Macbook Pro A1932 (820-01521-A) Stuck at 4.95V 30mA
  • Junior†
    ((pro))ficient
    • Dec 2020
    • 14
    • United States of America
    Click image for larger versionName:	KE3SoAlmPA.jpgViews:	16Size:	754.7 KBID:	3181280
    I have a customer that mailed me his a1932 (820-01521-A), all i know is that it is completely dead.
    here are my measurements/observations
    with battery/fan connected (connected to 65W charger):
    top USBC port: 4.950V (starts at ~75ma, then settles at 30ma) note: sometimes this port has the same behavior as bottom port with battery connected (so 20v 0ma)
    bottom USBC port: 20V (80ma for a split second then goes to zero)
    without battery, fan is still connected:
    bottom USBC port: 4.950V (starts at ~75ma, then settles at 30ma)
    RAILS:
    PPBUS_G3H (C6483): 12.31V
    TP[1]PP3V3_G3S_G3H_RIOL: 3.3V
    PP20V_USBC_XA_VBUS(F3000): 5V (both fuses)
    PPDCIN_G3H_CHGR_AMON (C7025): 5V
    PP3v3_G3H_RTC: (C-3100/3200): 3.3V
    I2C_PWR_SCL (R8080): 1.78v
    I'm close to summing everything i've seen as T2 corruption based on this source: https://repair.wiki/w/MacBook_Air_A1...A_at_5V_repair
    but I would like a second opinion or things I should check or do to get a better idea of what kind of problem we're dealing with here (I also don't have another mac at this very moment. I'll be able to give an answer if it's stuck in DFU mode later today when i have another on hand)
    Thank you much in advance <3 (bring back the old badcaps emotes!!!!!)
  • mon2
    • Dec 2019
    • 14764
    Try with a fresh USB Type C paddle board. At the very least, clean the contacts with a Q-tip and IPA (alcohol; stuff from Costco pharmacy is great).
    • Junior†
      ((pro))ficient
      • Dec 2020
      • 14
      Hey mon2 ,
      first things first,
      I do not have a spare on hand, i'm going right now to pick up another macbook to test if it's in DFU mode.
      cleaned the ports and the connector and it's the same behavior.
      many thanks mon2
      is there anything else I should check?
      • mon2
        • Dec 2019
        • 14764
        Confirm the voltage to ground on I2C_PWR_SDA to be sure it is not defective. Yes, could be T2 firmware issue.
        Update - check this webpage:
        MacBook Air A1932 Not turning on, pulling 0.03-0.06A at 20V repair - Repair Wiki
        • Junior†
          ((pro))ficient
          • Dec 2020
          • 14
          I2C_PWR_SDA: 1.78V
          won't be able to have that macbook again until Saturday but when i connected the macbook with apple config open on the working macbook it did not recognize it at all
          I forget the error message but I think it's the usbc cable but i'm almost certain that shouldn't matter (i used the usbc charging cable from the other macbook)
          odds are I told the customer it could be T2 corruption but I won't know until saturday, many thanks mon2 <3
          • mon2
            • Dec 2019
            • 14764
            A number of setup details must be correct before the Apple Configurator tool can work.
            from what I recall:
            1) the host MacBook must be on the same or higher operating system as the target non-working computer.
            2) the port used on the target is important- 2nd on the left? Do confirm.
            3) the usb c Cable must be fully loaded. A charge cable is not considered to be fully loaded. The usb cable must have all wires connected to allow for the data flow to/from the target device.
            • Junior†
              ((pro))ficient
              • Dec 2020
              • 14
              I understand I have to look for one if not I'll charge the customer but I do have a couple i'll try before then. I'll keep you updated.
              many thanks Mon2 <3
              • bouch
                unlock macbook air A1932 2019
                by bouch
                hi
                i whant unlock macbook pro A1932 2019 whit ibridge 9,3 ;
                i change efi files find on files mina T2 activator 1,4 and use for activation mina T2 activator 1,3 , but fault ssh?
                i use mina T2 ramdisk activator 1,0 and 3,0 . but whon t work ?
                have you other programme or method compatible whit this macbook ibridge 9,3 for bypass ?
                I need help or information?
                Does anyone have the minat2 activator 1.4 software?
                Or did they use it for bypass macbook air 2019 a1932 with new ibridge 9.3?
                Thank yo...
                03-12-2025, 10:14 AM
              • astroboypaul
                Macbook A1932 Some Keys Not Working
                by astroboypaul
                Macbook A1932 had completely dead keyboard. I found liquid damage on circuitry on keyboard itself, and repaired it by replacing what i think was a 10k 0201 resistor (here's my post requesting schematic for keyboard circuitry where I included a photo of the resistor: https://www.badcaps.net/forum/troubl...ic-820-01294-a)
                Now most of the keyboard works and I can login, but the following keys don't work: Delete, "/', left...
                06-10-2024, 05:32 AM
              • astroboypaul
                MacBook Air A1932 Keyboard Schematic 820-01294-A
                by astroboypaul
                Can anyone help with a schematic and board layout for the keyboard 820-01294-A in Macbook Air A1932 please? (for reference, mainboard is 820-01521-A)
                Alternatively, I'd settle for confirming value of a resistor on the keyboard (red arrow in picture below)
                Water damage keyboard, with corrosion visible on the noted resistor (picture was taken after cleaning). One pad under the resistor was corroded and resistor fell off while clearing the potting resin (or whatever it is Apple has coated the components in).
                By chance I discovered that mainboard 820-02443 has...
                03-22-2024, 11:57 PM
              • defdjamel
                macbook a1932 no screen , no backlight
                by defdjamel
                hi there , in this A1932 - Air 13 Retina 2018 820-01521, there no screen , no backlight.
                no liquid damage.
                i have change the lcd flex ,
                tested with a working lcd screen but no display , no backlight.
                hdmi over usbc is ok .laptop is working .
                the same.
                here measurement
                • PP3V3_LCD = 3,3 V
                • PP5V_LCD = 5 V
                • I2C_SDA_TCON / I2C_SCL_TCON = 3,3 V (no oscilation)
                • LCD_PWR_EN = 5 V
                • LCDBKLT_EN_L = 12 V
                • EDP_BKLT_EN = 0 V
                • IPD_LID_OPEN = 1.8 V
                i am stuck, if you have an idea....
                09-16-2025, 06:52 AM
              • worldofskin
                Macbook Pro 2017 15" 820 - 00138 - A Not powering on, Voltages pulsing, 30mA to 200mA
                by worldofskin
                Hi guys ! Hope you are having a lovely day. This macbook pro came to the shop not powering on. Board is 820 - 00138. Its a macbook pro 2017 15". After disconnecting everything from the board and puting it on a charger i got 25-30mA. Right when i connect the charger i hear a click on the board. when i disconnect the cable i need to wait like for 5-10sec so the click happens again.If i put it back right away no click can be heard. I thought there may be a short somewhere but i cannot find it. so i checked power rails from the schematic. All the S5 rails were there. I think when i cleaned the...
                10-26-2022, 08:16 AM
