dell la-611p doesn't charge
  • kjchatman
    • Dec 2012
    • 213
    • united states
    the board is missing 3valw_ec so it doesn't detect the charger but it powers up for a few seconds when the power button is pressed.
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    3V LDO present or not?
    • kjchatman
      • Dec 2012
      • 213
      • united states
      +3vlp is present at 3.3v
      • MahmoudNasser
        Dell Vostro 3400 battery does not charge beyond 55%
        by MahmoudNasser
        I have a Dell Vostro 3400 battery does not charge beyond 55%
        I tried another file... the battery charge exceeded 55%, but it entered manufacturing mode and it did not count from it.
        - I rebuilt the basic BIOS and Clear Me, but without results
        What if the same situation does not charge the battery more than 55%?
        Can someone help me?
        The original BIOS file is attached
        Device Data
        Model Dell Vostro 3400
        CPU:i5-11th
        SN 7G4BRF3
        MP PartNumper:LA-K032P REV 1.0 (A00)
        Bios Chips:XM25QH64A...
        10-09-2023, 03:58 PM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • diamon
        Dell 5590 LA-F412P does charge with USB-C not with DC-Jack
        by diamon
        As mentioned, I have a Dell 5590 laptop with motherboard LA-F412P.
        This laptop works with the USB-C charger and not with DC-Jack charger.
        With the USB-C charger attached, the battery is charging and in the BIOS the charger is also recognized.
        With the DC-Jack charger attached (USB-C charger removed), the light of the charger is not going off and the BIOS does not see the charger (message AC Adapter = Not installed). I'm using original Dell chargers and I have tested the used chargers on other Dell laptops and they are working correctly.
        I have replaced the DC-Jack,...
        12-29-2023, 07:29 AM
      • reeluff
        DELL XPS 15 9510 LA-K411P (NVDC ISL9538C) NO BOOT / NO CHARGE
        by reeluff
        Device history > Bit of liquid damage, that I cleaned up and sorted out all bad components.
        Current state > No Boot. No charge. It negotiates 20v on all USBC ports, and will even PD charge out – so all of the USBC circuit is probably ok. I have 3.3V + 5V ALWP present and stable. PCH has its 3V,1.8V,1V. On the board, PCH,EC,ISL,PD chips are all powered on and active. Power button has 3V, board is being signalled by it but not responding. I have 20V USBC in OK, I have a 12.6V main power rail ok. The battery was undervolt dead, so had to manually charge each cell individually...
        02-09-2024, 09:37 AM
      • Akhlz001
        by Akhlz001
        09-20-2025, 07:15 PM
