Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
  • korben_dallas
    • Sep 2023
    • 6
    • united states
    Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
    I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
    I'm new to soldering but the only feasible way to fix this issue is to do something myself.
    MY QUESTION:
    I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?) after reflowing the GPU v-core. However, I've also been seeing elsewhere that people don't have this issue at all.
    Also, one repair shop I called said they dont this repair anymore and just replace the logic board. But other people I've talked to (or seen Youtube videos of - namely Louis Rossman and ddosdude) don't run into logic board issues at all.
    So what am I looking at here? What's the real answer? Will I be running into a bricked device after refow of the GPU v-core?
    Or perhaps I misread things and these "disabled logic board" issues are only for certain MBP models (not mine)...
    Full model: Mid-2012 Macbook Pro 15" Retina A1398 (EMC 2512) MC975LL/A
  • Sephir0th
    • Oct 2020
    • 1255
    Finally, Post 1000
    But back to the topic: Most likely yes.
    You probably first need to realize that these are two completely different things when either an experienced chip-level technician like Louis Rossmann or a beginner with little experience works on large BGAs.
    An incredible amount can go wrong in such a process. It's not for nothing that BGA rework is one of the absolute supreme disciplines at chip level.
    However, there seems to be a second big misunderstanding, namely the "reflow" itself. Surprisingly, the theory that reflow would be of any use in the case of a black screen still persists these days. A dead chip is a dead chip and no reflow in the world can change this state.
    Of course, experienced colleagues know that this is all nonsense and in most cases only makes the problems worse or even renders the device unusable. The only cases where a reflow would (temporarily) bring an improvement are the old NVidia chips with the Bumpgate issue, which were mainly produced between 2006 and 2008.
    See also here: https://www.badcaps.net/forum/troubl...vidia-bumpgate
    My understanding is that your MacBook is from 2012, so there is no indication that it would do anything. And even if it did, a reflow can never be called a "repair". It rarely lasts for more than a few weeks.
    Even if there is an indication, for example in the event of a fall, the BGA would have to be completely desoldered and then the pads checked for damage.
    All in all, this is a very bad idea and I strongly advise against it.
    FairRepair on YouTube
    • piernov
      • Jan 2016
      • 4435
      • France
      OP is talking about the GPU VCore buck controller IC, which suffers from bad soldering joints cracking under mechanical stress on the 820-3332 board. Still does not mean this is an easy fix for someone with no experience at all though.
      Also this is not true, it's not reflowing that does something (as in melting the balls), it's the heat, and many ICs react to heat (same thing for the well known failures of AMD from around 2008-2012).
      • korben_dallas
        • Sep 2023
        • 6
        • united states
        Congrats on post 1000! I feel honored 🙂
        1. How would a reflow render my device unusable? In what ways can a logic board become unusable after a reflow?
        2. But I thought the Bumpgate chips were just... faulty chips. How would a reflow "bring an improvement" to a faulty chip? I don't think my Nvidia Geforce 650M falls under the Bumpgate thing. The 650M was made in 2012. The 650M isn't the problem, it's the way Apple soldered on the chip (cheaply). This issue with GPU chips in Apple MBP's around this time was it's own big deal like "Bumpgate". They did a full "repair" program that expired, and afaik, all Apple did was add a "spacer" that would push the GPU vcore U8900 chip into the board so that there was a connection with the soder.
        I've read comments from people (without soldering experience) have done this exact repair and been okay. It's only now seeing posts on this forum where a GPU vcore repair has resulted in a bricked logic board. I'll have to search these forums again to see what models they were repairing.
        • korben_dallas
          • Sep 2023
          • 6
          • united states
          piernov - Assuming I do the reflow successfully... are there any reasons why the logic board might become "bricked" or unusable after? Searching these forums, I see a lot of posts about serial number issues (?). What are those about?
          • Sephir0th
            • Oct 2020
            • 1255
            Ohh, missed this detail. Then nevermind please...
