider doesnt work as well u8400
            • mon2
              • Dec 2019
              • 14006
              U8400 (backlight ic) may be defective. If available, replace with a known good controller.
              • alfredposadas09
                • Aug 2020
                • 343
                • Philippines
                ok sir i forgot to tell that the camera connector is blown .. ok tommorow i will replace backlight ic and give u update sir thank you so much for ur help i really appreciate it
                • alfredposadas09
                  • Aug 2020
                  • 343
                  • Philippines
                  i replace backlightd driver still not working
                  • mon2
                    • Dec 2019
                    • 14006
                    Review this page:
                    https://logi.wiki/index.php/Backlight_Troubleshooting
                    • mon2
                      • Dec 2019
                      • 14006
                      Do you have caps key led toggle?
                      Do you have graphics if viewed with a phone torch light on the front of the lcd? Logic board works with external display?
                      check the smbus lines from the camera connector. They maybe impacting other smbus slave devices/sensors.
                      Open lid sensor voltage to ground is ok?
                      • alfredposadas09
                        • Aug 2020
                        • 343
                        • Philippines
                        i have key caps toggled .. we hear the chime sound too
                        • mon2
                          • Dec 2019
                          • 14006
                          Check the voltage to ground of the i2c lines used by this backlight IC.
                          Each of the return backlight led lines must reach the backlight IC from the lcd connector.
                          If the lcd is not detected, the backlight will not enable.
                          If the lid is considered to be closed using the trackpad sensor, the backlight will disable.
                          Does this keyboard feature a backlight? Does it function?
                          • mon2
                            • Dec 2019
                            • 14006
                            Adding to the list...remove all power. Meter in DIODE mode. Red meter probe, yes RED to ground.
                            Black meter probe to point to test.
                            Measure the following points of interest in this DIODE mode:
                            I2C_DISP_SCL
                            I2C_DISP_SDA
                            Post each measurement. The above I2C / SMBUS lines are used to configure the graphics MUX (multiplexer) @ U9801. If these lines are defective or not working correctly then the LCD display will not be powered, backlight will not be enabled.
                            • alfredposadas09
                              • Aug 2020
                              • 343
                              • Philippines
                              I2C_DISP_SCL
                              I2C_DISP_SDA
                              Click image for larger version  Name:	GMUX.png Views:	38 Size:	158.2 KB ID:	3245164
                              sir this is the result upon checking
                              DIODE MODE:
                              I2C_DISP_SCL =0.422
                              I2C_DISP_SDA =0.422
                              VOLTAGE MODE:
                              I2C_DISP_SCL= 1.2V << is this normal?
                              I2C_DISP_SDA= 1.2V << is this normal?
                              PP3V3_S5_GPIOX_R=3.3v
                              PP1V8_S5_GPIOX_R=1.799v
                              • alfredposadas09
                                • Aug 2020
                                • 343
                                • Philippines
                                hello anyone?
                                • mon2
                                  • Dec 2019
                                  • 14006
                                  No, the parked I2C_DISP_SCL / I2C_DISP_SDA voltage is not normal. It is a good find.
                                  Carefully review the voltage to ground of PP5V_G3S. This is the pull-up voltage rail used by this I2C pair of communication lines.
                                  Carefully, measure that you have a valid 5 volt reading on each side of R8444 and also R8445. This power rail is used to power the backlight IC and other parts of the logic board.
                                  Next, remove all power -> meter in resistance mode (not diode mode) ->measure the resistance to ground of PP5V_G3S​. If there is a shorted part on this rail, the voltage will be lower than expected.
                                  This power rail is created by U7650 buck regulator. This regulator may be defective or have a shorted part on the output. Measure the resistance (not diode mode) to ground @ L7600 (either side is ok).
                                  • alfredposadas09
                                    • Aug 2020
                                    • 343
                                    • Philippines
                                    Next, remove all power -> meter in resistance mode (not diode mode) ->measure the resistance to ground of PP5V_G3S. If there is a shorted part on this rail, the voltage will be lower than expected.
