DAOR33MB6E0 REV:E Partial ON
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    What is the voltage on ram supply (PL16)coil? Dramrst# should be 1.5V and not 1.61V. May be ram is supplied excess voltage.
    You should get voltage on PL29(i know its gfx core but have seen voltage on this coil in R33 mb). So probe components connected to PL29. Of ten the high side mosfet(PQ44) connected to PL29 gets partialy shorted.
    If PQ44 is damaged,then you need to replace PU15/PQ44/PQ43 all at one go.
    Btw, 1.05V_VTT_PWRGD present?
    • ravi_1617
      YY Solutions
      • Jan 2012
      • 343
      • India
      Yes you r correct,it's 1.5V
      Sorry for delay in replying.as you are saying PL29 GFX core should be present.
      I have checked PQ44 & 43, were fine,PU15 area was corrosive,I have removed/cleaned/ replaced ,than slight change observed, (previously as told board turning off) now it doesn't turn off,but PCH is heating ,
      Now what do u suspect to
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Replace PU15.
        • ravi_1617
          YY Solutions
          • Jan 2012
          • 343
          • India
          Replace PU15.
          I have replaced as, I said.
          I didn't had spare , ordered it, after replacing I had posted
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Glad to know that ravi
            • valente222
              HP 14 LA-A993P REV 1.0, identify ic? and not susp# present
              by valente222
              I have a Mb LA-A993P REV 1.0 computer, I am guiding myself with these two shared boards. ;
              there are some ICs that are not the same, in this case those of the PU1501 (JD4TB) and PUH1 (NF4SA) images.
              n, please identify.
              330mA of consumption after 8 seconds turns off. +3VALW AND +5VALW present, EC_RSMRST# , LID_SW# , EC_ON# , ACIN# present.
              SUSP# NOT PRESENT, which would be this the problem does not turn on sub-sources Any leakage?
              I also notice that in the PLH2 coil that belongs to +1.05VS according to the drawings I am not sure,
              06-27-2024, 06:11 PM
            • air_chair256
              Lenovo Yoga 9I 15IMH5, MB LC40CM Won't Turn On, 1V_VCCGT is not present
              by air_chair256
              I have a Lenovo MB LC40CM 19863-1 when press button is pushed the keyboard backlight turns on and off twice and the power button light keeps blinking and the fans spins for a few seconds and stops then again spins and stops (Three times) then laptop turns off. no image on screen. sometime when you leave it for few days it will turn on and work but once you restart it won't turn on.
              Tried to reball RAM 1,2,3,4
              Checked all voltages on big coils all present except 1V_VCCGT is not present I get 0V on this rail. is this voltage should be present once power button...
              02-13-2024, 06:00 AM
            • javieromex
              Dell G15 5511 LA-K452P won't turn on
              by javieromex
              Hello, any help will be apprecited!
              • Model: Dell G15 5511
              • MB: LA-K452P
              • Issue: Won't turn on at all, no leds, no keyboard light, no fan spin, nothing happens when pressing power button. NOTHING.
              • Customer reported it was turned off and left plugged in during the night and thats it...
              • No signs of liquid damage or burned components.
              Link to Schematics -> https://www.badcaps.net/forum/troubl...la-k452p-gdp50
              I have checked so far:
              04-17-2025, 12:44 PM
            • Prott
              Surface Pro 7 - SLP_S4 present, then gone
              by Prott
              Hello fellow Badcappers,
              I have a problem with stubborn Surface Pro 7. I narowed it down to disappearing SLP_S4# (gone after around 200 ms).
              Everything else works as it should (the whole power on sequence succesfully finishes, all the voltages are present) until this signal goes missing - with it missing the AND gate causes ALL_SYS_PWRGD to go back low and this makes VCCIN drop to 0 V as well. Interestingly the SLP_S4_DRV# signal from SAM is still present for a second, even after SLP_S4 is no longer there. I wonder what could either cause PCH to stop sending the signal or what...
              12-03-2023, 06:11 PM
            • lapfix
              Lenovo IdeaPad 3 NM-C961.no display
              by lapfix
              Hello everyone.
              lap and motherboard : IdeaPad 3-15IGL05 Laptop - Type 81WQ
              NM-C961.
              Behaviour : connect charger it power on automatically ,reach 0.170 amp than down to 0.74 amp...no display.
              with battery connected it reach 980 amp than 870 ...no display
              No short ; no corrision no intervention before.
              Try 2 differents bios versions same behaviour.
              Some measuremets :
              PL 1600 = 5valw present
              pl 1100 = 3 vlalw present
              pl 100 = 0.221 v without battery and when battery connected 7.8 volt
              pl 6602 = 1.2 v
              pl 6603 = 1.056v...
              05-29-2025, 05:01 AM
