Lenovo Ideapad S145-15IIL RAM problem
  • FZG
    • Sep 2022
    • 117
    I have a strange problem with an Ideapad S145-15IIL (nm-c711). This computer has 4 GB of RAM soldered to the board and works absolutely fine as long as the additional SODIMM slot is not populated. When additional RAM is inserted then sooner or later the machine will freeze and show glitches on the screen. Mostly happens in Windows but can also happen in BIOS and also happens when booting a live Linux. Most times it happens straight upon booting the OS but sometimes it works for some minutes before it crashes.
    I tried different sticks of RAM, checked the slot and its connections, flashed the BIOS... but nothing helped.
    What I find strange is that I never get bluescreens, it´s always graphic glitching that looks like VRAM errors. The laptop does not have a discrete GPU, it is integrated in the CPU (i5-1035G1).
    Any ideas for possible causes and things I could try to fix it?​
ID:	3209713 Click image for larger version
  • FZG
    • Sep 2022
    • 117
    Nobody?
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Since there is no issues with onboard ram and issue arises only with ram slot,very likely the slot itself is defective(cpu memory controller should be ok as its working with onboard ram). The best idea is to use a ram slot tester.
      • FZG
        • Sep 2022
        • 117
        RAM slot looks okay though. No corrosion, nothing bent. I checked every single pin is soldered solid. I´m not ruling out the CPU yet, maybe a cracked solder ball corresponding to DDR channel A (the slot).
        Another thing that seems strange but might be normal: I checked resistance to ground and voltages on all coils. CPU coils (PL3400, PL3401) read 128 Ohm and voltage can be up to 1,6 V. Both values seem quite high to me. But I don´t know unless someone with the same board can confirm this.
        • Stevedb
          Stevedb
          • Feb 2018
          • 624
          • Belgium
          Is it soldered memory with those black glue. Does it has slot also pressure on the ramstick while starting board does it help?
          • FZG
            • Sep 2022
            • 117
            Yes, the onboard RAM is stuck down with black glue. Putting pressure on the RAM stick or rattling it never really changed anything.
            I have now resorted to re-soldering every pin of the RAM slot (to eliminiate possible cold solder joints) and the machine is now running for over an hour without the issue appearing. But I am still very hesitant to call it a fix. Will need to leave it running for some time and run some tests.
            Still don´t understand (if it was bad connections) why it never resulted in bluescreen errors but always graphical glitches. Is that expected behaviour?
            • FZG
              • Sep 2022
              • 117
              Ran fine for a few hours, then the problem reappeared. It is a very intermittent fault.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                A ram slot tester comes handy in this type of scenario. The ram slot is very shoddy in HP's but cant rule out any other brand.You know the quality of the mb's these days are awful.To mee it still seems like an issue with ram slot itself.
                • Stevedb
                  Stevedb
                  • Feb 2018
                  • 624
                  • Belgium
                  With onboard ram only it works perfect then?
                  • FZG
                    • Sep 2022
                    • 117
                    Yes, no problems at all with onboard RAM only.
                    About the RAM slot tester: how do they work? Would like to know more. If they check the connection between the slot and the CPU, then what would that tell me? A missing or weak signal could still be caused by the slot or the CPU.
                    • Stevedb
                      Stevedb
                      • Feb 2018
                      • 624
                      • Belgium
                      Clean the boards. Check the ddr slot for lose pins or dirty pins
                      • FZG
                        • Sep 2022
                        • 117
                        Already cleaned it and resoldered the pins. Laptop is in a stable phase right now but I fully expect it to fail again. But thanks for the input.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Cpu is very unlikely at fault since it works fine with both onboard ram and slot,hence the doubt towards ram slot. Slot tester will confirm whether the slot is bad or not.Yes i agree no tester can guarantee 100% but it gives you a close idea about the fault.
                          • FZG
                            • Sep 2022
                            • 117
                            Laptop has just passed two complete runs of Memtest86 without errors so I might call it fixed for now, even though I have changed nothing since the last time the fault occured. Strange one. Thanks for your help, guys!
                            • tomodachi
                              • Apr 2012
                              • 611
                              • Turkey
                              Same exact issue happened to me with few units.
                              I do believe DIMM slot is failing due to poor soldering from CPU side. I strongly believe a proper reballing would solve this issue.
                              • FZG
                                • Sep 2022
                                • 117
                                I do believe the same but CPU reballing is out of my league and the laptop is running fine at the moment.
                                • tomodachi
                                  • Apr 2012
                                  • 611
                                  • Turkey
                                  " if it works, don't touch it " is my motto when it comes to Lenovo lol
                                  • FZG
                                    • Sep 2022
                                    • 117
                                    Exactly 😅
                                    • hakusembons1993
                                      • Mar 2022
                                      • colombia
                                      Hi, i have an issue with the soldered module (NM-C711), if the ram module has touched, appears artefacts on the display, so, if i installed any stick on the SO-DIMM module, the laptop power on but doesn´t have image.
                                      Sorry for my bad english.​
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        You need to disable onboard memory and then try with a ram stick in slot.
                                          Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 05:20 AM
                                          Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                          Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          Lenovo IdeaPad IdeaPad 3 15IML05 Notebook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad 3 15IML05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IML05 boardview and IdeaPad 3 15IML05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-07-2024, 05:00 AM
                                          Lenovo IdeaPad IdeaPad 3 17ITL6 Ultrabook 3 Specification for Upgrade or Repair
                                          This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
