e-machines 732Z: daozrcmb6co mosfet?
  • speedypro
    • Feb 2013
    • 561
    Anyone knows the where to get this schematic? eMachine e732z board model number daozrcmb6co rev c?
    This mosfet i need with writings: 1A36BV. In correct order is shows:
    F1A36BV
    FDD
    6685
    Full-time computer repair tech (10am - 6pm) and full-time, (8am - 11pm), Ruby on Rails Developer
  • speedypro
    • Feb 2013
    • 561
    Re: e-machines 732Z: daozrcmb6co mosfet?
    Any help? This laptop works ok but only on a full battery. Will not work with charger. There is a ticking sound on MB when charger plugs in.
    • Jane
      How do you test MOSFET in laptops ?
      by Jane
      I tried to use this method:
      Testing an N-channel MOSFET:
      Step 1: Discharge the Gate (turn off the MOSFET)
      Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
      Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
      Step 2: Charge the Gate (turn on the MOSFET)
      Now, place the red probe on the Gate (G) and the black probe on the
      09-27-2024, 03:31 AM
      ACER eMachines PT.NCAE2.071 eMachines EL1850 E5800 Specification for Upgrade or Repair
      This specification for the ACER eMachines PT.NCAE2.071 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the eMachines PT.NCAE2.071 boardview and eMachines PT.NCAE2.071 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
      09-12-2024, 03:36 PM
    • Nooy
      VGA MOSfet permanently shorted and loss of MOSfet pad
      by Nooy
      Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
      I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
      02-14-2024, 02:26 AM
    • AppleLover123
      Asus X712EA 3 volts after the first mosfet
      by AppleLover123
      Hey guys,
      i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
      I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
      Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
      I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
      Now i thought something...
      12-15-2024, 07:49 AM
    • MicroSMD Lab
      by MicroSMD Lab
      I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
      01-10-2024, 06:36 AM
