LENOVO P1 G1 (X1 EXTREME) 0.8V MAIN POWER RAIL [LPM-1]
This topic has been answered.
  • reeluff
    • Jun 2023
    • 32
    No shorts on any main power rails.
    All power mosfets over the whole board test good.
    Have 20v into first DC in mosfet, when power button is pressed main power rail is at 0.8V. Not sure if it is the EC or BQ creating that 0.8V or?
    The 2 input DC mosfets are not driving voltage, 2nd mosfet is N channel and no 25V on the gate. Again is this coming from the EC or BQ chip.
    BQ chip has 25.6V at ACDRV.
    Thankyou
  • Answer selected by reeluff at 02-15-2024, 12:23 PM.
    reeluff
    • Jun 2023
    • 32
    All finished, fixed beautifully.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Its not possible that you have ACDRV at 25V on charging chip and not on the gate of dc-in mosfets. maybe you're looking at wrong mosfets.
      • reeluff
        • Jun 2023
        • 32
        Definitely have 25.6V at ACDRV, and looking at the correct DCin mosfets.
        Turns out that this ACDRV pin is floating - not connected to anything.
        Mosfet drive must be coming from the EC chip, this board actually has 2 - specifically the TE1 chip at B2 / DCIN_DRV
        • mon2
          • Dec 2019
          • 14188
          The gate voltage has been boosted so it is the charger IC that will be supplying this line via ACDRV. Often there will be a 4k series resistor between ACDRV and the gate pin(s) of the DCin mosfets. Which exact charger IC is onboard? Would you have a link to the schematic? Probably the popular BQ (BenchMarq / TI part).
          ACDRV voltage = adapter_in voltage + REGN voltage = 19v + 6v = 25 volts to enable the N-channel mosfet(s).
          • reeluff
            • Jun 2023
            • 32
            BQ24780
            I used green marker to highlight areas of interest. It definitely is not the BQ driving DCin mosfets from what I can understand, but the TE1 chip - which is a lenovo thinkengine chip right next to the main EC chip. This TE1 looks like a seperate EC lenovo thinkengine power management chip.
            I have already replaced the TE1 chip, with no change. The chip was an aliexpress order, unsure if a good chip or not or whether this chip has to be programmed / can be programmed from the main EC however I am getting the exact same response from the board so will assume both new and old chips are as good/ bad as each other and operating the same.
            Under a thermal camera, when I have the 0.8V main power rail - it is only this TE1 chip that is doing anything on the board.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Now thats a completely new theory invented by you. To the best of my knowledge and experience, DC-IN mosfets are driven by charging controller thru ACDRV pin
              • piernov
                • Jan 2016
                • 4435
                • France
                It's not always the case. Sometimes you have a combination of P and N-channel DC-in MOSFETs, and the P-channel is not driven by ACDRV. And sometimes you even have both MOSFETs as P-channel, none driven by ACDRV.
                And Lenovo likes to do weird things on their ThinkPad lineup. As far as I understand it, the secondary ThinkEngine (which is mostly a power sequencing chip but not much info about it) is powered directly before the DC-in MOSFETs and generates its own 3.3V rail.
                • reeluff
                  • Jun 2023
                  • 32
                  Correct Piernov, the power switch is getting the 3.3v from this thinkengine power chip.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    I've not seen a p channel mosfet(as dc-in) in BQ24780 design so far. Yes,P channel mosfet are used as dc-in on many boards but then the charging ic is like BQ24737(no acdrv) or ISL. Whereever, i've seen a BQ series charging IC with ACDRV function,its Usually a N channel. May be i've not come across such design.
                    • piernov
                      • Jan 2016
                      • 4435
                      • France
                      Yes I meant with bq24780, it seems that it has replaced both the bq24735 (N-channel) and bq24737 (P-channel) designs for non-USB-C charging.
                      An example can be found on the Quanta X1BD board where 1st MOSFET is P-channel, driven separately, and 2nd MOSFET is N-channel driven by the charger IC's ACDRV output. I have no idea why they make it so convoluted though.
