Programming chip 25LB64CSIG
  • ut-norm
    • Nov 2019
    • 70
    • italia
    Greetings to all. I need to flash the bios of an ASUS x509M. I have two CH341A and EZP 2019+ programmers that do not recognize the chip which is: Gigadevice 25LB64CSIG (I have the adapter for 1.8 v.). How could I do? Can I use another programmer or perhaps an equivalent chip?
  • mon2
    • Dec 2019
    • 14673
    It is 1v8 version. See if this helps:
    https://www.badcaps.net/forum/troubl...9-help-request
    • ut-norm
      • Nov 2019
      • 70
      • italia
      Thanks mon2 I found the solution by reading the post.I programmed the chip with the CH 341A but without the 1.8v adapter.It didn't work with EZP 2019.The CH 341A recognized the chip as GD25Q64 powered at 2.98 v. voltage measured on pins 4 and 8. The PC with the new bios began to charge the battery and started up. Thanks again​
      • Amigaaga
        • Mar 2024
        • 3
        • France
        I would like to thank you.
        This was usefull for me.
        • hairulole
          • Jan 2024
          • 11
          • Malaysia
          ut-norm If using CH341a and converter 1.8v, does it detect the chip? I afraid without using converter it would be burn the chip. May i know which ch341a programmer version you be using to reprogram the chip?
          • S4X0
            • Aug 2022
            • Indonesia
            It's easier to flash the IC chip without having to remove it from the mainboard and I've tested it using the ch341a black edition
            • gusto
              • Oct 2024
              • 34
              • Czech Republic
              I am using linux flashrom and I have this problem.
              Code:
              sudo flashrom --programmer ch341a_spi --read read01.bin
              Code:
              flashrom unknown on Linux 6.8.0-51-generic (x86_64)
              flashrom is free software, get the source code at https://flashrom.org
              Using clock_gettime for delay loops (clk_id: 1, resolution: 1ns).
              Found GigaDevice flash chip "GD25LQ64(B)" (8192 kB, SPI) on ch341a_spi.
              Reading flash...
              cb_out: error: LIBUSB_TRANSFER_ERROR
              cb_in: error: LIBUSB_TRANSFER_ERROR
              ch341a_spi_spi_send_command: Failed to write 4265 bytes
              Read operation failed!
              FAILED.
              enable_pins: Failed to write 4 bytes
              • mon2
                • Dec 2019
                • 14673
                To me, sounds like a Linux related local issue since the LIBUSB transfers are not being processed. Test with another distribution.
                • gusto
                  • Oct 2024
                  • 34
                  • Czech Republic
                  I have updated Linux Mint 22 and I tried different USB ports.
                  Tomorrow I will try a completely different PC.
                  The log shows that the programmer identified the chip, but could not read the data.​
