Toshiba C660 voltage rail problem
  • lord
    • May 2011
    • 319
    • Croatia
    I have this problem, i am missing a 1.5V rail. It is a LA-6842P rev.1.0 board (page 39 of the attached schematic).
    The MOSFET-s are OK, VTTP_EN is 5V, i have 5V at Low Driver Gate, but nothing on the DH (pin 13).
    Could it be the chip?
    Is there a posibility that anything else in the circuit could be wrong?
    Regards,
    Darko
  • whaldsz
    • Apr 2013
    • 395
    • Philippines
    Re: Toshiba C660 voltage rail problem
    What do you get at pin6 PGOOD pin?
    • lord
      • May 2011
      • 319
      • Croatia
      It was the chip, i replaced the stock G5603RU1U with TPS51117 and it works. Now when i have the 1.5V and all power supplys to clock generator, i don't have frequency on the crystal. :|
      Suspect the clock generator now.
      • lord
        • May 2011
        • 319
        • Croatia
        Nothing, logical low voltage.
        • whaldsz
          • Apr 2013
          • 395
          • Philippines
          And you get a voltage at PL802? If so, then there's something wrong with this circuit. PGOOD pin should be high. Is the +5VS and PR811 ok?
          • rtstorm
            • Feb 2012
            • 971
            • Croatia
            what is the symptoms of this fail? (LED, fan, display)
            ...the quieter you become the more you are able to hear...
            • whaldsz
              • Apr 2013
              • 395
              • Philippines
              I don't exactly understand what you mean, could you clarify more about the issue you are having.
              • Francisco.s
                • 686
                • Spain
                Recheck voltages.
                Could be new replaced chip is damaged.
                • lord
                  • May 2011
                  • 319
                  • Croatia
                  I repaired the 1.5V rail with replaceing the IC controller, now i miss +CPU_CORE from PU13, which i replaced already.
                  Here are the readings from PU13:
                  PGOOD at pin 1 is low
                  CLK_EN# at pin 40 is 3.3V
                  VR_ON at pin 38 is 3.3V (What does this pin do?)
                  I also noticed that i don't have any frequency readings from clock generator on Y1. All input voltages to clock generator and CK_PWRGD/PD# is low (i think this is supposed to be low because Q37 connects this pin with ground after CLK_ENABLE# goes hi).
                  I tried to replace the crystal, and i have one more used RTM890, so i tried with that but lo luck. I also tried with this used RTM890 but also no luck.
                  Does anyboy knows which one has to work first: the +COU_CORE rail or the clock generator?
                    09-06-2024, 05:27 AM
                  • tvguy12012012120
                    Samsung UN55NU6900F Standyby voltage is 1V higher than expected, is this a problem?
                    by tvguy12012012120
                    This is the zombie UN55NU6900F I wrote about in this original post.
                    It originally was completely dead with no standby voltage. After some poking around, I found the solder at RM819 (see pictures) failed. I removed it from the board, it tested fine, resoldered it, and now the TV works.
                    The expected standby voltage at the reference pin is specified to be 11.8V but it's reading 12.8V. Couple questions:
                    1. What could cause the standby voltage to be 1V higher than expected
                    2. Is this a problem
                    3. Could it have led to the failure at RM819, or was that...
                    02-12-2025, 11:22 AM
                    Toshiba Portege R30-C Notebook Specification for Upgrade or Repair
                    This specification for the Toshiba Portege R30-C Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the R30-C boardview and R30-C schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Portege...
                    09-06-2024, 05:30 AM
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • doctormasry
                    toshiba c660 la-6847p nopower bad problem
                    by doctormasry
                    i have toshiba c660 pwwaa la-6847p problem
                    3.3 volt is present
                    5 volt is present
                    when i connect adaptor led is on
                    there is no 3.3 volt on press power
                    u19 i/o ene
                    pin 30 ON/OFFBTN# is 3.3 v
                    pin 100 EC_RSMRST# is 3.3 v
                    pin 102 EC_ON is 3.3...
                    08-20-2021, 04:06 PM
