HP G35N : How much voltage can DDR4 RAM rail take?
  • dit3
    • Nov 2023
    • 7
    • Czech Republic
    I am diagnosing my daughters laptop motherboard, its HP(8th Gen i5, dGPU) laptop with G35N motherboard, it turns on for a second and then off(without fan spinning). I found some loose screw inside(display hinge stuck), pointing to possible short caused by it, so far I tracked fault on +3V and +1.2V, I have fixed 3V issue by replacing TPS22976DPUT, but found faulty 1.2 just recently and I wanted to try out injecting it externally, to see if it comes to life.... me being impatient I tried to inject 1.2V(2A limited) from my dodgy power supply with my voltage probe hooked up and I noticed volage jump up to 1.8V, then I immediately disconnected the power supply... it was connected for about second or less. This line is connected to CPU and RAM, I am not sure how much for how long can kill CPU (replacing RAM is no problem).
    Ultimately I found that 1.2 MOSFET(AON7408) has GATE to PHASE short... so I am wondering if I should order the mosfet or if you think that CPU is dead.
    The IC(APW8868B) that creates 1.2 should provide also initial signal for HWPG based on its PGOOD out, which of caused do not appear as the mosfet is shot.
    Thank you for any suggestion
  • Nagy Daniel
    Lowest possible resistance on laptop motherboard rail - Guide Table request
    by Nagy Daniel
    Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
    I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
    I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
    So, I generated a table with AI so I can...
    03-04-2025, 08:24 AM
  • ROONEY50
    Voltage Injection on 3.3v rail
    by ROONEY50
    I am repairing a laptop that has a short on it's 3.3v rail. I injected 1v on the rail and it was pulling 200mv but can't find any heat anywhere with thermal camera or alcohol. What else can I do to find what's shorted?
    10-11-2025, 12:37 PM
  • HERETIK10
    MSI GT70 2PE Voltage dropping on the main power rail
    by HERETIK10
    I have a strange problem (for me) on an MSI GT70 2PE laptop.
    When it's under heavy load, power goes steadily to the battery (for 2 or 3 seconds) then return to the charger. If I remove the battery it turns off.
    The higher the load, the lower the voltage on the main rail. We go from 19.5V, PC connected to the charger but turned off (normal consumption of 0.06A)
    On, when it draws 2A the voltage is 19.2V, then eventually collapses to 18.5V (and turns off) around 5A.
    I removed the first 2 mosfets (PQ13 & 14) from the main rail, without noticeable change....
    11-24-2023, 06:06 AM
  • jaroslav.psenicka
    Lenovo Yoga 13 Panasonic, no video, fan OK, missing voltage rail (?)
    by jaroslav.psenicka
    I have a Lenovo Yoga 13 Panasonic here, when powered
    • both fans spins (the sconds starts with a bit of a delay), no image neither on HDMI nor the display
    • most voltage rails seem OK (see image below, red labels)
    • resistnace to ground mostly seem OK as well (blue labels)
    the only suspicious is the 0.0V rail (2nd from left, top row)
    • the resistance to ground is rather low (1.9ohm)
    • when injecting the voltage (1V), it consumes around 200mA, seems OK to me (?)
    also tried new BIOS, no change
    I can't find a schematics for the board - can some of you gurus look at the voltages?...
    05-02-2024, 05:59 AM
  • stingerchamp
    Ddr3/ddr4 ram section voltage requirements(working)
    by stingerchamp
    Follow this guide to verify voltage at RAM SECTION
    DDR 3 ram section voltage check list at ram slot
    DDR3 operating voltage VDD (at coil )= 1.5V PINs 75,76 ram slot
    VRef_DQ = 0.75 V at PIN 1
    VTT/Termination voltage= 0.75V PINs 203,204
    VRef_CA. = 0.75V PIN 126
    VDD SPD = 3.3V PIN 199
    SDA data = 3.3V PIN 200
    SCL clock = 3.3V PIN 202
    DRAM_RST# = 1.5V PIN 30
    DDR 3L ram section voltage check list at ram slot
    DDR3L...
    12-12-2020, 02:07 AM
