Toshiba A300 turns off after 10 secs
  • rmps
    • Oct 2009
    • 82
    Hi guys..
    This notebook turns off after 10 seconds. Even on bios... I´ve tried with battery only and power only and even with battery + power. Same results.
    Initially this notebook didnt power on because the TI BQ24721C was shorted. So i´ve bought one and changed it. Now the notebook powers up fine, i can access the bios but it turns itself off after 10 seconds no matter what i do...
    Already replaced the NEC/TOKIN chip too...
    Any ideas?
    Thanks in advance
  • spleenharvester
    • Mar 2010
    • 913
    Re: Toshiba A300 turns off after 10 secs
    Remove RAM and power it. Does it still power off after 10 seconds?
    Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
    • rmps
      • Oct 2009
      • 82
      yes it does mate :/
      • janpol10
        • Apr 2012
        • 6
        • Philippines
        You have to replace the capacitor (NEC TOKIN) with the same value Or another options is the modification process using 4 tantalum capacitor (330uf atleast 2.5 volts).
        • spleenharvester
          • Mar 2010
          • 913
          That's really peculiar. And almost certainly not an NEC/Tokin problem (I have powered Tokin repaired L300 boards up with shorts across the caps and no caps at all before and not a single one of them powered off). Maybe a thermal shutdown?
          Personally, I'd go through all the S0 power state voltages (5V run, 3V run etc) and measure them from power on time until power off time. Maybe something is gradually dropping below a threshold?
          • fddizon
            • Sep 2011
            • 555
            • Philippines
            Remove processor. Test all coils to ground using ohmmeter. If u find a short in one of them, you know what to do
            • whaldsz
              • Apr 2013
              • 395
              • Philippines
              You may try to reflash the bios.
              • spleenharvester
                • Mar 2010
                • 913
                Actually, come to think of it, my test L300 board does this if no processor is present. I know it POSTs but have you tried a different one?
                • rmps
                  • Oct 2009
                  • 82
                  I've tought about it too but i dont have another one to test.... :/
                  I'm going to test the coils later like the other member said. Then i'll post results.
                  • spleenharvester
                    • Mar 2010
                    • 913
                    Whereabouts are you based? If you're in the UK I can chuck a Celeron 900 in the post for you to try.
                    • rmps
                      • Oct 2009
                      • 82
                      Ok, so..
                      Tested all coils for shorts. Nothing shorted!
                      Tested with another CPU. Same problem!
                      I´m out of ideas....
                      • dycc
                        Vision
                        • Nov 2011
                        • 625
                        • Côte d'Ivoire
                        probably something that heats
                        • robrock1
                          • Jul 2013
                          • 129
                          • Ghana
                          check if the cooler really touches the cpu, maybe there is some small gap between? Had similar problem before, i had to bent the cooler and screw it back very tightly.
                          • dj_ricoh
                            • 2073
                            • uk
                            Originally posted by rmps
                            Ok, so..
                            What is a good value and a bad value for a coil?
                            • robrock1
                              • Jul 2013
                              • 129
                              • Ghana
                              a coil should generally be low ohms, if it burns resistance will go up. but it will need a lot of power so you will see it from the outside.
                              • jtamad44
                                • Apr 2013
                                • 145
                                • israel
                                to make it sure, remove coil and measure the value, if the value is ok, then trace backward or forward reading.
                                • infosquadsn
                                  • Nov 2013
                                  • Argentina
                                  What is the mainboard model ?
                                  Could be a overheat protection circuit issue or even a BGA problem on the southbridge.
                                  Sorry my poor english and good luck
                                    Toshiba Satellite A300-1RZ Specification for Upgrade or Repair
                                    This specification for the Toshiba Satellite A300-1RZ can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A300-1RZ boardview and A300-1RZ schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba Satellite...
                                    09-06-2024, 05:27 AM
                                    Toshiba Satellite Pro A300-1MK Specification for Upgrade or Repair
                                    This specification for the Toshiba Satellite Pro A300-1MK can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A300-1MK boardview and A300-1MK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                    Toshiba Satellite Pro A300-22J Specification for Upgrade or Repair
                                    This specification for the Toshiba Satellite Pro A300-22J can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A300-22J boardview and A300-22J schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Toshiba...
                                    Toshiba Satellite A300 A300-14S Laptop Schematic
                                    Quanta BL5S Santa Rosa - Rev 1A...
                                    11-01-2024, 07:49 AM