            Next time I have probably to look into the boardview before start writing...
            • piernov
              • Jan 2016
              • 4435
              • France
              If the repair is performed improperly, of course it can cause the problem to get worse, like any other kind of repair. But board repair with no experience at all can easily go wrong, so it's always advisable to practice on a worthless board first.
              While it is not very common, the soldering joints issue on the GPU VCore buck controller can cause bad voltage regulation and can damage the GPU itself, and improper soldering when performing the repair can do the same.
              • korben_dallas
                • Sep 2023
                • 6
                • united states
                So to clarify, there shouldn’t be any BIOS/SMBIOS/EFI issues if a reflow is performed on the discrete GPU, right?
                • piernov
                  • Jan 2016
                  • 4435
                  • France
                  No, but no reflow should ever be performed on a GPU, it won't fix any issue and it can easily make it worse by completely killing the GPU, damaging the balls when they were not the problem, or even damaging the board.
                  • tony359
                    Reflow equipment
                    by tony359
                    Hello all,
                    I am experimenting a bit with reflowing larger components - ideally I'd like to reflow a PS4 APU or a GPU for example.
                    I know it's impossible to reflow such large components with just hot air so I bought a pre-heating plate, T-8280 classic Chinese machine, which seems to be working fine besides it's a little slow, which shouldn't be a big deal.
                    Now, my hot air station is a Aoyue 852A++ and I feel it's a bit weak when used with larger nozzle. I tried reflowing a laptop chipset using one of those large, rectangular, nozzles and I failed miserably,...
                    12-25-2021, 01:29 PM
                  • Francisco.s
                    CPU vcore missing in HP workstation Z2 Mini 4G
                    by Francisco.s
                    Hi, have a HP workstation Z2 Mini 4G for repair with CPU vcore missing.
                    The resistance at the output of CPU vcore coils, is less than one ohm so I think CPU could be damaged, but no mosfet are damaged.
                    It mounts an i7 8th gen, and have only i5 7th gen for test, but I think it is not compatible.
                    Without CPU in the socket there is no short, but there is no vcore voltag, and it emits a beep like no detecting ram.
                    The controller chip for cpu vcore is a MP2949A, and has no enable voltage at pin 37.
                    I wonder which circuit generates this enable...
                    04-22-2024, 12:35 PM
                  • mikzs
                    Rx580 8gb sapphire nitro+ turn off vcore randomly
                    by mikzs
                    Hello, this is my first post, English is not my native language but I hope you understand me. I recently got a 580 that didn't turn on the typical short mosfet, as I didn't know exactly which one was short, I unsoldered them until I got the bad one out, I was able to remove the short and identify the bad mosfet, the gpu gives video again! but it has a problem that completely turns off vcore at random times or if I try to put a load on the gpu vcore drops to 0 I don't have much idea why because I don't know much about sapphire, any advice on where I could start looking or what problem it could...
                    11-06-2023, 12:28 PM
                  • jm942
                    Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
                    by jm942
                    My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
                    I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
                    I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
                    I did voltage injection on the cpu with 0.7V and i have a current...
                    07-11-2024, 05:11 AM
                  • mferna14
                    MacBook Pro (Retina, Mid 2012) A1398 heats up & turns off
                    by mferna14
                    Hi all. I am working on MacBook Pro (Retina, Mid 2012) A1398 820-3332-A. There is no liquid spill & no physical damages on the logic board. The CPU/GPU heats sink heats up a lot & then turns off automatically. I did a re-solder job on the GPU VCORE chip U8900, but this did not help much & also updated the BIOS. Added brand new coolant compound but still the same, after about 1/2 hr, it heats up & then turns off automatically. Just asking anyone will the CPU & GPU BGA balls reflow will be suitable to rectify this problem. Any tips or help will be greatly appreciated. Thanks...
                    02-14-2021, 02:36 PM
