Compaq 615-Does not work at all
+ More Options
Posts
  • olorin
    • Sep 2013
    • 82
    • Greece
    Hi..I have compaq 615 Worked fine.Today when I press the power button it does nothing.It does not work at all!! Nor does lit no lamp!When connected to the ac adapter the white light illuminates indicating that powered.I tried with another charger but nothing.Even with the battery does not work.
    What happened???
    What can I do?
    Thank's!
  • bowor
    • Oct 2013
    • 36
    • indonesia
    Re: Compaq 615-Does not work at all
    Update bios first!!
    • dj_ricoh
      • 2073
      • uk
      bios battery out. notebook bat out, unplug the power button and let it sit like that for 10 min?15? the plug everything back and try.
      • olorin
        • Sep 2013
        • 82
        • Greece
        Originally posted by bowor
        Update bios first!!
        How do I update the BIOS insomuch the laptop dont works!
        • olorin
          • Sep 2013
          • 82
          • Greece
          Thank's for your answer.
          I did everything you said but still nothing happened.
          What can I do next?
          • jtamad44
            • Apr 2013
            • 145
            • israel
            you can flash manual, check it out;
            http://www.drivestar.biz/programmer-...6mqj8jj7b659u3
            • Alfa is auto
              • May 2013
              • 83
              • Finland
              How about the ati 3200..loose balls
              • olorin
                • Sep 2013
                • 82
                • Greece
                Now I remembered that I already have the latest version of BIOS.Upgrade a few days before to be spoiled
                • olorin
                  • Sep 2013
                  • 82
                  • Greece
                  Dude, you mean that we need to made reflow on chipset?
                  • dj_ricoh
                    • 2073
                    • uk
                    to update the bios you need a bios programmer
                    • olorin
                      • Sep 2013
                      • 82
                      • Greece
                      I update BIOS from Windows with F.20 version from here http://h20565.www2.hp.com/portal/sit...tte.cachetoken before spoiling.
                      Is it possible to needs the GPU reflow?
                      • Alfa is auto
                        • May 2013
                        • 83
                        • Finland
                        I,ve had same symptoms on another 615 no power only lights on battery charger and i did reflow and after that it work..try mild reflow and see what happens.
                        • Alfa is auto
                          • May 2013
                          • 83
                          • Finland
                          Still i think something vent wrong with bios update..
                          • RJARRRPCGP
                            • Jul 2004
                            • 6304
                            What happened???
                            What can I do?
                            Thank's!
                            Sounds like the solder got screwed, because of high core temps. Because it's an HP/Compaq.
                            ASRock B550 PG Velocita
                            Ryzen 9 "Vermeer" 5900X
                            Arc A770 16 GB
                            eVGA Supernova G3 750W
                            Alienware AW3423DWF OLED
                            • olorin
                              • Sep 2013
                              • 82
                              • Greece
                              Suddenly the laptop worked itself,but it does not work the screen(black screen) and Caps lock flashing 5 times.
                              • trebo
                                • 514
                                • Wales, UK
                                I think 5 flashes MB failure,
                                It may be worth disconnecting screen from MB and trying a external monitor etc
                                • olorin
                                  • Sep 2013
                                  • 82
                                  • Greece
                                  I try...nothing again.....!!!
                                  • jtamad44
                                    • Apr 2013
                                    • 145
                                    • israel
                                    bga chip issue, if you have Ati or Nvidia chip, reflow it, if you don't reflow northbrigde chip.
                                    • olorin
                                      • Sep 2013
                                      • 82
                                      • Greece
                                      I reflow ATI GPU but nothing hapened!!!!!!Now does not work at all as before
                                      • robrock1
                                        • Jul 2013
                                        • 129
                                        • Ghana
                                        then it was too hot now the chip is damaged, need to replace it with a new one
                                          HP Compaq Compaq SG3-240ES Compaq SG3 220 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Compaq SG3-240ES can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-240ES boardview and Compaq Compaq SG3-240ES schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-12-2024, 03:44 PM
                                          HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
                                          HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower Compaq Pro 6005 B59 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower boardview and Compaq Pro Počítač Compaq 6005 Pro (ENERGY STAR) v provedení microtower schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                                          09-12-2024, 03:36 PM
                                          HP Compaq Compaq SG3-331IT Compaq SG3 245 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Compaq SG3-331IT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq SG3-331IT boardview and Compaq Compaq SG3-331IT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                          09-12-2024, 03:30 PM
                                          HP Compaq Compaq dc7900 Compaq Q9400 Specification for Upgrade or Repair
                                          This specification for the HP Compaq Compaq dc7900 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Compaq dc7900 boardview and Compaq Compaq dc7900 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