                                    R8444\R8445=5v each side
                                    L7600=3.3k ohm​
                                    • mon2
                                      • Dec 2019
                                      • 14006
                                      Go back to the i2c lines and measure their voltage to ground on each side of the pull up resistors.
                                      I2C_DISP_SCL
                                      I2C_DISP_SDA
                                      • alfredposadas09
                                        • Aug 2020
                                        • 343
                                        • Philippines
                                        R5215 = PP1.8V_S5 = 1.8V /I2C_DISP_SDA=1.8V
                                        R5216=PP1.8V_S5 = 1.8V /I2C_DISP_SCL=1.8V
                                        • SuperAman
                                          PS5 HDMI port diode reading?
                                          by SuperAman
                                          I did an hdmi port repair for a PS5 and I lost the small diode z71 SOD923 on the back of the port. I did a trace repair for pin 19 of the port as well. Without the diode I get no display at all. I tried replacing the diode twice but after I get flux on it the marking comes off so I can't tell if I have it on the right orientation. When I measure I get a reading of 1(open) and 923 in diode mode. Is 923 a normal reading for these and also which side should the reading be with regards to the arrow on the board?...
                                          02-03-2024, 10:16 PM
                                        • abajor
                                          A2141 PP3v3_G3H_RTC_X Diode Reading .104V Voltage 3.39V
                                          by abajor
                                          Have an A2141 which is reading about 5.2V 0.07A on all USB jacks, started doing the measurements.
                                          PPBUS_3GH diode: measures good .45V
                                          PPBUS_3GH Voltage: maybe not so good 12.25V maybe bad T2? Unit did not come up in DFU on configurator.
                                          The weird so far is
                                          PP3v3_G3H_RTC_X diode: .104V (WTF?)
                                          PP3v3_G3H_RTC_X voltage: 3.39V (Normal)
                                          Stopped there attempted reverse voltage injection at PP3v3_G3H_RTC_X with 1V. Instead of the circuit sinking any current, My PSU suddenly reads 3.4V with no current draw.
                                          Not sure what any of this means...
                                          03-18-2025, 10:27 PM
                                        • iMuhtaseb
                                          A2681 Keyboard, trackpad and sleep?!
                                          by iMuhtaseb
                                          Wow it's been a while since I posted!
                                          This is a weird case, it has a history of liquid spill a year ago but customer did not want to replace neither trackpad or keyboard.. fast forward for today:
                                          A2681 turns on but not trackpad or keyboard feedback (or external keyboard and mouse) and then after a minute or so the Mac sleeps..
                                          It's a NOT a sleep sensor or trackpad or keyboard or daughterboard or anything else (I replaced all those); it's the logic board..
                                          Tested another locked logic board on customer's top case and it posted with keyboard and...
                                          05-22-2025, 09:59 AM
                                        • Kyleadonis
                                          Launch Automotive Diagnostic Tool Missing Diode and Cap
                                          by Kyleadonis
                                          Hi there, I need some help identifying replacements for a Launch Diagnostic Plug In Tool. I can't seem to find any information on the LF 7HZPU Diode so I have no idea what to replace it with if anyone can help? Also there is a missing component on the side that I highlighted in green and I assuming it's a cap?
                                          I have added some photos for reference....
                                          09-03-2024, 11:54 PM
                                        • karoliens
                                          820-01700 PPVCC_S0_CPU normal resistance to ground/diode reading?
                                          by karoliens
                                          I am working on this board that has some water damage though not around this rail but I measured it anyway to rule out that CPU is not fried.
                                          Resistance to ground on PPVCC_S0_CPU rail is 2Ohm and in diode mode it shows 0V.
                                          What is the normal reading on that rail?
                                          TIA
                                          09-11-2022, 12:55 PM
