Acer aspire 6920g - no display issue after fix
  • murphyai
    murphyai
    • Nov 2013
    • 26
    • ireland
    I have a acer aspire 6920g that i'm trying to repair for a friend.
    It kept restarting all the time.
    so i proceeded to change the nec tokin oe907 chip on the motherboard with 2 x 470uf 2.5v capacitors
    since i've done this the battery is now charging when it wasn't previously but the screen will not appear from the vga display on the motherboard.
    I forgot to put thermal pads back on the gpu when i was putting it back and used only thermal grease.
    anyone any ideas?
  • dj_ricoh
    • 2073
    Re: Acer aspire 6920g - no display issue after fix
    use 4x 330 always go higher
    • murphyai
      murphyai
      • Nov 2013
      • 26
      • ireland
      i don't think that is the solution
      oe907 is 900
      2 x 470uf is 940 so it is higher.
      i previously tried 4 x 470uf and that was too much
      also battery was not charging with 4 capacitors but it is now with 2
      any other ideas community?
      • trebo
        • 514
        • Wales, UK
        high esr caps maybe,
        or no continuity between the two positive ends that some MBs don't seem to have
        • murphyai
          murphyai
          • Nov 2013
          • 26
          • ireland
          if there is no positivity between the positive ends how come the battery is charging now?
          • rievax_60
            • May 2012
            • 897
            • australia
            The NEC/TOKIN capacitor filters the CPU's Vcore voltage.
            • jtamad44
              • Apr 2013
              • 145
              • israel
              oe907 is 900
              Why don't you try to put 3 x 470uf see what happen.
              • Francisco.s
                • 686
                • Spain
                Nec tokin, filters cpu core voltage, but circuit charger should work in stand-by. (no need cpu)
                Can you charge the battery and check if laptop woks properly with it?
                • murphyai
                  murphyai
                  • Nov 2013
                  • 26
                  • ireland
                  i'll add one more capacitor later on.
                  then charge the battery and try to boot off it.
                  don't see how the capacitor would affect the video though
                  • dj_ricoh
                    • 2073
                    if i take the cpu from my working notebook... will it work?
                    so if the voltage its not powering up the cpu will it work?
                    • rievax_60
                      • May 2012
                      • 897
                      • australia
                      When you are asked to check continuity between the end strips, do you know what is meant?
                      Why do you keep ignoring something that is simple and might be important?
                      What do you normally repair as a professional tech?
                      • murphyai
                        murphyai
                        • Nov 2013
                        • 26
                        • ireland
                        to check continuity do i need a multimeter.
                        i don't usually repair motherboards at component level.
                        i fixed network and software issues usually
                        • jtamad44
                          • Apr 2013
                          • 145
                          • israel
                          here
                          http://www.ebay.com/itm/Fluke-115-Di...-/170707010480
                          • murphyai
                            murphyai
                            • Nov 2013
                            • 26
                            • ireland
                            well, i took out my motherboard yesterday and placed it in the oven at 220 degrees for 10 minutes
                            battery started to charge and work on it's own after that.
                            but still no video.
                            haven't got around yet to testing the charge
                            • kostas-
                              • May 2016
                              • 13
                              • Greece
                              I have the same problem on the same model (acer aspire 6920g). Had random restarts and i replace the NEC/TOKIN 0E907 with a new one. After i replace it i have no video (laptop screen, VGA and HDMI).
                              I test other NEC/TOKIN, cpu, memory and MXM graphic card but the problem still exists. So the problem must be on m/b. I test it only with m/b, cpu, memory, graphic card, fan, power button and an external monitor via VGA port. I try to power up the laptop while pressing the north bridge chip (Intel LE82PM965) with no result. In case suddenly the chipset fail (i know not the best way to test it).
                              Before, the laptop was working and the only problem was the restarts. I disabled the second cpu core from device manager and working without any problem. So i decided to replace the NEC/TOKIN.
                              I have a multimeter. How to check continuity between the end strips as mention above? I'm not sure i understand it. The voltage on NEC/TOKIN is 0v on both sides. Also, the cpu and chipset never heated.
                              If i put 4x 330uF 2.5V tantalum capacitors it is possible to fix the problem? If the NEC/TOKIN removed, the laptop behave this way (no video)?
                              Any ideas or advices?
                              • ala_borbe
                                aka Donald
                                • 1625
                                • Malta
                                i had similar problem with toshiba, there is a post somewhere, talantum order from ebay was bad, replaced with used from dead motherboard and it worked
                                you can also use 6x220 2.5v
                                worked for me anyways
                                Im Back... sort of...
                                • kostas-
                                  • May 2016
                                  • 13
                                  • Greece
                                  Thanks for the reply. I'll try the smd tantalum capacitors. But i'm afraid it's something else.
                                  • kostas-
                                    • May 2016
                                    • 13
                                    • Greece
                                    I replace the NEC/TOKIN with 2x 470uF caps (used from other laptop). Also, replace the core voltage controller (ADP3208) and two mosfets (Si7686DP).
                                    Now with the cpu attached when you press the power button the power light opens for a second and turns down. Of course no video. Also, the fan try to spin but stop immediately. Without the cpu the power light remains open and the fan spins.
                                    I check all the system voltages (5V, 3V, 1.5V, etc) and it's ok. I test with other cpu and graphic card with the same results.
                                    Any ideas?
                                      ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                      This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-12-2024, 03:28 PM
                                      ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                      This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                      09-12-2024, 02:30 PM
                                      ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                      This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                      09-06-2024, 05:27 AM
                                      ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                                      This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
