Hello. Lenovo 710-11isk NM-A771,SR2ER processor with built-in hub and video. When connected from a laboratory power supply, the current consumption rises to 300mA, after 10-20 seconds it drops to 250mA. It may stay like this for a long time, or it may fall to 10mA. The display is connected to the board, voltages are present on the processor PWM, except +CPU_VCCGT video core power supply (no PWM signal) I replaced the NCP81206 controller, but it did not change anything. All voltages are normal except +CPU_VCCGT. I also replaced the PWM charge controller because there is no signal from it to the PSYS_CPU processor PWM. It didn't change anything. I also flashed the BIOS with a clean ME region. I understand that the signal rises under load, but I have no other display to check. If anyone had a similar problem, please let me know. Thank you
					Lenovo 710-11isk autostart, no picture
			by coasterghostFor Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
 Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
 Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
 System Hardware:
 Processor: AMD Ryzen 7 PRO 5850U
 Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...09-08-2025, 10:46 PM
			by minaedwardHi all
 I have an Lenovo Thinkbook 14 G2 laptop with no picture
 when pressing the power bottom the ESC and Caps lock led are on then the Caps lock goes off and ESC stays on but with no picture
 earlier it startup but freeze at Lenovo logo
 All voltages are present so I suspect the onboard ram
 I flashed a disabled onboard ram Bios but with no success
 There is a memid section on the schematic which I believe it concerns about the onboard ram
 but I don't understand it
 Anyone could help me with this issue is appreciated
 (attached the memid part)...
			by elprojectsHello, I have a problem with lenovo all in one ThinkCentre M800z, mb: lm70z 14072-1, ih110sw/v1.0, It turns on and post no picture, i think that the problem is with the bios, the attached dump of the main bios 8mb, there are three spi flash on the board in total.
 the board stopped working after windows update and reboot....-
			by dhs6512Hello. Lenovo Legion 5 15ACH6H 82JU PF303BT1, board HY660 HY661 HY561 HY572 HY56C HY57K NM-D562 Rev:2.0 2021-01-25.
 Starts up, the keyboard backlight lights up, the sound of the Windows 11 password entry window loading is heard, the backlight brightness is adjustable on the keyboard,
 when pressing caps or numlock there is an indicator, there is no picture either to its own or to an external one via HDMI. I checked the board under a microscope, ok, clean and untouched.
 I threw in a matrix (FHD, 40 pin, 144Hz), flashed the BIOS (official, took the latest gkcn65ww and one earlier...
			by YellowJacketGreetings badcaps community,
 I would ask for little help with diagnosing Lenovo V330-15IKB, which I got as dead - after pressing the power button there was no reaction, just dead.
 Model: V330-15IKB
 Board number: LV315KB ; 17807-3 ; 448.0DC04.0031
 Serial number: R90Q6BW3
 (Schematic, boardview and resistances/voltages attached)
 When I got it, battery had 0V, so I am diagnosing it without battery, with original lenovo charger. After some searching, I managed to make it run by reflashing the bios - but I have no picture ( even on attached...
- Loading...
