HP Spectre x360 13t-ae000 - No power on the battery
  • tommy97
    • Mar 2023
    • 167
    Hi, i have problem with HP X360 13t-ae000, laptop power on with no battery attached, if battery is connected there is no light on the side, i've got 3 replacement batteries on all of them are the same. Checked battery mosfets they're in good standing order, just in case replaced ISL, same thing, and as well i've tried new BIOS which made no difference. I don't have much knowledge in regard to repairing this kind of issue, need some help with finding the problem.
    Board 941884-601
  • mon2
    • 14664
    Measure the voltage to ground of each pin on the battery connector while connected to the laptop. Post each measurement.
    • tommy97
      • Mar 2023
      • 167
      From the left side mon2
      1.GND
      2.GND
      3.(White) 0V
      4,5,6 11.22V
      7. 3.3V
      8. 3.2V
      9.3.2V
      10(GND)
      • mon2
        • 14664
        These measurements look good. Are the batteries marked for use with this laptop?
        what are the topside markings of the isl charger ic?
        suggest to carefully measure the voltage to ground of each pin on the charger ic with only the battery attached. Post each measurement.
        have you tested the usual dcin mosfets? Often the fault will be there.
        • mkdj
          by mkdj
          Mark and model: ASUS X571
          Tests already made:
          - I have removed...
          07-14-2025, 09:16 AM
        • DenK
          Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
          by DenK
          Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
          1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
          12-06-2024, 01:29 AM
          HP Spectre x360 Spectre x360 - 15-df0068nr Hybrid (2-in-1) 15 Specification for Upgrade or Repair
          This specification for the HP Spectre x360 Spectre x360 - 15-df0068nr Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 - 15-df0068nr boardview and Spectre x360 - 15-df0068nr schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
          09-06-2024, 07:20 AM
          HP Spectre x360 Spectre x360 - 13-aw0197tu Hybrid (2-in-1) 13 Specification for Upgrade or Repair
          This specification for the HP Spectre x360 Spectre x360 - 13-aw0197tu Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 - 13-aw0197tu boardview and Spectre x360 - 13-aw0197tu schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
          09-06-2024, 12:10 PM
          HP Spectre x360 Spectre x360 - 15-ch050na Hybrid (2-in-1) 15 Specification for Upgrade or Repair
          This specification for the HP Spectre x360 Spectre x360 - 15-ch050na Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Spectre x360 - 15-ch050na boardview and Spectre x360 - 15-ch050na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
          09-06-2024, 06:21 AM
