asus k50ij dead
  • koresi
    • Sep 2012
    • 24
    asus k50ij dead
    hello,
    i have an asus k50ij with no led lights and no charging;there is only +19V and 3,3v for EC also EC_reset but no VSUS_ON.
    I have checked the EC inputs everything seems to be ok...AC_IN_OC# is 3,3v...EC clock is 32 Khz..
    I would change the EC but i want to be sure that EC is defective...
    Any hint?
    Could be the bios chip?I am not sure that the EC needs bios to rise up the VSUS_ON signal.
    Waiting for your opinions...
    Best regards.
  • sopik78
    • Nov 2013
    • 517
    • Czech Republic
    Re: asus k50ij dead
    Try charger IC MB39A132 and related FETs
    • Francisco.s
      • 691
      • Spain
      Re: asus k50ij dead
      Could you measure a high level at pin 19 (VSUS_ON) of IT8502?. (U3001)
      If so, did this voltage gets to J8111 to reach VSUS_ON_PWR point?
      (VSUS_ON--> VSUS_ON_PWR--> ENBL)
      This mobo has JP8113 pads, to POWER TEST the pwm circuit of 3,3 and 5 volts.
      Check and post results.
      • whaldsz
        • Apr 2013
        • 395
        • Philippines
        Re: asus k50ij dead
        Originally posted by koresi
        hello,
        Any hint?
        Best regards.
        Check if you get 3.3v at RSMRST#.
        • koresi
          • Sep 2012
          • 24
          Re: asus k50ij dead
          no,there is no voltage on pin 19 of IT8502.
          • koresi
            • Sep 2012
            • 24
            Re: asus k50ij dead
            i did not checked the RSMRST# signal,but i think it becomes active after VSUS_ON and SUSPWRGOOD.
            I will check and tell you.
            thanks.
            • desktop85
              • Jul 2013
              • 14
              • Venezuela
              Re: asus k50ij dead
              I've the same board with the same problem, I solder the test pad JP81113 to power on the PWM U8101 ( RT8206AGQW ) but nothing happens, I've checked the power mosfets that the U8101 controls but are ok. Also I replace the PWM by other compatible ISL6236 but nothing.
              I solder the test pad because I don't have the ENBL signal.
