G7A-2G DA0G7AMB6D1 REV:D startup problem
  • mesut
    • Jan 2010
    • 10
    Hello, I need help. The required voltages are coming in the places I marked, but there is no power.
    The light is not on, 3.3 volts are coming to the power button, I reprogrammed the bios what could be the problem?
  • Chaminda4191
    Chaminda4191
    • Apr 2023
    • 31
    • Sri Lanka
    first Check PG signals
    • mesut
      • Jan 2010
      • 10
      PG sig. is ok
      • theone111
        by theone111
        3. Problem: TV shuts down
        07-22-2024, 10:36 AM
      • Zeonalbasta
        Thinkpad X1 Carbon "LMQ-1MB 12298-2 48.4LY26.021" VCC3M problem
        by Zeonalbasta
        i have a problem with thinkpad X1 carbon gen 2 "LMQ-1MB 12298-2 48.4LY26.021"
        The laptop was turned off because the MOSFET was not transmitting voltage. After checking it turned out that the gate pin on the MOSFET was the problem, because it was producing an inappropriate voltage. and it was discovered that the problem was with the Think engine, so I decided to reprint each pin, and finally the mosfet could work properly. However, there is another problem, even though the voltage has been supplied to the laptop, it still won't turn on, there isn't even an LED indicator. After double...
        09-13-2024, 01:17 PM
      • Term1903
        philips 42pfl8694h (8404h) startup problem
        by Term1903
        hello friends,
        tv has problem at startup procedure, when main power is on, tv tries to wakeup , after three times trial it turns into error(protection) mode and gives red led flashing twice.
        what I have checked;
        3.3v standby voltage is OK,
        mainboard pulls the ps_ON pin to low(this happening three times) at this period, psu 12V becomes active, and I can see 1.2v 3.3v 5v on the mainboad at measuring points.
        attached you will find the service manual and some photos
        thank in advance for any suggestion,....
        12-15-2022, 07:31 AM
      • Gibon378
        Problem with stopping audio and video for no reason
        by Gibon378
        PC Specs:
        • CPU: Ryzen 5 1600
        • GPU: GTX 1080 Palit JetStream
        • MOBO: ASRock ab350 PRO4
        • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
        • PSU: XFX 650W (don't remember what model)
        • OS SSD: ADATA SP920
        • OS: Windows 10 21H2
        Problem description:
        Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
        11-19-2022, 09:41 AM
      • perzyk23
        Lenovo T580 - LCD Panel problem - error 0288
        by perzyk23
        Good morning,
        I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
        10-25-2024, 12:42 AM
