Macbook Air 1466 820-00165-A no power (CPU heats)
  • andersonamr
    • Sep 2022
    • Brazil
    Hi guys, i'm working on a macbook air a1466 820-00165-A.
    My costumer said it just stopped working without any cause.
    The SOC is heating a bit, no fan spin, magsafe shows green light when connected and then it turns orange.
    PPBUS_G3H 8.57v
    PP3V4_G3H 3.434V
    No signs of liquid damage, drawing 0.173ma on the power supply.
    Already tested another flex cable and I/O board, same results.
    Thanks for your time!
  • mon2
    • Dec 2019
    • 14256
    A1466 2015-2017 13” MacBook Air - Repair Wiki
    • envym
      MacBook Pro 2018 with Activation Lock
      by envym
      Hi everyone!
      I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
      I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
      06-27-2025, 08:54 AM
    • Yosua
      MACBOOK AIR 1466 DEAD
      by Yosua
      HELLO FELLOW COLLECTORS, How are you doing, I hope GOD always gives us good health, I'm here asking for help to work on this MacBook Air, to be honest, this is the first time I'm dealing with a MacBook machine, and I immediately decided that the ISL 6259 IC and after I replaced it it still didn't work and I found that the CHGR_CSO_N & CHGR_CSO_P pins had a short circuit.
      can anyone help me guys?​
      02-17-2025, 02:07 AM
    • tobeend
      Bypass mdm macbook m2 ventura
      by tobeend
      1. RESET MACOS WITH IPSW
      a. Power off MacBook, press and hold the power button to enter Recovery
      b. Open Disk Utility, remove Macintosh HD
      c. Reboot, connect to the network to Activate Mac.
      d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
      d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
      e. Release the other keys, but keep holding the Power key for another 10 seconds
      f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
      05-26-2023, 07:18 AM
    • Lgolebio
      MacBook AIR 1466 [ 820-00165-A] = Missing "PM_SLP_S5_L"
      by Lgolebio
      Hi
      MacBook AIR 1466
      MB: 820-00165-A
      I followed the power scheme https://logi.wiki/images/a/af/G3_-_S...ell.drawio.png. I have all voltages up to "PM_SLP_S5_L" = 0V. When I plug the charger it tries to power on, goes to 0,250A then goes to 0,023A and does nothing. No fan spin.
      I'm confused, board looks good under microscope. No corrosion.
      05-15-2023, 04:52 AM
    • SarcasticOP
      General question about MacBook power rails for repair.
      by SarcasticOP
      I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
      • PPBUS_G3H (12.6V-12.8V)
        • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
      • PP3V42_G3H (3.42V)
        • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
      • PPVRTC_G3H (3.3V)
        • This
      12-12-2024, 05:50 PM
