Acer Nitro 5 LA-H501P Not Charging, Not Powering On
  • Growtopia Jaw
    • Aug 2023
    • 36
    • Malaysia
    I have an Acer Nitro 5 AN515-54 no charging indicator and not powering on via AC. Battery is totally dead (0V) and I'm in the process of getting another battery that at least has some charge left in it.
    I have no idea where to start so without plugging in battery and plugging in AC, I measured main voltage rails with my analog multimeter. i've also attached boardview and schematics for this motherboard.
    Click image for larger version  Name:	image.png Views:	0 Size:	7.8 KB ID:	3176082
    [Mod. Edit]
    Schematic and boardview:
    https://www.badcaps.net/forum/troubl...11#post1492111
    https://www.badcaps.net/forum/troubl...25#post1531325
    Reminder: rules and organization of this section
    https://www.badcaps.net/forum/troubl...f-this-section
    If you request/offer BIOS/schematics/boardviews, please post in the appropriate subsection, and you can link to it in the troubleshooting topic.
    Last edited by Vesko356; 01-10-2024, 04:15 PM. Reason: Attached schematic and boardview removed and replaced with link
  • Stevedb
    Stevedb
    • Feb 2018
    • 624
    • Belgium
    You need the measurements on the charging ic
    • Growtopia Jaw
      • Aug 2023
      • 36
      • Malaysia
      I'm not really sure which component exactly is the charging IC. Could you help me out by pointing out the charging IC. Should I take measurements in volts, amps, resistance etc.?
      • mon2
        • Dec 2019
        • 14106
        Search for PUB1 in the PDF schematic = ISL88739AHRZ. This is the charger IC.
        • Growtopia Jaw
          • Aug 2023
          • 36
          • Malaysia
          Which pins exactly should I measure?
          Edit: In the meantime, I'm measuring all the pins' voltage just in case
          Click image for larger version  Name:	image.png Views:	0 Size:	716 Bytes ID:	3176337
          • mon2
            • Dec 2019
            • 14106
            Pin 30 is a good voltage to enable the dcin mosfets at pqb11 and pqb12.
            carefully measure the voltage to ground of each pin on pqb11. Then repeat for pqb12. Post each measurement.
            output at pqb12 should power the board.
            • Growtopia Jaw
              • Aug 2023
              • 36
              • Malaysia
              Here are the measurements as requested
              • Stevedb
                Stevedb
                • Feb 2018
                • 624
                • Belgium
                Looks ok so you have 19v on current sensor now we need a hd picture with all voltages on coils and resistance of the coils to ground . Resistance measured without any power and on 200ohmd or 2kohms mode or automatic but says it Kohm or Mohm.
                • Growtopia Jaw
                  • Aug 2023
                  • 36
                  • Malaysia
                  Could you point out where exactly could I find said coils in the schematics/ boardview? Thanks.
                  Edit: So basically coils are just inductors right?
                  • Growtopia Jaw
                    • Aug 2023
                    • 36
                    • Malaysia
                    I've measured resistance and voltage of the inductors and found out that almost all are 0 ohms (when NOT connected to AC) and 0V (when connected to AC) other than the PL101,102 and 103 which are getting 19V
                    • Growtopia Jaw
                      • Aug 2023
                      • 36
                      • Malaysia
                      I've also noticed that this metal bracket for the NVME slot getting quite hot for no logical reason whenever the AC adapter is connected.
                      Edit: I've also just noticed that PUB1 (ISL88739AHRZ) gets very hot and is burning to the touch. Could this be the issue all the other inductors aren't getting power?
                      • Stevedb
                        Stevedb
                        • Feb 2018
                        • 624
                        • Belgium
                        Big grey coils ( squares)
                        • Growtopia Jaw
                          • Aug 2023
                          • 36
                          • Malaysia
                          I measured it with AC plugged in and found out they are all 0V. I l also measured without AC, in resistance mode and they are all 0 ohms.
                          PL101, PL102 and PL103 is 19V when AC is plugged in.
                          • Growtopia Jaw
                            • Aug 2023
                            • 36
                            • Malaysia
                            I've replaced ISL88739AHRZ and plugged in AC. The mosfet is no longer burning hot and is in normal temperature. But all coils are still 0V when AC is plugged in. Charger receives 19V to PL101, PL102 and PL103.
                            In resistance mode (not connected to AC), coils are all 0 ohms with or without ISL88739AHRZ soldered.
                            I no longer have any idea what to do next. Does anyone have an idea?
                            • mon2
                              • Dec 2019
                              • 14106
                              Confirm the voltage on the 2*dcin mosfets at pqb11 and pqb12.
                              measure:
                              source (1-2-3)
                              gate (4)
                              drain (5-6-7-8)
                              for each of these mosfets. Post each measurement.
                              • Growtopia Jaw
                                • Aug 2023
                                • 36
                                • Malaysia
                                I've remeasured and these are the values
ID:	3182681Click image for larger version
                                • Growtopia Jaw
                                  • Aug 2023
                                  • 36
                                  • Malaysia
                                  Is it safe to say that PQB11 is bad?
                                  • mon2
                                    • Dec 2019
                                    • 14106
                                    No, not yet. We know that the adapter voltage is reaching the first mosfet from the 19v measurement. The datasheet for this part identifies the part to be N-channel type. So the gate voltage must be higher than the voltage being passed between source and drain to enable. This gate voltage should be ~25 volts to fully enable these 2 dcin mosfets. Yet the gate voltage is 0 volts.
                                    remove all power. Meter in resistance mode. Measure the resistance to ground of the gate pin. What is the measurement?
                                    Repeat for the resistance to ground on the drain pins. We are checking if either of these pins are shorted to ground.
                                    next, switch the meter to volts mode (dc scale; 30v or higher). Apply the power adapter.
                                    carefully measure the voltage to ground of the following pins on the charger ic:
                                    ACIN pin #1 ; to confirm adapter will be detected
                                    DCIN pin #18 ; to confirm the ic is being powered
                                    ACOK pin # 2 ; output flag for the adapter detection
                                    • Growtopia Jaw
                                      • Aug 2023
                                      • 36
                                      • Malaysia
                                      PQB11: gate - 9.5k ohms
                                      all drain pins - 34k ohms
                                      • mon2
                                        • Dec 2019
                                        • 14106
                                        These resistance to ground measurements are ok. No shorts here.
                                        Continue to debug the charger ic as noted above. Post each measurement. If the charger ic is not defective ; is soldered in place properly; is being powered then the gate voltage should be ~25 volts to enable these 2 dcin mosfets.