                      • reeluff
                        • Jun 2023
                        • 32
                        This P1 board does indeed have 1st.P + 2nd.N channel DCin mosfet pair, neither of which are driven by the BQ24780.
                        Not a completely new theory invented by me, again i will upload the schemtatic pages of interest highlighted in green.
                        You can clearly see that the BQ24780 chip, ACDRV pin is floating - going nowhere as indicated by the big X - not driving any mosfet.
                        You will also see, the 2 DCin mosfets, first being a P channel, 2nd being an N channel. The N channel gate is being driven from the TE1 chip (thinkengine power sequencing EC) on the DCIN_DRV line.
Name:	badcap schematic1.jpg
ID:	3209030 Click image for larger version
Name:	badcap schematic2.jpg
ID:	3209031 Click image for larger version
Name:	badcap schematic3.jpg
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          Yes,with the schematic pics,its clear now.Quite a weird design to diagnose.Sorry for my comments.
                          • reeluff
                            • Jun 2023
                            • 32
                            • HERETIK10
                              MSI GT70 2PE Voltage dropping on the main power rail
                              by HERETIK10
                              I have a strange problem (for me) on an MSI GT70 2PE laptop.
                              When it's under heavy load, power goes steadily to the battery (for 2 or 3 seconds) then return to the charger. If I remove the battery it turns off.
                              The higher the load, the lower the voltage on the main rail. We go from 19.5V, PC connected to the charger but turned off (normal consumption of 0.06A)
                              On, when it draws 2A the voltage is 19.2V, then eventually collapses to 18.5V (and turns off) around 5A.
                              I removed the first 2 mosfets (PQ13 & 14) from the main rail, without noticeable change....
                              11-24-2023, 06:06 AM
                            • Mugar
                              asus fa507re - hn021 plyta DA0NJNMBAD0 REV D model NJN - no reaction, main power rail shorted
                              by Mugar
                              Hey guys got laptop like above. Came to me with shorted main power rail and battery protecion on ( 0V on output). Got rid of short but nothing. Bench power supply says it takes nothing, but still got all voltages 1,2v,3.3v,5v - all good. Thermal cam showed nothing is starting even for a sec. I believe that since all coils etc are good resistance to ground it's probably one of chips. Can be IO chip or maybe something else? Could somebody help me out with this one - it's blowing my mind lol
                              05-12-2024, 01:53 AM
                            • Fronczek
                              Lenovo Legion Y520-15IKBM - No power besides the main rail
                              by Fronczek
                              Hello people,
                              I've got this laptop not working for repairs, and as you can see something was done to it as you can see in the coils PL58XX (which I for some reason cannot find in the schematics...) The first FET (PQ201) was not an original part and a questionable one at that and the second one (PQ202) was shorted. Both are N-channel. Ordered replacements for them and replaced them after arrival. Now I have encountered another problem: there is no power at the second FET. By following the thread linked I got to the injection part. Applied 0.8V at 1.5A, but couldn't feel anything getting hot,...
                              Technical discussions covering any type of laptop, notebook, netbook, tablet, or smartphone. Any and all brands and models welcome. When starting a new thread, please put the make AND model of your device in the thread title. Also be VERY descriptive of your issue, that way you'll get the best answer possible!
                              03-28-2024, 04:18 AM
                            • cheeky2
                              by cheeky2
                              05-25-2024, 03:27 AM
                            • AidenX
                              Toshiba Satellite L750D - 19v missing on the main power rail
                              by AidenX
                              Hi, i'm trying to fix this notebook with the 19v missing on the main power rail.
                              It's an old Toshiba Satellite L750D.
                              The CPU (an AMD Phenom II) can be removed but the GPU is soldered.
                              Mainboard model: DABLCDMB8E0 REV E.
                              The notebook isn't mine, and it was in pretty bad condition.
                              Other than be full of dust and with broken parts, i also found this problems:
                              1) the DDR3 ram was half-disconnected, and 1 smd capacitor near the memory chips seems burned (photo n1);
                              2) in the mainboard another one smd capacitor was not soldered,...
                              05-22-2022, 03:17 PM
