Macbook Pro 2017 15" 820 - 00138 - A Not powering on, Voltages pulsing, 30mA to 200mA
  • worldofskin
    • Jan 2022
    • 21
    • Slovensko
    Hi guys ! Hope you are having a lovely day. This macbook pro came to the shop not powering on. Board is 820 - 00138. Its a macbook pro 2017 15". After disconnecting everything from the board and puting it on a charger i got 25-30mA. Right when i connect the charger i hear a click on the board. when i disconnect the cable i need to wait like for 5-10sec so the click happens again.If i put it back right away no click can be heard. I thought there may be a short somewhere but i cannot find it. so i checked power rails from the schematic. All the S5 rails were there. I think when i cleaned the area around clock generating circuit the board started pulling more current. When i plug it in its taking more like 30mA but it jumps every like 5sec to 200-250mA current draw. When it does all of the power rails pulse. Even PPVCC_S0_CPU is at 1,7V. So i thought okay it looks like a bad bios chip. I pulled it off. The chip was - 25Q64FVSIG . without the bios chip the board jumped to around 200mA and stayed. All the powerrails with the voltage they are supposed to. After trying to read the chip i got a full FF file. The chip was dead. I replaced it with a different chip MX25L1006E whitch is a 64Mbit chip too. and i am back at the pulsing and current draw 30mA to 200mA. This is my first post so if you see any mistakes please comment it i will improve. Thanks in advance have a nice day )
  • kurland
    • Sep 2020
    • 25
    • Norway
    Re: Macbook Pro 2017 15" 820 - 00138 - A Not powering on, Voltages pulsing, 30mA to 2
    Use procedure described here to check your pwr signals. It's for 820-00165, which is mostly the same as your 00138, chip references etc.
    https://www.it-tech.com.au/mac-q-a/c...0_cpu-voltage/
    • ACS-Repair
      • Feb 2021
      • 204
      The 820-00138 board is a 2015 model MacBook Pro, not 2017. It could have been manufactured in 2017.
      With your EFI chip, it is more likely that you had a read error rather than the EFI was blank (all FF). It is a good idea to get a good read on those chips before doing swapping.
      Pulsing voltages usually means you have a short somewhere. keep looking. I'm sure you'll find it.
      • worldofskin
        • Jan 2022
        • 21
        • Slovensko
        Thanks for your reply, i did indeed try to use this procedure but only thing i got to is that i've got all of those power rails. i just cannot get to why it is powercycling.
        • worldofskin
          • Jan 2022
          • 21
          • Slovensko
          You are totally right, the bios was alright and it was not blank. I backed up the dump. i am really trying to find the short but no luck so far. Actually in the end i found a short on clock circuit so i changed the crystal and the chip too. No short anymore, the 33kHz rtc and 25MHZ clocks are there. Still no luck. I found a broken corroded cap C7150 between trace chgr_cso_n and chgr_cso_P, repaired the broken trace under it. then i found a short (1ohm) between gate and source of Q7130(PPBUS_G3H mosfet). so i changed both mosfets and the chip with them to be sure. Still no change and the short between G and S is there again. Dont know if its normal i think not. But you may be more experienced then i am. Please any of your ideas will be very helpfull i am sure. Have a great day guys )
          • reformatt
            • Feb 2020
            • 1520
            If you are getting all rails up to CPU Vcore, why are you mucking around in the PBUS Supply? Replacing components for the sake of it only introduces more potential issues, especially if you don't know the voracity of the parts.
            Power cycling means you either have a short somewhere (use a thermal camera) or it's not able to read the BIOS.
            • worldofskin
              • Jan 2022
              • 21
              • Slovensko
              You are right, actually i got a little frustrated and i just started to repair the PBUS supply. nevermind lesson learned. i will try to reflash the bios. If it wont change i will leave the mb without bios and turn it on becouse thats only time it consumes 200mA all the time.(But what does it say? i dont understand why it would be at 200mA all thetime without a bios :/) i dont have a thermal camera. i will keep looking thanks for the advice.
              • reformatt
                • Feb 2020
                • 1520
                Try a good donor clean ME BIOS, then check your SPI Bus termination resistors for corrosion, bad test points etc.
                You might also want to check U1100 (PCH) and it's resistance to ground on L7630. Seen these just go short for no reason.
                • worldofskin
                  • Jan 2022
                  • 21
                  • Slovensko
                  I tried a new bios, in the process i overheated a 3.3 G3H supply. it started generating 7V i did not respond as quick as i should. It killed smc it seems like. The board draws now 235mA all the time and the only thing that goes hot is smc. Nevermind i will give it to a good known technician. Thanks so much for the replyes again. I am smarter going out off this problem. I will post after the technician will repair it ) good luck guys.
                  • TechSplendid
                    MacBook A2442 not powering on – suspecting CD3217, but replacement didn’t help
                    by TechSplendid
                    Hi All,
                    I'm working on a MacBook Pro A2442 (14", 2021) that's not powering on. On two out of three USB-C ports, I get 5V and the current briefly ramps up to around 0.210A before dropping to 0.036A. On the third port (JF600), I only get 0.0045A and it stays there.
                    Initially, I suspected a faulty CD3217 on that port, especially since I noticed signs of previous liquid damage near the JF600 USB connector. I replaced the CD3217 with an UF400 (from an A2442 donor board from the same location). According to the supplier, this should be a compatible version, but the behavior...
                    04-09-2025, 02:13 AM
                  • speggio91
                    820-00165 pulsing and stuck at S5
                    by speggio91
                    Hello everyone!
                    I have this board that got slightly water damanged and it is stuck at S5 state. It pulses once every 5 seconds.
                    When connected the magsafe 2 to the bench psu, the current goes from 0.02A to 0.10A when is pulsing.
                    When using the genuine magsafe 2 charger, the light turn on and it became green and then amber. The fan is not spinning.
                    When I tried the SMC bypass mode, the fan spins a quarter every 5 seconds and the pulsing is still present every time the fan spin.
                    The pulses are present in the CPU Vcore rails on L7320 and L7310....
                    11-25-2023, 11:25 AM
                  • envym
                    by envym
                    Hi everyone!
                    06-27-2025, 08:54 AM
                  • Junior†
                    Macbook Pro A1932 (820-01521-A) Stuck at 4.95V 30mA
                    by Junior†
                    I have a customer that mailed me his a1932 (820-01521-A), all i know is that it is completely dead.
                    here are my measurements/observations
                    with battery/fan connected (connected to 65W charger):
                    top USBC port: 4.950V (starts at ~75ma, then settles at 30ma) note: sometimes this port has the same behavior as bottom port with battery connected (so 20v 0ma)
                    bottom USBC port: 20V (80ma for a split second then goes to zero)
                    without battery, fan is still connected:
                    top USBC port: 4.950V (starts at ~75ma, then settles at 30ma)...
                    01-18-2024, 03:43 PM
                  • ErinV
                    MacBook Pro A1989 820-00850-A not powering on
                    by ErinV
                    Hey everyone!
                    I have a MacBook Pro A1989 with a 820-00850-A board that recently stopped working. I used it overnight to charge my phone, in the morning it didn't turn on, I assumed flat battery but now won't charge and doesn't start at all.
                    I have fully dissassembled it, when disconnected the battery reads at 0.012V. Even with the battery disconnected the laptop doesn't boot.
                    The diode voltages around all 4 CD3215's seem fine.
                    For all CD3215 (UB300, UB400, U3100 and U3200) I read just above 5V on PP20V_USBC_TA_VBUS, 3.3V on PP3V3UPC_TA_LDO, 1.8V...
                    09-30-2024, 10:21 PM
