benq joybook lite u121 can not boot
  • alihomee
    • Dec 2012
    • 1574
    • malaysia
    this benq netbook can not boot after the benq logo only blank screen with blinking small white line. even i cant not go into bios by pressing f2 i also try with usb key board but still same but if i press alt ctrl del it restarts that means the key board is working...........any ideas and if some body have bios file for this model please post it
  • lefos
    • Nov 2013
    • 321
    • Greece
    Re: benq joybook lite u121 can not boot
    Have you tried with keyboard or touchpad disconnected?
    • Keshetisrael
      Tech-N-Training
      • 72
      Have you tried hitting F8 or F12 or any combination of keys? Esc? While booting up?
      Do you have a mobo card testor kit?
      http://www.youtube.com/watch?v=38PyYkbksnE
      • robrock1
        • Jul 2013
        • 129
        • Ghana
        disconnect keyboard and mouse, change memory, remove hard disk do a cmos reset
        • alihomee
          • Dec 2012
          • 1574
          • malaysia
          try all this already but same........any one got bios file for this model because i think that the bios is corrupted
          • alihomee
            • Dec 2012
            • 1574
            • malaysia
            any body got the file
            • robrock1
              • Jul 2013
              • 129
              • Ghana
              try reflowing the southbridge if you cant get the bios file
              • alihomee
                • Dec 2012
                • 1574
                • malaysia
                i am sure this is bios problem because after logo it shows only blinking light but if i press esc then it shows options like f2 and f8 but if i press f2 then it hangs there so if any body got bios file for this model please....................thanks in advance
                • alihomee
                  • Dec 2012
                  • 1574
                  • malaysia
                  any body pleaseeeeeeeeeeeeeeeeeeeeeeeeeeeee
                  • degutji
                    • Dec 2012
                    • 173
                    • Indonesia
                    I used to replace R near keyboard socket when dealing with this kind of problem on old model
                    • alihomee
                      • Dec 2012
                      • 1574
                      • malaysia
                      what u mean by r
                      • dj_ricoh
                        • 2073
                        • uk
                        Resistor
                        • degutji
                          • Dec 2012
                          • 173
                          • Indonesia
                          R ( resistor ) don't know what type is
                          • selldoor
                            Slow Learner
                            • Dec 2010
                            • 7870
                            it is an array 15ohms
                            https://www.google.co.uk/search?q=re...iw=977&bih=646
                            and a data sheet
                            • alihomee
                              • Dec 2012
                              • 1574
                              • malaysia
                              key board is working ok i need the bios file so that i can flash the chip..........................thanks
                              • alihomee
                                • Dec 2012
                                • 1574
                                • malaysia
                                any body got
                                • alihomee
                                  • Dec 2012
                                  • 1574
                                  • malaysia
                                  no answer for this bios
                                  • tecmax
                                    • Jan 2014
                                    • 5
                                    • India
                                    When you say there is no option to boot from USB stick... There wasn't on mine either - to start with... I finally discovered that - with power OFF, I had to insert the USB stick - then enter BIOS... THEN it 'found' the USB stick and gave me the chance to boot from it....
                                    Try that... Then, if you can run Jolicloud from the USB stick, (live) you will be (should be) able to install successfully from 1. within the live distro or 2. after rebooting again, from the USB stick.
