MacBook Pro 13" M2 No trackpad click high fan spin
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    Board powers on and display turns on, battery holds charge, I know the trackpad is the issue, replaced the trackpad with new M2 trackpad and cable since they were burnt, also replaced the connector on the board good as new, pins are getting power, however since I do not have the schematic for this and cannot seem to find it, can someone point me in the right direction to get this trackpad working and also maybe provide a M2 A2338 schematic?
    I have no power on these pins so far
    7,11,12,27, 29,41
    pin 25 is .5volts which is low. Need schematic to pin point the short so I can get this trackpad happy.
    update: found the schematic on here. I’ll come back with my findings
    sigpic
    MEOWING IN THE IMPOSSIBLE UNIVERSE!
  • Stephen
    Meow Meow MEOW!
    • Apr 2020
    • 674
    So no click on track pad still, cannot seem to find the short that is causing this trackpad to not click which will cause the major fan spin and the keyboard to not function (from experience)
    I am getting voltage on the PPBUS_AON pins without issue. But I am not getting voltage on pins as follows
    Pin7
    Pin11
    Pin 12
    Pin 25 (.5v) is being shown which is in my suspicion low.
    Pin 27
    pin 29
    Pin 41
    sigpic
    • mon2
      • 14698
      Remove all power. Measure the resistance to ground of pin 25.
      • Stephen
        Meow Meow MEOW!
        • Apr 2020
        • 674
        Nothing coming up from pin 25
        sigpic
        • mon2
          • 14698
          What is the resistance to ground on pin #25?
          • Stephen
            Meow Meow MEOW!
            • Apr 2020
            • 674
            No readings coming up for pin 25 with resistance to ground
            sigpic
            • mitchw
              MacBook Pro M4 Pro - no keyboard / trackpad / lid sensor
              by mitchw
              Hello
              I got this MacBook Pro M4 Pro to have a look at.
              It was tiny bit liquid damaged, just the edge of the board got 1 small 10x10 mm area wet. I've seen much worse that still worked fine to be honest.
              Since it was liquid damaged, warranty does not apply anymore.
              Anyways it was checked at an local Apple Store and they discovered that it needs new trackpad, new top case, etc. Also it needed a new lid angle sensor which they replaced.
              The main issue was that the screen remained black.
              Anyways I cleaned the liquid damaged area, put the machine back...
              09-06-2025, 07:19 AM
            • Skrndelj
              Apple Macbook Air M1 A2337 Trackpad problem
              by Skrndelj
              Hello all,
              I am repairing a Macbook A2337 and i have a problem
              The Macbook is stuck in restore as someone before me tried a DFU restore and bricked the device, now i can't do a restore as AC2 throws error 1 which is related to the trackpad.
              When i turn on the device i get the trackpad click for a few moments and then nothing, i tried 7 trackpads and 7 trackpad flats, i know all 7 are functioning okay, especially one as i use it for testing and DFU restore.
              I inspected the whole board and everything seems fine.
              Can anyone help me as i didn't fiddle with trackpad...
              06-11-2024, 04:26 AM
            • rynr
              MacBook Air M2 A2681 no Trackpad
              by rynr
              I have been following the posts in the forum for some time now and have learned a lot. I would first like to thank you for this and hope that it will continue for a long time.
              I received the MacBook in DFU. The recovery always failed with error 1. After some search, I was able to find a defective inductor (LT202).
              After replacing the component, I was able to successfully complete the DFU restore. Unfortunately, the trackpad and keyboard where still without function.
              So i measured all voltages and diodereadings on the JT400 connector. ...
              11-04-2024, 09:56 AM
            • Vliegenier04
              Macbook A2338 M2 (EMC 8162) keyboard not functioning, trackpad is working
              by Vliegenier04
              Hi! This Mac has been an headscratcher for me, I can't seem to figure out the issue. The Macbook has gotten water damage to the front of the keyboard connector and battery connector. The keyboard connector was dead, by which I mean it was completely corroded and I have replaced it with a brand new one.
              I have verified all the pins are connected to the main board and the main voltages (PP1V8_AONSW_KBD_ISNS and PP3V3_AON_KBD_CONN) are both present, with and without keyboard attached.
              Unfortunately, the keyboard does NOT want to work, caps lock LED not functioning as well as any...
              06-16-2025, 12:03 PM
            • biosdi
              MacBook Pro A1989 trackpad and keyboard not working
              by biosdi
              Hi guys.
              I Just replaced battery on my MacBook Pro A1989. Unfortunately doing that, I’ve broken the trackpad flex cable (821-01701-a), and I’ve already ordered a spare one. At the same moment I’ve noticed that also the keyboard it’s not working anymore and I’ve found an SMD chip unsoldered and moving freely inside the backplate. I can read L20L on the chip. Is something could explain the keyboard not working or the keyboard doesn’t work due the unconnected trackpad?
              thanks...
              04-17-2025, 09:42 AM
