MacBook Pro A1706 - Stuck at 5V and 0.09A
  • mon2
    • Dec 2019
    • 14727
    Share the voltage to ground of the following:
    PP5V_S4
    PP3V3_S5
    PP5V_S4_P2V7NAND_LB
    PP3V3_2V7_NAND_VCC
    ; measure @ L9400
    • BMCappelletti
      • Nov 2021
      • 152
      • Brasil
      PP5V_S4
      PP3V3_S5
      PP5V_S4_P2V7NAND_LB
      PP3V3_2V7_NAND_VCC
      ; measure @ L9400
      PP5V_S4 - 0V
      PP3V3_S5 - 3.3V
      PP5V_S4_P2V7NAND_LB - 0V
      PP3V3_2V7_NAND_VCC ; measure @ L9400 - L9400 has P2V7NAND_SW and P2V7NAND_R. 0 volts. Any point near it, where PP3V3_2V7_NAND_VCC would actualy be, is also 0V.
      • mon2
        • Dec 2019
        • 14727
        Measure voltage to ground (carefully) of P5VS4_EN @ U7650 which is used to enable PP5V_S4.
        • BMCappelletti
          • Nov 2021
          • 152
          • Brasil
          Zero.
          Measured directly on the pin and on a test point.
          • BMCappelletti
            • Nov 2021
            • 152
            • Brasil
            Other other idea?
            • mon2
              • Dec 2019
              • 14727
              Do you have the trackpad attached or disconnected? If it is attached, disconnect it and test again.
              • BMCappelletti
                • Nov 2021
                • 152
                • Brasil
                #27
                I have it disconnected. Only the board. Nothing else.
                • mon2
                  • Dec 2019
                  • 14727
                  Review the power rails for your board here:
                  Power Rail List - LogiWiki
                  Note all that are not present.
                  • BMCappelletti
                    • Nov 2021
                    • 152
                    • Brasil
                    #29
                    All of these are missing.
                    PPVCC_S0_CPU
                    PPVCCSA_S0_CPU
                    PPVCCGT_S0_CPU
                    PPVCCIO_S0_CPU
                    PPVCCEDRAM_S0_CPU
                    PP0V6_S0_DDRVTT
                    PP0V6_S3_MEM_VREFDQ_A
                    PP0V6_S3_MEM_VREFCA_A
                    PP0V6_S3_MEM_VREFDQ_B
                    PP1V8_S4
                    PP1V8_S3
                    PP1V8_S3_MEM
                    PP1V8_S0
                    PP1V0_S3
                    PP1V0_S0SW
                    PP5V_S4
                    PP5V_S4SW
                    PP5V_S4SW_ISNS
                    PP5V_S0
                    PP5V_S0_KBD
                    PP3V3_S4
                    PP3V3_TBT_X_S0
                    PP3V3_TBT_T_S0
                    PP3V3_S4_BT
                    PP3V3_S4_TPAD
                    PP3V3_S4SW_SNS
                    PP3V3_S4_MESA
                    PP3V3_2V7_NAND_VCC
                    PP3V3_S4_SOC_PMU​
                    • mon2
                      • Dec 2019
                      • 14727
                      For each power rail that is not to the expected voltage range or is zero volts, measure their resistance to ground. A good idea to locate each inductor onboard and perform the same resistance measurement to ground. Report any off measurements which may be due to a shorted capacitor or something else. A low resistance will cause an excessive current draw and this will be sensed by the buck regulator or the current sense amplifier circuits and then will result in powering down that rail. Music stops playing, party is over, everyone has to go home.
                      • mon2
                        • Dec 2019
                        • 14727
                        Check that SMC_RESET_L and SMC_USBC_INT_L are properly pulled up to 3v3.
                        • BMCappelletti
                          • Nov 2021
                          • 152
                          • Brasil
                          #32
                          I can't believe it.
