No Display through HDMI
  • Puneet Parve
    • 6
    • India
    I have an acer swift 3 sf315-41 model and recently i stared facing issues through the hdmi port, i checked the port it looks fine and when i try to unplug the main display from the motherboard and connecting only the external monitor through hdmi the screen shows the acer logo and windows loading screen and just before the login screen and display reverts back to the no signal, monitor works just fine with my other pc, and when i try to plug both the screen and try to boot only the main screen shows output and works fine, i even reformatted the os and bios is to the latest version but the monitor connected thru the hdmi is just not detected in the windows display section as well as in device manager please help
  • mon2
    • 14664
    Fault may be with your HDMI cable. Do try a known good and perhaps even a better grade cable. The video card driver kicks in likely near the login screen and that may be the root cause. Try to boot your Windows in SAFE mode and test if the external HDMI display continues to function right upto the desktop. In the SAFE mode of Windows, the device drivers for the video card will not be loaded. Post your update.
    Respectively, it is vital that you have the proper vendor supplied (Acer) device drivers for your hardware including the video card. Often the computer manufacturer will tweak their hardware to their own desired specifications with the device driver will also be customized.
    https://www.acer.com/us-en/support/p....005/downloads
    • Puneet Parve
      • 6
      • India
      Thank you it worked, never thought updating an driver can cause such an issue.
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • DqMagetz
        Acer Nitro 5 AN515-54. displays on the external monitor and works fine, the issue is NO display on the internal screen
        by DqMagetz
        Good day!
        I have a customer's laptop — Acer Nitro 5 AN515-54 (EH5VF - LA-H501P). It has a display on the external monitor and it's working fine, but the issue is NO display on the internal screen. I already replaced the eDP cable and checked the LCD connector pins.
        Here are the voltage readings:
        • Input – 19V (stable)
        • +LCDVDD – 3.3V briefly, then drops to 0V
        • EDP_HPD – 3.3V briefly, then drops to 0V
        • PCH_BKL_PWM – 2.2–5V briefly, then drops to 0V
        • EC BKOFF# – 1.8V briefly, then drops to 0V
        • PANEL_OD_EN – 0.3V
        Is it possible that the EC chip is corrupted or damag...
        07-12-2025, 09:37 PM
      • amuse619
        Asus G15 5980HX - 6800M - No Display on Laptop - HDMI/Display Port external monitor works fine. Fried Component.
        by amuse619
        Hello!
        Looks like I fried something when my EDP cable got squeezed on the hinge. I replaced the cable but still no display. Laptop works fine with external monitor connected through HDMI and Display Port-USB C port. I took it apart and I see a burnt component. Can anyone help me identify what this component is? I tried to use schematics for another G15 but it does not match on the amount of pins and size. I attached pictures. The component has a label on it - (21A29)
        Laptop is a Asus G15 Advantage Edition 2021 Laptop Ryzen 9 5980HX - 6800M...
        08-14-2024, 01:22 PM
      • Rolin
        Lenovo Legion 5 15IMH05H No Display
        by Rolin
        I have a Lenovo Legion 5 15IMH05H 81y6003yUS that someone asked me to help them with a failing SSD. I installed a new SSD, fresh Win11 installation, updates, etc. Very standard stuff and everything was completed. He said he'll pick it up in a few days so I shut it down and set it aside.
        A few days later came and now it won't POST an image, keyboard lights up, fans spin then shuts itself off after about 40 seconds. I've already tried the typical draining capacitance and removed CMOS battery,etc. No display on an external HDMI monitor as well.. No idea what happened. Suspected a BIOS...
        06-21-2025, 11:32 PM
        Lenovo ThinkPad X1 Yoga + T24i Monitor (61CEMAR2AU) Hybrid (2-in-1) X Specification for Upgrade or Repair
        This specification for the Lenovo ThinkPad X1 Yoga + T24i Monitor (61CEMAR2AU) Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Yoga + T24i Monitor (61CEMAR2AU) boardview and X1 Yoga + T24i Monitor (61CEMAR2AU) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
        09-06-2024, 09:40 AM
