Dell D620 not booting, intermittent
  • morphski
    • Mar 2013
    • uk
    I have a Dell D620 that doesn't always turn on. When you press the power button the numlock, capslock, scroll lock, power light and wifi light come on for about 3 secs then go off. Then without moving anything, it will turn on ok. It does this if either powered on mains, or battery only. I have tried the reset trick, and have also re-seated memory, hard drive etc. Does anyone have any ideas?? I have seen another thread on here about powering on without the keyboard, but I can't make the picture out. Does anyone have the schematics for this board to bypass power button?
  • morphski
    • Mar 2013
    • uk
    Re: Dell D620 not booting, intermittent
    I have found 2 pads near the keyboard connector p/sw that were covered in glue, i have removed the glue, and shorted these out, and it still does the same, only flashing numlock, capslock, scroll lock, power light for a few seconds. I know when it's going to boot correctly, because when the lights come on, the HDD light will illuminate at the same time
    • sonunigam
      • Aug 2013
      • 151
      • Pakistan
      Just wash your mother board in a very good way with Thinner or Petrol especially the CPU Processor's Socket. Your laptop will be fine. . . . .
      • Daniel Kubica
        Dell Latitude 5590 i5-8350U LA-F411P kernel panic when booting from USB
        by Daniel Kubica
        I got a bare Dell Lattitude 5590 with missing battery, RAM, RTC battery and Storage, I wanted to put some components in it and use it as my home laptop. After adding a FRU 2GB DDR4 2400 SoDIMM RamaxelRAMI've tried booting Linux Mint from USB, I got an error while trying to boot it. I tried reseating the stick, different slot, didn't help.
        I tried to boot Windows 10 installer, as that was the stock system my model came with, got a BSOD as soon as the installer started booting, different code every time. I've tried switching to AHCI mode, I've tried linux in legacy mode, I've tried compatibility...
        06-14-2025, 09:24 AM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • expertreader
        Dell 5520 not booting up - on light comes on momentarily
        by expertreader
        Dell 5520 South peak 15 MB 213253-1 2TWTT$LA
        Hi all, looking for some help to get started on troubleshooting without schematics
        I have used Dell Latitude 5530 SouthPeak15 MLK 203102-1 schematics from forum although this board is a little bit different.
        I am a bit lost on USBC PD circuit and what to measure - here is what i have done so far.
        • no coils are shorted - one is showing about 15ohms but others are in kohms or infinite resistance.
        • most of the coils are showing 5V, 1.3V, 3V etc except 2 of them.
        • i have measured 16.5V available at the capacitor
        10-19-2025, 08:20 PM
        Dell Latitude D620 Laptop Boardview
        JM5-F...
        10-22-2024, 04:33 AM
      • Akhlz001
        by Akhlz001
        09-20-2025, 07:15 PM