                          The Macbook came with an original USB-C charger, which was showing 5V when connected to my meter. So I used another original Apple charger I have. Same story.
                          Earlier today I found a Anker USB-C charger I have and I thought "why not?". I plugged in and... 5V... boom! 20V! And the board started.
                          Which means both original chargers are not ok. And I wasted my time and yours.
                          I'm really sorry about that.
                          The laptop was freezing and rebooting, but it was because of a swollen battery. I disconnected it and it's working fine for hours. Now I need to by a new charger (or not) and battery.
                          • Steven Pieter
                            Macbook Pro A1706 820-00923-05 Stuck At 5V 0.03A
                            by Steven Pieter
                            hello everyone, let me ask, I have a macbook which is stuck at 5v and 0.03 A when tested with a usb tester. Previously I wanted to replace the screen on the device, but by accident I forgot to unplug the battery. This caused the MacBook to get stuck at 5v, previously I had replaced the CD3215 (U3100) IC because it was warm. After I replaced it the problem was still not resolved. Please guide. Thank you
                            11-24-2024, 10:02 AM
                          • pluggedDan
                            MacBook Pro A1706 charge stuck at 5v when battery is plugged in
                            by pluggedDan
                            I have an A1706 that was liquid damaged, the logic board turns on and works when the battery connector is not plugged in, but when the battery is plugged in, the computer is stuck on 5v @ 30-40 Mah, and USB-C meter will reboot every 5 sec or so, pressing and holding down the power button will make the USB-C meter to stop boot looping, and if you keep holding it, fan will quickly spin up and turn off.
                            when the battery is unplugged and plug in the charger then plug in the battery it will stay on 20V and 1.6A-2.6A but when you unplug the charger, the computer...
                            10-29-2023, 02:41 PM
                          • Bmet
                            MacBook Pro 13 inch A2238 M2 stuck on 5V
                            by Bmet
                            I have a MacBook Pro 13 inch A2238 M2 and it was stuck 5V with 0 amps. I measured some important lines and I found a short on PP3V8_AON_MPMU_ISNS_VIN, I tried injecting 1v and I saw heat coming from the mPMU so I removed the pmu thinking that was the problem. I don't know why I didn't check the other side of the border but there it was, a shorted cap. I replaced the cap and the short was gone, so I reballed the PMU and put it on again but voltage was still stuck at 5V and the current was fluctuating between 0 and 0.45 amps. I checked under the thermal camera and I saw the mPM...
                            04-02-2025, 05:02 PM
                          • conghuyms
                            MacBook Air A2179 stuck logo , pls help me !
                            by conghuyms
                            Hey everyone,
                            I’ve got a MacBook Air A2179 that got some water damage through the keyboard. Now it powers on, shows the Apple logo, but just stays stuck there — no startup chime, no keyboard backlight, and no progress bar under the Apple logo.
                            When I try to boot into Internet Recovery (Option + Command + R), the mouse cursor is extremely slow and laggy — like when I lift my finger off the trackpad, the cursor keeps drifting slowly for a second or two.
                            I opened it up and found some corrosion around the LED driver IC area on the logic board. I cleaned...
                            11-05-2025, 08:30 AM
                          • modtool
                            Macbook Pro A2289 EMC 3456, MLB 820-1987-A, broken U6903, stuck at 5v
                            by modtool
                            Dear friends,
                            a close friend of mine gave me this machine, she told me that the last days the fan was going high and that it was heating up too much for the usual things, and that suddenly one morning it didn't start anymore .
                            I opened it and inspected carefully with a high magnifying lens, found no oxydized spots but a short on PPBUS_G3H , then a blown U6903.
                            I changed U6903 with a new one, PPBUS_G3H became 558 (measuring with red probe to gnd , and black on F7000) , PP3V3_G3H_RTC 463.
                            Now when I plug the usbc cable (original Apple 61W power supply), nothing starts automatically,...
                            10-25-2025, 05:09 AM
