Non-existant? Thinkpad L470 corrupt bios
This topic is closed.
  • heartbreakhotel
    • Jan 2024
    • 7
    • South Africa
    Hello friends, I have searched the internet to the last pages on google, and I can't seem to find any information regarding a BIOS recovery for my Thinkpad L470, I was unknowingly updating the BIOS via windows and shut down the laptop.
    I need to know if there is a BIOS recovery method that I can use to restore this thing, when you press the power button its just a black screen, not even the backlight turns on.
    This is pretty much all info I have regarding the laptop model/serial number etc...​
  • mon2
    • Dec 2019
    • 14664
    I believe you will have to use an external programmer to remove the original bios chip -> reflash it and solder it back on to fix this case. Best to post the same question in the dedicated bios forum.
    • heartbreakhotel
      • Jan 2024
      • 7
      • South Africa
      Could you confirm if something like this would do the trick?
      https://www.takealot.com/eeprom-flas...t/PLID90431302
      will probably only use it once so I don't want to buy the wrong thing
      • mon2
        • Dec 2019
        • 14664
        Yes, I think this programmer is suitable but do wait on others to share their comments before proceeding. From a quick review of the schematics for the NM-B021 board, the flash memory chip that is of interest resides @ UC16M1. This appears to be the Winbond W25Q128FVSIQ device and is a QSPI (Quad mode SPI device). Respectively, you will need to either purchase a spare flash memory device that is of the same type or consider to reflash the one that is onboard. Personally suggest to buy a spare one to experiment with. They are not expensive from Digikey / Mouser. In my paid database service, found the flash memory chip dump for this model. This flash chip operates @ 3v3 volts so it should be straightforward to use the referenced programmer. Be sure to first check the programming software to confirm it can support this flash device - 99% sure it is possible. We recall writing our own programming s/w to operate in SPI and QSPI mode to benchmark against the Spansion brand a few years ago.
        See attached.
        Last edited by Vesko356; 01-20-2024, 05:36 PM. Reason: Bios removed. All bios requests/replies in dedicated sub-forum only please.
        • heartbreakhotel
          • Jan 2024
          • 7
          • South Africa
          I checked stock on the mentioned retailers, there seems to be 0 stock on any of them. Best I could find was eBay at almost 4 times the price. I think it's best I just try flash the onboard chip, the laptop was forgotten about regardless and it fails, it wont be the end of the world, then I might purchase a new one.
          • Vesko356
            VIP Moderator
            • Aug 2018
            • 4386
            • Bulgaria 🇧🇬
            Reminder: rules and organization of this section
            https://www.badcaps.net/forum/troubl...f-this-section
            BIOS guides, methods, resources and tools -> https://www.badcaps.net/forum/troubl...rces-and-tools
            All bios related requests/replies in dedicated sub-forum only -> BIOS Requests ONLY!
            All bios related requests/replies rules are posted here -> RULES UPDATE for BIOS requests/offers *AVOID BANNING, READ BEFORE POSTING*
            Thread closed.
            Become a Badcaps supporter
            Thanks to all supporters.
            • lucaszmn
              by lucaszmn
              Problem:
              Initial Findings:
              • I concluded that the
              08-12-2025, 03:01 PM
            • Bloodhoundje
              HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
              by Bloodhoundje
              I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
              I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
              After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
              I have desoldered the bios chip (GigaDevice...
              03-16-2024, 03:12 PM
            • TripTop
              Dell Latitude E7270 - Requesting BIOS clean/corrupt? service tag CB00KC2
              by TripTop
              Hi
              i have dell latitude E7270 with following symptoms:
              - takes long time to restart.
              - sometimes powers on and then off
              - sometimes while working it just dies,
              From googling online bios clean could possible resolve this?
              i was able to save bios and was going to try bios clean myself but get an below error when i drop it in ME analyzer.(unsure whether this sometimes occurs or could be due to bad/corrupt bios)
              As ME analyzer gave me an error i just decided to write bios with a cleaned bios from E7270 bios post.
              I reinstall...
              09-09-2024, 02:05 PM
            • MaxonDomkrat
              Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
              by MaxonDomkrat
              Hi everyone.
              I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
              07-30-2025, 01:27 PM
              Lenovo ThinkPad L470 Notebook L Specification for Upgrade or Repair
              This specification for the Lenovo ThinkPad L470 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L470 boardview and L470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
              09-06-2024, 09:10 AM
