Macbook Air 1466 820-00165-A no power (CPU heats)
  • andersonamr
    • Sep 2022
    • Brazil
    Hi guys, i'm working on a macbook air a1466 820-00165-A.
    My costumer said it just stopped working without any cause.
    The SOC is heating a bit, no fan spin, magsafe shows green light when connected and then it turns orange.
    PPBUS_G3H 8.57v
    PP3V4_G3H 3.434V
    No signs of liquid damage, drawing 0.173ma on the power supply.
    Already tested another flex cable and I/O board, same results.
    Thanks for your time!
  • mon2
    • 14662
    A1466 2015-2017 13” MacBook Air - Repair Wiki
    • ahmarzo
      MacBook Air a 1466 keyboard and touch not working
      by ahmarzo
      Have a MacBook Air a 1466 with part no 820-00165-a with keyboard and touchpad not working.have tried another working keyboard and touchpad.have check the cable to board and it's good
      The voltage on connector j4800 is following
      Pin no 1-3.3v
      Pin no 10 3.3v
      Pin no 14 - 5v
      Pin no 15-20 all pins have 3.3v
      Have reballed the ic u 5000. And tried another ssd with working os .
      10-18-2025, 10:40 AM
    • envym
      by envym
      Hi everyone!
      06-27-2025, 08:54 AM
    • Yosua
      MACBOOK AIR 1466 DEAD
      by Yosua
      HELLO FELLOW COLLECTORS, How are you doing, I hope GOD always gives us good health, I'm here asking for help to work on this MacBook Air, to be honest, this is the first time I'm dealing with a MacBook machine, and I immediately decided that the ISL 6259 IC and after I replaced it it still didn't work and I found that the CHGR_CSO_N & CHGR_CSO_P pins had a short circuit.
      can anyone help me guys?​
      02-17-2025, 02:07 AM
    • Flasman90
      Macbook Pro DFU Restore Issues
      by Flasman90
      I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
      - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
      - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
      08-30-2025, 10:27 AM
    • tobeend
      Bypass mdm macbook m2 ventura
      by tobeend
      1. RESET MACOS WITH IPSW
      a. Power off MacBook, press and hold the power button to enter Recovery
      b. Open Disk Utility, remove Macintosh HD
      c. Reboot, connect to the network to Activate Mac.
      d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
      d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
      e. Release the other keys, but keep holding the Power key for another 10 seconds
      f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
      05-26-2023, 07:18 AM
