Toshiba C660 LA-7202P water damage
  • spleenharvester
    • Mar 2010
    • 921
    Got this board today. Not a heavy amount of water damage and no corrosion but the damage ended up where it mattered.
    It's covered TPS51125, the card reader chip, and the ISL chip which generates GFX/CPU vcore. All right next to the SATA connector.
    Done a good clean up and done resistance tests. Surprisingly, almost all lines test OK with only +5VALW, +3VALW shorted. So I think I stand a chance of getting this board working (it's a very rare Socket G2 board for this model so I'd like to!
    Lots of blackened caps around the TPS51125. Far as I can tell no voltage is generated past VIN.
    Schematic here:
    How do I test TPS51125 and the ISL charger chip?
    Cheers!
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
  • spleenharvester
    • Mar 2010
    • 921
    Re: Toshiba C660 LA-7202P water damage
    PQ332 tests as shorted from pins 1/2/3 to pin 4. So either PQ332 is shorted or TPS51125 is. I'm guessing I need to replace TPS51125?
    B+ line is okay, full 19V on that side.
    • spleenharvester
      • Mar 2010
      • 921
      Can I replace TPS51125A with TPS51125? I've found a VIN-side dead L450 board with exactly the same TPS51125 schematic, except it doesn't use the A version!
      I'm guessing I need to remove 51125, test for the shorted caps, replace any, then replace 51125?
      • spleenharvester
        • Mar 2010
        • 921
        Replaced TPS51125, plugged in, heard a brief "BZZZ" sound. Still dead but now there's the sound of a relay clicking. And 5V rail is no longer shorted.
        EDIT: Something on VIN is now shorted. I think this one is dead.
        EDIT2: Plugged battery in and something on the board went up in plumes of smoke. Lol this one is screwed. TPS51125 isn't even anywhere near VIN so I have no idea what's caused this.
        EDIT: I know what I did. soldered TPS51125 the wrong damn way! FFS! Make sure you get your positioning right when you solder folks!
        • tomodachi
          • Apr 2012
          • 611
          • Turkey
          I really wonder if you managed to work it or not
          • spleenharvester
            • Mar 2010
            • 921
            Agh I had a good chance too! Turned out when I checked the orientation I was looking at TPS51125 on a different schematic :/ Ah well, we live and learn.
            • tomodachi
              • Apr 2012
              • 611
              • Turkey
              • ChetanSethi
                • Oct 2015
                • 11
                • India
                i have la-7202p toshiba logo stuck both bios are reprogram but same any solution
                • Ugur87
                  MacBook Air M4 A3240 Brand New Water Damage no Image
                  by Ugur87
                  I have a brand new 13.6-inch MacBook Air M4 that was only used for three days and now has water damage. A glass of water was spilled over it. I examined the motherboard and there was only water next to the display connector. I cleaned it with isopropanol and the components look clean. The MacBook obviously turns on and draws 20 volts from the power supply. The keyboard backlight comes on, but the display remains black. Where should I best start? Even when I shine a light on the display, I don't see any image. I have all the tools I need, including an infrared camera. Where should I best start?...
                  08-28-2025, 01:09 PM
                • edugimeno
                  Stagg sms12p audio amp has water damage
                  by edugimeno
                  Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
                  I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
                  There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
                  There is only one signal wire connecting the first boards...
                  05-24-2025, 06:00 AM
                • Joel Ohana
                  Lenovo IdeaPad 3 15IAU7 that suffered water damage
                  by Joel Ohana
                  I have a Lenovo IdeaPad 3 15IAU7 that suffered water damage. It doesn't turn on (white power light flashes when on button pressed), and the amber light flashes when plugged in.
                  Symptoms:
                  • Short detected – sparks appear when touching the charging port connection with board with a metal (even a multimeter probe).
                  • Visible damage – after cleaning corrosion, I found 4 possibly burnt memory chips near PC3165, labeled UD5, UD6, UD7, and UD8.
                  What are my next steps to diagnose and possibly repair it without replacing the entire board? Any guidance would be greatly...
                  03-06-2025, 11:25 AM
                • abajor
                  A2141 820-01700 Water Damage L8504 Damaged, U3100/U3200 power cycles UB300/UB400 5V .25A
                  by abajor
                  Like title says A2141 came in with Water Damage, customer desperately wants the data.
                  The actual water ingress doesn't appear too bad it sat for a day but was very dusty internally. I have no idea why L8504 was arced there is no apparent moisture there or around the LVDS cable; however, the LVDS to screen screw studs had popped off at some point and somebody tried securing it with kapton tape.
                  I had to create a micron wire pad jumper to reconnect the south side of the L8504 since the primary pad was blasted down to the vias.
                  That said after cleaning up the...
                  12-21-2024, 07:16 PM
                • s_henya
                  Macbook Air A3114 5V 0.0A after water damage
                  by s_henya
                  Hi Mac experts :-)
                  Im usually not getting too many Mac logic boards repairs, (mostly PC laptops)
                  This Mac isn't powering on not boosting to 20v, stays at 5v with 0.0Amps.
                  Took out the board and it suffered some water damage, see attached pics.
                  All cleaned with IPA but due to long time with corrosion something already got shorted...
                  any advice on the below:?
                  1. Looking for relatively safe location for voltage injection as all of the caps around that area has 0.0ohms resistance.
                  I tried injecting 0.5v on one of the caps...
                  08-25-2025, 01:09 PM
