Lenovo nm-a272 strange behavior
  • lordmmx
    K6 Computers
    • Apr 2015
    • 48
    • Slovakia
    Hello friends,
    I have lenovo g50 mobo nm-a272 , that is behaving weirdly.
    After power on this happens:
    https://youtube.com/shorts/tBUo6eokv...Tbbz8rvLA8HGgY
    Board had replaced superio chip, that was preprogrammed and tested in identical board, also bios was done the same way.
    Board does have stable 5v and 3.3v, but nothing on cpu mosfet and logically nothing on ram mosfet.
    Does the same thing with or without memory.
    Any ideas?
  • coasterghost
    Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
    by coasterghost
    For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
    Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
    Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
    System Hardware:
    Processor: AMD Ryzen 7 PRO 5850U
    Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
    09-08-2025, 10:46 PM
  • ebyte64
    Lenovo IdeaPad 330 laptop mosfet issue
    by ebyte64
    Good day everyone.
    I have been scratching my head with a Lenovo laptop I got in today.
    The laptop had no power and taking no amps from the power supply. Checking voltage showed 20v only on one side of the first mosfet. Took it off and replaced it and then same story. Took off second mosfet and then the first mosfet had the right voltages as well as 25v on gate is it should. Replacing the second mosfet the problem started again.
    Even using a wire to bypass the second mosfet does the same interference with the first mosfet.
    Would anyone...
    06-27-2023, 10:19 AM
  • Grafnus
    Lenovo ThinkPad P15 Gen2 Battery Mosfet Replacement
    by Grafnus
    Hey there,
    first time posting here. I have been lurking a bit trying to find a solution but with little to no avail.
    So I have a Lenovo ThinkPad P15 Gen2. When I got it (for free) it was turning on but not charging because the battery was unplugged. When I plug the battery in, the Laptop won't boot at all.
    Specs:
    • Type: Lenovo ThinkPad P15 Gen2 20YQ-001KGE
    • CPU, GPU, RAM work fine (not involved in the Problem)
    So the first thought was to toss the battery and get a new one, as clearly the BMS is throwing errors or something.
    Now I noticed...
    08-06-2025, 11:54 AM
  • m0jo1103
    Need help.... Lenovo L340-15IRH mosfet missing!
    by m0jo1103
    Can someone please help me.. Mosfet is missing on this motherboard (Lenovo L340-15IRH) I cant find the part number.. Can someone please send me a picture or part number of the mosfet missing on the board.. Thankyou!
    05-19-2025, 07:13 AM
  • Jane
    How do you test MOSFET in laptops ?
    by Jane
    I tried to use this method:
    Testing an N-channel MOSFET:
    Step 1: Discharge the Gate (turn off the MOSFET)
    Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
    Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
    Step 2: Charge the Gate (turn on the MOSFET)
    Now, place the red probe on the Gate (G) and the black probe on the
    09-27-2024, 03:31 AM
