Alienware M15 R3.Which of these is the BIOS chip?
  • survivalbloke
    • Aug 2021
    • 302
    This is a Alienware M15 R3. It has a no power condition, 0 amps being drawn. The power button is blinking 3 amber, 6 blue which lines up with an incomplete BIOS flash. Looking at this board, it appears it has 3 winbond chips and I'm not sure which of these is the BIOS chip. The board is LA-J52. Follow up question, can I extract a BIOS file from a Dell exectuable bios update file? ****EDIT***** That lower right "UE2" is not a winbond.
    Click image for larger version  Name:	M15.png Views:	0 Size:	2.13 MB ID:	3235668
    Common SPI bios chip programming Questions and Answers
    by SMDFlea
    Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
    A: If you can`t read from it how do you expect to write to it ?.
    Q: Why is my bios chip unreadable ?.
    A: The programmer is faulty or has a worn or broken zif socket.
    The USB cable is frayed,connector pins worn or some other physical damage.
    Not enough amperage or voltage to power the programmer properly.
    Bad...
    09-02-2021, 04:40 PM
  • JoWed
    Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
    by JoWed
    Hello Community,
    I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
    07-01-2025, 09:32 AM
  • drux
    Alienware Aurora R15 accidentally flashed with XPS 8960 BIOS
    by drux
    I've had an ssd that was previously used on dell xps 8960 and then it was installed in Alienware Aurora R15(intel version). On first windows boot in R15 windows started bios update and loaded bios for xps 8960(r15 and xps8960 essentially have same motherboards).
    Now it has xps 8960 bios that looks different from alienware bios and when I'm trying to run bios update files for R15, I get unsupported platform error.
    These models have AMI/Aptio BIOS.
    Tried to edit product info with DMI Edit to change values back to Alienware R15, but it does not want...
    11-03-2024, 01:18 AM
  • hyperwood
    [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
    by hyperwood
    I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
    The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
    I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
    āœ… What I need:
    • A working 2MB BIOS dump
    • Matching NM-E471 Rev. 2.0, e.g. JY575
    06-25-2025, 02:28 PM
  • Azurain
    Elitebook 840 G5 Bios Chip Soldering Question
    by Azurain
    I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
    Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
    04-14-2023, 06:58 PM
