Acer Aspire Switch 10
  • obelix24
    • Jun 2023
    • 291
    • Slovakia
    I just got Acer Aspire Switch 10 that is not turning on.
    it's charging (i get orange light)
    When i try to power it on there is nothing on the screen. I've checked and there looks no issue on motherboard.
    i've also checked with thermal camera and there are 3 components getting hot immediatelly. 0 ohm resistor (1 marked on picture) and component (2 marked on picture) and then the big chip
    see video from thermal camera
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    This BD26XXX is a multi PMIC much like newer apple boards. Check resistance to GND on all coils around this PMIC. One of the rail is likely shorted.
    • obelix24
      • Jun 2023
      • 291
      • Slovakia
      yes it looks like this chip is bad... I've already ordered another to replace this one. When it arrives i will replace it and see if it will fix the problem.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Should remove the PMIC and check resistance to GND on each coils connected to this IC. If resistance is fine after de soldering the PMIC,then and only then solder a new IC-Else the new IC may also go bad.
        • learnmore
          • Mar 2022
          • 100
          • England
          Obe, out of curiosity, how did you get the metal shields of the mainboard? I am tinkering with this model also ATM
          • obelix24
            • Jun 2023
            • 291
            • Slovakia
            I think it was just clipped. You can use something sharp to lift one corner and the it will go easy
            • learnmore
              • Mar 2022
              • 100
              • England
              Thanks, much appreciated. I used the wrong charger, and mine doesn't turn on now. I followed your lead and got the IR camera out. The charging IC was on fire, which may be expected, but I removed it, and now the 12v from the adapter seems to be travelling to the charging IC area (before, it didn't). I'm not looking forward to reattaching a 25pin QFN, as I've never got it right :/
              • obelix24
                • Jun 2023
                • 291
                • Slovakia
                I just received new pmic but i found out that cpu is bad as there was short to ground near pmic when it was removed. After removing cpu short was gone. I've ordered new cpu from ali (4€) to see if this will fix it.
                • learnmore
                  • Mar 2022
                  • 100
                  • England
                  Sounds like progress and great deal on the CPU I've recently changed the charging ic and inductor just after the dc jack that literally split in half due to using the wrong charger. The device now powers on but shuts down with a blue led light on connecting the charger. IR cam shows another IC (BQ27531YZFR-G1 £1.62) linked to the charging IC the is on fire. At this rate not econmoic as already brought a keyboard and charger lol. Nevertheless, I can't help but want to see it through. Oh, also now have a black spot on the screen--rookie mistake removing IC without removing the board completely.
                  • obelix24
                    • Jun 2023
                    • 291
                    • Slovakia
                    i found at home same chipset on other tablet ...
                    i've removed new cpu, reballed, installed in Acer and short was gone.
                    Now when i try to turn it on nothing happend.
                    When i connect power supply it takes 12V 0A there is red light when charger and battery connected. But it's taking 0A not responding to power button. With thermal camera i can see that BQ ic is getting hot and one other component.
                    • obelix24
                      • Jun 2023
                      • 291
                      • Slovakia
                      ok there was one resistor not connected.
                      Now when i connect power supply it;s charging battery fine 1A
                      but still not turning on ...
                      I've found one shorted Cap that is caused by faulty TPS61030 (i've ordered one from china) i really want to fix this tablet
                      • kumarj
                        • Mar 2017
                        • 6
                        • W.Mids
                        I know this topic is over a year old but did you get any joy with this repair? Did replacing TSP61030 help?
                        I have a Switch 10 tablet which powers on and when charger is plugged in the charging bars move for about 10 seconds and then stops.
                        It doesn't take a charge. I cannot see any shorts or burnt components so need a bit of advice.
                        Is it ok to post on this or start a new topic?
                        Thanks.
                        • obelix24
                          • Jun 2023
                          • 291
                          • Slovakia
                          no it didn't help me. i was not able to find the problem.
                          • kumarj
                            • Mar 2017
                            • 6
                            • W.Mids
                            Thanks obelix24 for your feedback. Really appreciate it.
                              ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                              This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              09-12-2024, 03:28 PM
                              ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                              This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              09-12-2024, 02:30 PM
                              ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                              This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                              09-06-2024, 05:27 AM
                              ACER Aspire Aspire M7200 Aspire 805 Specification for Upgrade or Repair
                              This specification for the ACER Aspire Aspire M7200 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7200 boardview and Aspire Aspire M7200 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
