HP Compaq 2230s Dead !! Need Help...?!
  • degutji
    • Dec 2012
    • 173
    • Indonesia
    Hi All,
    Receive Compaq 2230s in condition Totally Dead no light or any sign of life ( at first dc jack led come on for once and goes off before i remove nec tokin 128, and now completely dead ). I've flashed Bios chip and replace nec tokin with 4 caps 330u/2.5v, and measure at JACK1000 ( for the record Adapter is OK )
    pin # 1 & 2 = 19v
    pin # 3 = 4.7v ( is it ok ? ) some friends on this forum has say that pin #3 (Pin ID / LIMIT_SIGNAL ) must be 7-8v to work, so i trace it to U1 on pin #1 ADP_ID get 0v, is this problem ? or U18 problem ? need advise here
    And one question how do we use dc bench power supply with this type of 3 pin adapter as we know common adapter only 2 pin, still confuse till now
  • dj_ricoh
    • 2073
    Re: HP Compaq 2230s Dead !! Need Help...?!
    Did you put something under the caps so it can touch the second layer of solder?
    De - from the cap its the second line.
    Maybe you need to put the caps like this \\ //
    • degutji
      • Dec 2012
      • 173
      • Indonesia
      Thk's for you advise dj but usually put like that with no problem. I've scratch the pads for soldering caps leg.
      • degutji
        • Dec 2012
        • 173
        • Indonesia
        Anyone pls....?
        • dj_ricoh
          • 2073
          do you know that there is + - and ground?
          you dont scratch the mobo so you can put the ground to those caps
          it need to touch those pads the pads where made for those.
          not the ground layer scratched
          • alihomee
            • Dec 2012
            • 1574
            • malaysia
            i agree with dj u must solder the caps with those grounds
            • degutji
              • Dec 2012
              • 173
              • Indonesia
              I know what you mean DJ, and already change position as you advise still same , for the record the pads where made for those caps is same with green pads that I've scracth so the problem is about limit signal that less than 7-8v ( maybe ), in my measurement on my board , i get only 4.7v is it correct ?
              • dj_ricoh
                • 2073
                still no sign of life?
                the led from the charger goes off after you plug it in?
                • degutji
                  • Dec 2012
                  • 173
                  • Indonesia
                  Problem solved
                  Thank's DJ
                  • dj_ricoh
                    • 2073
                    Pfiu I'm happy when a project it's finish.
                    We all love a happy ending
                    • alihomee
                      • Dec 2012
                      • 1574
                      • malaysia
                      how u solve it please shear it hear
                      • hschen
                        • Mar 2014
                        • 3
                        • China
                        Hi All,
                        I have a HP Compaq 2230s notebook too, and the problem is the BIOS password has been missed. I've indicated that the BIOS chip should be flashed, but not confirm which chip is and whether it should be take it down from the motherboard.
                        Thanks very much!
                        Best wishes
                        • lezsimply
                          The Wanderer
                          • 645
                          • Philippines
                          I think this is your bios chip U16, check page42 of schematic. try to remove rtc battery first to reset bios.
                          • hschen
                            • Mar 2014
                            • 3
                            • China
                            Yes, it's U16!
                            But remove rtc battery cannot clear the password, the bios must be flashed.
                            Maybe the chip should be taken down, flash, and put back again.
                            • lezsimply
                              The Wanderer
                              • 645
                              • Philippines
                              yes that's your best bet. backup bios first before flashing, post results after. thanks
                              • yhank
                                • Feb 2014
                                • jakarta timur
                                Thanks yyoou
                                • BassT
                                  • Mar 2016
                                  • 6
                                  • Nigeria
                                  Hi guys, i have a HP 2230s that indicates it's charging but can't power on at all. Pls any help on how to resolve this will be appreciated.
                                  • BassT
                                    • Mar 2016
                                    • 6
                                    • Nigeria
                                      • 31015
                                      start by testing the power switch - it sounds obvious, but they can fail.
                                      • BassT
                                        • Mar 2016
                                        • 6
                                        • Nigeria
                                        Thanks stj. i will do that and post my findings
                                          HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                                          09-12-2024, 03:44 PM
                                          HP Compaq Compaq SG3-240ES Compaq SG3 220 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Compaq SG3-240ES can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-240ES boardview and Compaq Compaq SG3-240ES schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower Compaq Pro 6005 B59 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower boardview and Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                          09-12-2024, 03:36 PM
                                          HP Compaq Compaq dc7900 Compaq Q9400 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Compaq dc7900 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq dc7900 boardview and Compaq Compaq dc7900 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-12-2024, 03:30 PM
                                          HP Compaq Compaq SG3-331IT Compaq SG3 245 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Compaq SG3-331IT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-331IT boardview and Compaq Compaq SG3-331IT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
